rear bumper I started build. - Page 3 - Ford Bronco Forum
 5Likes
post #41 of 63 (permalink) Old 04-19-2015, 07:11 AM Thread Starter
bonsai dave's Avatar
Bronco Info: 79 with a 460 dana 60's rear 35 spline full spool. front welded with hidro asst. 9" of lift on 44 bo
Originally Posted by helirich View Post
Is the high lift bolted on?
Yes, one bolt on the foot plate and one behind the tire in the center tube.
for the love of mud. F.O.T.M. July 2015.
bonsai dave is offline
post #42 of 63 (permalink) Old 04-19-2015, 02:23 PM
Steve83's Avatar
Doesn't that make it difficult to access when you need it? Why not make it hold itself on by jacking it out against some stops? Then you could release it without tools, other than the jack handle.
post #43 of 63 (permalink) Old 04-19-2015, 03:36 PM
helirich's Avatar
Not sure what the answer is in this case. If you make it too eazy, it may get stolen. A high lift is a lot more in demand then shackles.
helirich is offline
post #44 of 63 (permalink) Old 04-19-2015, 03:40 PM
Steve83's Avatar
...but not as easy to stash as you walk through a parking lot with it, and not as apparent how to remove from its mount. A padlock would be easier to install for mall-crawling & remove at the trailhead than bolts.
post #45 of 63 (permalink) Old 04-20-2015, 07:12 AM Thread Starter
That's a good ideal Steve, but I think over time it would lose it's friction by stretching the stops out. The jack is easy to access with the swing arm open.
post #46 of 63 (permalink) Old 04-20-2015, 07:31 AM Thread Starter
I going to drill a hole through the top bolt for a lock. To keep it from getting stolen.
post #47 of 63 (permalink) Old 04-20-2015, 08:09 AM
Hillbilly Heaven's Avatar
Bronco Info: 1979 Bronco
Best solution for both is to use a wheel stud with a wheel lock nut. To keep someone from using something like a pair of vice grips or a hammer on the lock, just use a piece of tubing to surround the lock.
post #48 of 63 (permalink) Old 04-20-2015, 07:22 PM
Steve83's Avatar
Originally Posted by bonsai dave View Post
...it would lose it's friction...
It wouldn't hold by friction; it would mechanically interlock. A couple of thin rubber pads would keep it from rattling.
...stretching the stops out.
Only if you make the stops too weak.
post #49 of 63 (permalink) Old 04-21-2015, 07:18 AM Thread Starter
This is another good idea, I'm not to concerned there's not a high demand on hi-lift jacks in my area. I think it would be over kill for a Toyota, Honda or any other foreign junk cars running around here.
post #50 of 63 (permalink) Old 04-21-2015, 07:39 AM Thread Starter
It wouldn't hold by friction; it would mechanically interlock. A couple of thin rubber pads would keep it from rattling.Only if you make the stops too weak.
Yes, mechanically interlock jack out to stops and held in place by pressure? I still think it would loosen up. There is one rubber pad to keep it from rattling on the center tubes bolt.
post #51 of 63 (permalink) Old 04-21-2015, 12:42 PM
helirich's Avatar
Correct me if I'm wrong, but I'm thinking a high lift put between two immovable stops will not be able to get tight. It has to go alittle past a distance and then back down abit. If you have two immovable stops, it won't be able to go past the stop. If it can go past, it will back down to a lose spot.
If you put a thick piece of rubber on the stop, it could get tight. But only the rubber would be holding it. I don't like that on something that heavy.
helirich is offline
post #52 of 63 (permalink) Old 04-21-2015, 01:08 PM
Steve83's Avatar
You're assuming the stops are rigid. They can be 1) immovable, 2) strong, but 3) flexible enough to allow the jack to work & hold tight. Think about an old valve spring mounted around a short tube... Other small parts of the structure could hold the jack centered on the spring.
But if he's happy with the bolts...
post #53 of 63 (permalink) Old 04-21-2015, 02:31 PM
The idea of using a valve spring sounds like a good idea. Design whatever stop you want for the top of the valve spring. It will need a rod inside the valve spring to keep it in place when you remove the jack. You get a lot of travel with a non compressed valve spring. Use an old retainer for the base of the stop.
post #54 of 63 (permalink) Old 04-22-2015, 06:02 AM Thread Starter
OK Steve, I can see a valve spring working with a center pin. The spring would hold the pressure and the pin would be the retainer. That's a good ideal also now that you added a spring in it. and yes I'm happy with the bolts.
post #55 of 63 (permalink) Old 04-24-2015, 11:48 PM
EdgarBronco1979's Avatar
Bronco Info: 1979 Ranger XLT,
Nice looking bumper! I'm going build custom bumpers for mine.... Someday!!
EdgarBronco1979 is offline
post #56 of 63 (permalink) Old 05-14-2015, 05:54 PM
Just read through this...great looking bumper. Beefy!
TaylorF-150 is offline
post #57 of 63 (permalink) Old 11-15-2016, 06:33 AM Thread Starter
I built a new bumper for my 95 I had just pic up a few months back.
RAMPNT1 likes this.
post #58 of 63 (permalink) Old 11-15-2016, 07:55 AM
Nice work!
post #59 of 63 (permalink) Old 11-15-2016, 09:11 AM
helirich's Avatar
Looks nice. Are you starting with a piece of angle or tube? (The main bumper) How are you curving the ends?
helirich is offline
post #60 of 63 (permalink) Old 11-16-2016, 06:24 AM Thread Starter
Originally Posted by 445 FE Bronco View Post
Nice work!
Thanks
Thanks, I started with 1/4" plate.
TJSmoot likes this.
