School me on Air Compressors - Page 3 - Ford Bronco Forum
 11Likes
post #41 of 105 (permalink) Old 02-04-2015, 09:52 AM
Resurection Ranch
379sinvb's Avatar
Originally Posted by Rockford514 View Post
If i use mine hard during the summer it will make about a quart of water every two days or less
Well Buddy, I've never drained mine . So I'm not looking forward to seeing how much comes out of mine. Yeah, I know read the owners manual. It will be read for sure now. You and I have a very similar compressor.
Rick
My Projects- "Left for Dead"
Filly
379sinvb is offline
post #42 of 105 (permalink) Old 02-04-2015, 10:57 AM
RESIDENT ASSHOLE
Dirtdigger's Avatar
Bronco Info: ,2003 F-150
When and if you drain it ,expect water & RUST.That shit will stain you concrete.
____________________________
I dont suffer from insanity I enjoy every minute of it
Duct tape can't fix stupid........but it can muffle the sound!
Dirtdigger is offline
post #43 of 105 (permalink) Old 02-04-2015, 11:27 AM
dash_cam's Avatar
my 28 gal compressor builds up moisture every time. i put a 90* valve on it and it's great. i just use my foot to flip it off or on. i did, however, have to raise it a little so the bigger valve would fit.
it's fun to do bad things
my "build" thread
dash_cam is offline
post #44 of 105 (permalink) Old 02-17-2015, 04:19 AM
AussieF100's Avatar
Bronco Info: 84 F100 Shortbed, 351C, AOD, 4WD.
Originally Posted by turpit View Post
Harsh.
Yeah, well, maybe I am an idiot, or a tin hat wearer to some, but the truth is the truth and it hurts sometimes.
Certainly there is no hunting like the hunting of man and those who have hunted armed men long enough and liked it, never really care for anything else thereafter. You will meet them doing various things with resolve, but their interest rarely holds because after the other thing ordinary life is as flat as the taste of wine when the taste buds have been burned off your tongue - Ernest Hemingway.
AussieF100 is offline
post #45 of 105 (permalink) Old 02-17-2015, 04:21 AM
AussieF100's Avatar
my POS worked great for 20+years. Good luck getting that out of the junk they're selling today.
True, but the junk sold these days doesn't turn into a WMD created by a PMS.
post #46 of 105 (permalink) Old 05-19-2015, 08:43 PM Thread Starter
Beach bumming it ........
Saltlife's Avatar
Just wanted to update on the compressor. I have been using it for a few months now every weekend for , airing, 1/2 impact, 3/8 impact, chisel, drill, and cut off wheels.
It has done me great so far. Only thing I have noticed like Jowens said you diffidently want to drain it at the end of the day every use.
After two days:
But it keeps up with everything I need. Setup:
I did get a reel makes a huge difference around the garage having one.
Anyone else use these ColorConnex fittings? I get them from Northern Tool and love them. No leaks, durable, and blue.
See the difference to the original fittings.
They work great!
Saltlife is offline
post #47 of 105 (permalink) Old 05-19-2015, 08:56 PM
Harley's & Bronco's FTW!
I've been using the standard basic airfittings forever and never have any problems.
Them sure do look purdy though.
Love the hose reel. can't hardly imagine living without one.
still need to setup that angle pipe and drain extension.
BikerPepe` is online now
post #48 of 105 (permalink) Old 05-19-2015, 09:08 PM Thread Starter
Saltlife's Avatar
I even bought the pieces to make the extended drain. I just have to get the compressor higher in the air. I like the availability of movement so Maybe bigger tires. I haven't really looked into anything.
Saltlife is offline
post #49 of 105 (permalink) Old 05-19-2015, 09:14 PM
yea... I'll have to raise mine as well. currently it's just sitting on a few rubber pads I cut off some conveyor belt I picked up a few years back for misc. material.
I'm thinking some 4x4 blocks and screw in through the feet. Mine's not mobile... but it's big.
post #50 of 105 (permalink) Old 05-19-2015, 10:08 PM
pfun41's Avatar
Ive been using the standard fittings forever. For a long time I had issues with leaks at the couplers, then I figured out that I just destroy them. Ive been buying them from HF for years. I realized the Brass ones are actually WORSE than the regular steel ones. For a while I used the Anodized fittings and found they worked well, except that I had to buy a whole pack when the coupler was the only piece wearing out. I did figure out that a universal coupler has a better seal and is damn near bulletproof, but its a PITA to connect and disconnect.
http://www.harborfreight.com/14-in-f...ler-68184.html
I'm now using the regular steel fittings.
