Custom F/R bumper pics 80-96 - Page 5 - Ford Bronco Forum
post #81 of 110 (permalink) Old 11-18-2012, 10:57 AM
bwg96bronco's Avatar
Bronco Info: 96 351 4" lift, 4.10s, eaton elocker in rear, nic naks here and there
here is mine, going to get it bedlined at a local truck accessory store
bwg96bronco is offline
post #82 of 110 (permalink) Old 12-01-2012, 11:08 AM
here are some pics after bedliner. the license plate lights are LEDs in the bolts
post #83 of 110 (permalink) Old 03-02-2013, 08:31 PM
adm678's Avatar
Bronco Info: 90 Bronco 5.0 AOD 33 X 12.50 4" Rancho lift
This was supposed to be my first project with Bronk. Two engines, a transmission rebuild, 4" Rancho lift and new tires later, first project completed. Built, not bought and very proud of that.
adm678 is offline
post #84 of 110 (permalink) Old 03-03-2013, 12:03 PM
adm678's Avatar
Thanks for the complements. Special thanks to Dawgfan and triplesix for all their posts. If not for them I might have built something out of square tube. Good eye on the GM tow hook junk yard find. The bumper is made of 1/4" flat plate and 1 3/4" .120 wall tube. There is nothing running out to the end of the tubes near the tires. I used a piece of 1/4" to triangulate near the winch. I know it could be stronger if I did something different but it feels pretty stout as it is now. I only do easy trail rides and play in the mud. If I get more ambitious I might add to it. Kind of concerned about protecting the fairlead but I've seen several others that lead with it. My hoop does project out further and will hopefully take any initial blow.
adm678 is offline
post #85 of 110 (permalink) Old 03-03-2013, 12:33 PM
Pushrod91's Avatar
Bronco Info: 93 Lifted on 35s. 351/auto.
Heres the start of my rear bumper...
Pushrod91 is offline
post #86 of 110 (permalink) Old 03-03-2013, 03:40 PM
drinkbrew's Avatar
Bronco Info: 96 XLT, 5.8
I did my rear bumper a couple years ago, there are still a few thing I want to change/add but here is how it is so far. I mostly put it on hold until I resolve my smog issues, since it does no good to have a bumper if I can't drive the truck . It's a pretty simple 2" square tubing bumper with 1/2" plate for the mounts/shackle points. I made the bumper mounts so they went all the way through the bumper so the mounts and shackle points are one solid piece. I went with square tubing since I don't have a bender and it was easier to work with only having a chop saw and welder, plus I wanted something a bit different.
The first time I took it out before adding the sides rails and painting.
Added the side rails and painted with bedliner. The bedliner makes it easy to touch up when I scrape it up. I still want to brace the front part of the side rails to the frame, but that will come later.
Picked up some shackles in 2011 when I was at TDS.
I also need to finish mounting the plate lights and the trailer plug
drinkbrew is offline
post #87 of 110 (permalink) Old 03-03-2013, 06:54 PM
drinkbrew's Avatar
That square tubing is a LOT stronger than most round-tube bumpers. But why butcher the fenders if the hitch is staying a foot below the bumper?
My body trimming might not be the cleanest, but I trimmed the fenders for a couple reasons.
-I wanted the top of the bumper to be about the same height as the stock bumper.
-The part of the fenders I cut off were already somewhat damaged form hitting them on rocks. Also why I added the side rails.
-I also wanted the extra clearance behind the tires, since that is where my stock bumper and fenders always got hung up coming off rocks or ledges. Like many people the horns were bent back from catching.
