here's my ride in progress! - Page 25 - Ford Bronco Forum
 5Likes
post #481 of 482 (permalink) Old 03-05-2016, 04:09 PM
Bronco Info: 1995 Eddie Bauer Edition, 5.8L, Manual Hubs
Originally Posted by yogib View Post
Oh ya. It,s a beast. But totally unhappy with FAST Ez-efi . And I emailed them with my complaints and no return email.until or if they help me out. im down on fast stuff. Well a update on this issue. FAST wasn't any help at all. But after searching the forums I figured out the problem on my own. I need to purchase FAST,s updated controller (color screen with more features) that has Cold start adjustment. Due to my larger cam and lower vacume numbers the stock ez-efi system cant read at idle correctly. So 300 bucks later I will be able to adjust cold start and other stuff too. Not cool. But better than buying a whole new system.I am really tired of changing fouled plugs and this thing idling like crap till warm. This should finally solve the issue.There 2.0 version was,nt out yet and of course it has the features I needed to run properly. :/ grrrr.
Any updates? How is that EFI system working now? Awesome build!
JT1911 is offline
post #482 of 482 (permalink) Old 06-08-2016, 09:29 PM Thread Starter
yogib's Avatar
Well Im going to have to get a new computer of my own soon. I still cant post pics yet till I do. Updates since the magazine shoot. 1.and 2. I with my friend kevin welded on new caliper brackets. (the ruff stuff ones) so I could install the large 77 chevy 3/4 ton front calipers out back. Also using the 79 ford f-150 front rotors out back. (slip on over the axle studs) .3. Installed new ten factory stronger axles. 4. added a spider trax rear fill plug. 5. new larger 1 1/4" bore 3/4 ton ford master cylinder. 6. proporting valve for rear brakes. 7. Installed king 2.5" x 4" travel bumps in back. And the bump pads on the axle. 8.Installed a new Borgensen steering shaft.9. installed new FITech meanstreet efi. She,s running great. Next will be steering upgrades.Ditch some ball joints for heims and build stronger arms. Sorry no pics. when I can. Oh wired for roof light bar that I have. Waiting for my own custom made brackets to get back from powder coat to install it.
yogib is offline