Be honest salt, you got a little too excited with the couplers. I'm counting way more than necessary.
Oh yeah, I just got an old school 100 psi air compressor with a belt drive V-twin cast Iron pump. Just one catch. No one ever drained it. The bottom of the tank rotted and is leaking air.
https://www.youtube.com/watch?v=ElQH4FrhDvY
pfun41 is offline
post #51 of 105 (permalink) Old 05-20-2015, 03:00 AM
Steve83's Avatar
Update on my air compressor:
post #52 of 105 (permalink) Old 05-20-2015, 08:03 AM Thread Starter
Saltlife's Avatar
If your talking about the ones connecting the compressor to the reel I had to. The reel fitting are 3/8s and the air fittings are 1/4. I had to work with what I had, I will get adapters later.
Saltlife is offline
post #53 of 105 (permalink) Old 05-25-2015, 08:00 PM Thread Starter
Saltlife's Avatar
Saltlife is offline
post #54 of 105 (permalink) Old 05-25-2015, 09:35 PM
Thread Killa
jowens1126's Avatar
One thing to think about when your getting alot of water in the lines. The air coming out of the compressor is typically HOT, and saturated with water. As most may know, the hotter the air is, the more water it will hold (to a point). As the air cools, the water vapor drops out as condensate. When you de-pressurize a pressurized container, the air going thru whatever line your using cools very quickly, causing the moisture to drop out as condensate. This is why you get alot of water coming out of the end of a 25 ' line. The air has a good length of hose to cool in and let the water condense.
So in order to optimize this effect to your advantage, I would suggest taking a 25' section of hose and coil it up neatly somehow. Then connect the end to something like this......
You can make that from parts at lowes/home depot for about $40, then choose your own manifold pieces or just put a valve on the end to connect to your hose reel. The first section will catch the majority of water and it can be easily drained.
You can also add a automatic drain valve as seen in this diagram.
devildog93 likes this.
jowens1126 is online now
post #55 of 105 (permalink) Old 05-25-2015, 09:51 PM
dash_cam's Avatar
Originally Posted by Saltlife View Post
i had one of those and it worked ok. i sold it when i sold that compressor. when i hooked up my new one, i found an IR separator / oiler for something stupid like $15.
i don't have a 25' hose, but i did use a 6' coil hose and do exactly what you mentioned.
my "build" thread
dash_cam is offline
post #56 of 105 (permalink) Old 05-25-2015, 09:52 PM
pfun41's Avatar
If I had unlimited time, funds, and a desire for perfect air I would totally do a DIY aftercooler.
As a bonus it looks cool.
I was under the impression that these were good as I see them alot.
I think that's a filter regulator though.
I've just got a cheapo inline filter on mine.
For good water removal for cheap what I would do is (all mounted to a wall) a cooler, a metal U pipe like jowens posted below it, then a decent water separator, maybe two.
pfun41 is offline
post #57 of 105 (permalink) Old 05-25-2015, 10:17 PM
Thread Killa
jowens1126's Avatar
Since I move around alot I havnt had a chance to build anything good yet. But I think we will be in this house at least 3 years, so I am going to build something decent once I get my compressor hooked back up.
I also have the big water can like Pfun pictured above. It works pretty good. It would work better if I mounted it after 25' of hose so the water had a chance to condense. As its hooked up now, it it almost a wasted effort.
With my blaster rig, If I run more than 15 mins or so continuous blasting, that can will fill with water, then I have to empty it. I also have a water seperator at the blaster cabinet, and it will fill up too, to quickly.
post #58 of 105 (permalink) Old 05-25-2015, 11:00 PM Thread Starter
Saltlife's Avatar
Wow I didn't realize so much could/needed to go into filtering the water out. I may have to rethink my setup. Thanks for the advice guys.
Saltlife is offline
post #59 of 105 (permalink) Old 05-26-2015, 01:17 AM
regularly tank draining, a good filter on off the tank, and an inline filter at the gun when spraying paint has always worked just fine for me.
that and 2-3 drops of oil in every tool, before every extended use.
post #60 of 105 (permalink) Old 05-26-2015, 03:18 AM
Steve83's Avatar
Back on the topic of air compressors in general... This thread makes me glad I didn't buy IR.