The hitch is only lower then the bumper in the middle. Not that I haven't drug the receiver through the dirt once or twice , but I like how the main part of the hitch actually protects the gas tank quite a bit. Someday the receiver may get integrated into the bumper or even through the top of the crossbar it's mounted on now, but for now it works fine.
my tweaked stock bumper
post #88 of 110 (permalink) Old 03-03-2013, 08:42 PM
Pushrod91's Avatar
More... Not done. Not as fancy as others but it'll work for me. Need a couple more strength braces...
post #89 of 110 (permalink) Old 05-22-2013, 04:16 PM
slawnugget's Avatar
Bronco Info: 1991 silver anniversary with a body lift
heres mine, built buy a guy i found on craigslist.
slawnugget is offline
post #90 of 110 (permalink) Old 10-11-2013, 04:48 AM
Thanks 351w500
LarryP's Avatar
Bringing this to the top for you all. Also please notice there is no chit chat going on here.
LarryP is offline
post #91 of 110 (permalink) Old 10-19-2013, 07:30 PM
OBS Brody's Avatar
Bronco Info: 1996 xl auto 4x4, 4"lift, 33" Duratracs, LEDs!!!
here is my front one...which was ripped off of the truck today wheeling. I got pulled out one too many times today. And I broke my windshield on my way out, catching air.
and my rear. all of which I built myself. front cost me about 75 to build and my rear cost about 85. including the d rings and the clevis'
Then there's "us"... We wheel, we speed, we do burnouts.
OBS Brody is offline
post #92 of 110 (permalink) Old 11-26-2013, 01:40 PM
The Doc
Dr.Dirty's Avatar
Bronco Info: 07 Jeep Rubicon 4dr
Dr.Dirty is offline
post #93 of 110 (permalink) Old 12-30-2013, 10:58 AM
going to get bedlined like i did the rear one
post #94 of 110 (permalink) Old 01-04-2014, 10:54 PM
Pyledriver's Avatar
Bronco Info: 1996 Ford Bronco XLT, 4" BDS, 33" Toyo MT, Edelbrock Intakes, E303 Cam, Bassani Full System, 4.10
Front
Pyledriver is offline
post #95 of 110 (permalink) Old 01-06-2014, 02:47 PM
Elliott000's Avatar
Progress report, going to drill my holes in the 1 1/4 at work, cap all the openings and paint er up. Super happy with my first bumper. Idea thanks to this Rear bumper build, changed a few things to personal preference
Elliott000 is online now
post #96 of 110 (permalink) Old 01-08-2014, 12:24 AM
BeastfaB
triplesix's Avatar
Bronco Info: 89 Bronco, mass air 351, Coil D60 SAS with Cage arms, 14 bolt rear
triplesix is offline
post #97 of 110 (permalink) Old 01-08-2014, 05:13 PM
Elliott000's Avatar
Finished product
post #98 of 110 (permalink) Old 01-16-2014, 10:27 AM
Tokeage91's Avatar
Bronco Info: 1991 5.0 auto stock (for now)
Originally Posted by bigbroncojeff View Post
i call this my "super custom 8" c-channel removable winch mount with 2 tow hooks with an sb-175 power connector on an aluminum bracket" bumper
and i fastened everything down with 5/8" grade 8s which is quite a bit more than what warn uses to secure it's winche to mounting plates(4 smaller grade 5s) so i think i'm good to go... that and i sprayed it with some of the dark grey hammered paint... approach angles can't get any better with out more lift/tire
click for larger images
This bumper is sick!! Great idea and looks killer. Less is more!
Gonna do something similar in the back. Mount a plate or c-channel under the 2 rear frame rails and mount a class 3 reciever above. Will post pics when done.
91 Bronco/ 5.0 from a 96 F150/E4OD/OpenTTB/Open 8.8. 163k.
Tokeage91 is offline
post #99 of 110 (permalink) Old 01-18-2014, 01:11 PM
BeastfaB
triplesix's Avatar
Originally Posted by Yzwilly View Post
2" or thicker?
I use mostly 1 3/4".
post #100 of 110 (permalink) Old 01-19-2014, 10:41 AM
The Doc
Dr.Dirty's Avatar
Same here. 1.75 x .120 works out pretty well
Dr.Dirty is offline
