So HF has this advertised, a $600, 9k winch for $400 (actually my flyer says I can get it for $350)!! :
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search
Now go open up the spec sheet.
No HP for the motor, no spec on gearing, no pull by line like ALL other winches that are decent, no amp draw even (a less efficiently designed motor can draw a ton of amps). Only a little graph that shows if you pull with it on a flat surface, with vehicle able to roll, it will pull 9k (cool, I can also push 9k on a flat surface I imagine). If this changes by 20*,still assuming rolling surface, pull drops to 3k. There is no other way to compare it to a known winch, I would be very careful with considering buying a winch such as this.
