3D printers are AWESOME! - Page 2 - Ford Bronco Forum
 5Likes
post #21 of 26 (permalink) Old 06-20-2016, 10:11 AM
Capbyrd's Avatar
I just got a micro 3d printer and have been fooling around with a few small prints. The printer is so cheap that its difficult to get a great print. It also doesn't have the resolution that I'd like. So I'm likely going to be upgrading. Your projects are coming out great and I hope to be able to do stuff like this for myself in the future.
Couple of notes to Hillbilly Heaven. Printing takes place at well over 200 degrees. doubt anything is going to melt in the summer heat. As for big pieces and seams, if he is printing in ABS, acetone will dissolve it. You can use abs chunks in acetone to form a paste that acts as a glue. The abs chunks in the solution are the same material so the acetone left in it will "melt" the two pieces while the chunks fills the gap and leave an almost seamless piece. Its also just as strong as the rest of the print since its the same material. You can also use acetone vapor to smooth print lines. Its a bit of an art but basically just cover the piece while it rests over acetone. Check it every so often and the outermost layers will start to melt or smooth. You can then clean it up with really fine sand paper and have a great finished piece.
Hillbilly Heaven likes this.
94 Bronco XLT - 5.0/E4OD
Capbyrd is offline
post #22 of 26 (permalink) Old 06-29-2016, 10:38 PM Thread Starter
AFBronco235's Avatar
Bronco Info: 91 Bronco w/ 5.0 L V8, Auto w/ E40D
Just wanted to show off my latest print. This one had to be made in 4 pieces and then screwed together. It came out PERFECT! I was afraid it might be too tall or that the pieces would warm and the holes wouldn't line up. Have to say, I LIKE this piece. Now I can finish rewiring all my aux lights and switches how I really wanted them all along. The sunglasses fit perfectly and the switches line up just how I wanted them to.
ID:	83657   Click image for larger version
Capbyrd likes this.
1991 Bronco w/ 5.0L V8, Auto w/ E40D trans, factory spare tire rack, factory limited slip diff, dual batteries, custom air intake, 8K lb. winch, tactical seat covers, drop down TV w/ CD/DVD player, 31's on stock suspension, roof baskets, new injectors, rear bumper w/ tire rack, 33" Goodyear Wranglers, 2" suspension lift.
To Do List: paint,
My BKO build: Project Farmhand
AFBronco235 is offline
post #23 of 26 (permalink) Old 07-12-2016, 03:44 PM
imdabes
votum's Avatar
Bronco Info: 1996 XLT 5.8, 35s no lift
Awesome man!
I've got an LSL in my office...but unclear if I can use it yet. It ain't cheap to run, and I haven't been here long enough to ask haha
votum is offline
post #24 of 26 (permalink) Old 01-20-2017, 08:36 PM
ThomasStemmle's Avatar
Bronco Info: 1996 302 V8 Auto Eddie Bauer
i have a 3d printer. i can probably make the same stuff you have been getting printed; probably cheaper. If i can help you out, let me know
ThomasStemmle is offline
post #25 of 26 (permalink) Old 01-20-2017, 09:55 PM
Thread Killa
jowens1126's Avatar
I would love to play with a 3d Printer. Ive been looking at this carbon fiber 3d printer.
https://markforged.com/onyx-series/#onyx-pro
Still a bit expensive for my needs though at $3500.
But they are cool. I design stuff all the time and it would be nice to be able to 3d print them.
and heres a good article on 3d printing with steel.
3D printing with metal: The final frontier of additive manufacturing - ExtremeTech
it 3d prints with dry metal powder, which you then heat up to solidify it, then further heat process it till its solid. pretty cool stuff.
jowens1126 is offline
post #26 of 26 (permalink) Old 01-20-2017, 10:11 PM
Hillbilly Heaven's Avatar
Bronco Info: 1979 Bronco
For someone wanting to get into 3D for the first time, this one is highly rated and lots of mods you can do later on. At less than a grand has great features.
Prusa3D ? 3D Printers from Josef Pr??a
Hillbilly Heaven is offline
