100+mph - Page 2 - Ford Bronco Forum
 24Likes
post #21 of 42 (permalink) Old 08-16-2016, 11:01 AM
Mountain dewd's Avatar
My '73 was still pulling like hell when I let up.
BigBlue 94 and 445 FE Bronco like this.
Do NOT tread on me.
Mountain dewd is offline
post #22 of 42 (permalink) Old 08-21-2016, 03:06 AM
I did all for the Nookie
huggyb1972's Avatar
Ran a guy down in a Z71 Chevy who seamed to be laughing at my Bronco on the way to Badlands offroad park I let out of it at 113 mph. I then proceeded to wheel all day and drive back home later that evening. I always loved that feeling you have when your Bronco makes a 180 mile round trip, wheels for 8hrs, and is sitting safe and sound in the driveway.
FOTM DEC. 2011
huggyb1972 is offline
post #23 of 42 (permalink) Old 08-21-2016, 09:40 PM
trustyrusty's Avatar
not sure exactly how fast I have had mine but it will put the speedo back at zero and still pull ,the tach was reading pretty high and it sounded like a screaming banshee
anyone know how fast 0 is the second time around in a 78?
trustyrusty is offline
post #24 of 42 (permalink) Old 08-22-2016, 12:22 AM
Probably 120 or so
Do NOT tread on me.
post #25 of 42 (permalink) Old 08-22-2016, 02:41 AM
Harley's & Bronco's FTW!
I've seen 'em bounce. didn't think they could go round.
BikerPepe` is offline
post #26 of 42 (permalink) Old 08-22-2016, 05:55 PM
Had my 68 FE F250 over 130 with four wheel drum brakes, yes I am stupid and insane but I was laughing my ass off at the 93 corvette behind me. Bet he took it back to the dealer and said something is wrong with my car.
tsoptich and sniperbull like this.
post #27 of 42 (permalink) Old 11-11-2016, 07:52 PM
Bronco Info: 94 F150 8ft 4x4 4.9L, E4OD
All I'm gonna say is that I've done 2500rpm in 4th with an E4OD and 3.08s...
That sounds like something I'd do. I bet his answer was "the driver needs to grow a pair"
'94 F150, 4.9L, lunchbox locker, extended RAs, 66" leafs, manual steering
...................____ ___
_________ ||__,\\___\\,_____
|]__/---\__||__ ||/---\_[-\==/-]
_ __(o))-0---))_ _(o))-----o))______________
arse-sidewards is offline
post #28 of 42 (permalink) Old 11-11-2016, 11:13 PM
pakmule87's Avatar
Bronco Info: 1992 Eddie Bauer, 302 currently with E4OD, 265/75r15
Originally Posted by x-ring View Post
Not a chance.
I've had my Z to 150, but hold the Bronco to 70 or 75. It feels right there.
My dad had his 280z up to about 130 once back in the day (long before I was ever in the picture) and he says the road starts getting a little narrow at that point
For my Bronco though, I have snuck up to 85, but that was tires that needed to be rebalanced (they came straight off my wrecked 90 without it), and they need to be redone yet again thanks to when I put the 2 newer ones on some idiot making me lock my brakes up from about 15 mph, and then recently from 50-55, with not any noticeable help for rear ABS...seat belts are more fun when you don't have the shock of a wreck. Would also usually cruise at 80 heading up the interstate heading to a friends, until recently when noticing my transmission does indeed start to noticeably overheat when you step over 70. And 85 seems to be about my current top speed, even did it once in a Mazda B2200, didn't realize it since the speedo got stuck at around 70 until I hit the dash after realizing something didn't seem quite right
Remember with your tailgate windows not working...Clean your plug first!
!992 Eddie Bauer, 302 w/E4OD
So far...
Former 1990 302 XLT swapped T18
pakmule87 is offline
post #29 of 42 (permalink) Old 11-14-2016, 12:34 AM
Bronco Info: 1987 / 5.0 / C6 / Bone Stock
I guess so. While I have a 280 (and a 260 and a 240) I wouldn't want to try to get one over 120 or so. They wander at high speed unless they have been lowered and have a good aftermarket front air dam / splitter.
The one I had to 150 was a 370, electronically limited to that speed.
x-ring is offline
post #30 of 42 (permalink) Old 11-17-2016, 03:59 PM
1985 Bronco's Avatar
Bronco Info: 1995 C150 Centurion 4 Door Bronco, 351, E4OD, 4x4
Had my 1985 that had a 3 inch lift and on 35s up to 110 MPH a few times, I still had more power, but I was scared to go any faster. It had a 500ish hp 460 swapped into it by the PO.
445 FE Bronco likes this.
1995 C150 4 Door Bronco: 351, E4OD, 4x4, Bullnose conversion in progress
Build Thread: http://www.fullsizebronco.com/forum/...ld-thread.html
1985 Bronco: Sold
1985 Bronco is offline
post #31 of 42 (permalink) Old 11-19-2016, 12:24 AM
Age. Fac ut gaudeam
Andrew James's Avatar
Regularly when I was a teenager, then I discovered crotch rockets and so I rarely go past 65mph in my trucks. 190 so far on my Z1K
2008 Jeep Liberty 3.7/42r
Andrew James is offline
post #32 of 42 (permalink) Old 11-22-2016, 04:50 PM
Nothing beets a Fullsize
Kingfish999's Avatar
my current 96 351w (even tho its now a 425w) is limited to 95mph due to a speed limiter in the factory tune. my previous 96 302 was limited to 105. anybody who claims thier 96 can go faster with a stock truck is BS. however now that i found this limiter with my tuner and can disable it, i should be able to well exceed this.
Kingfish999 is online now
post #33 of 42 (permalink) Old 11-22-2016, 07:13 PM
Thread Killa
jowens1126's Avatar
I took the wifes challenger up to 150 last night. I would hate to go that fast in a bronco.
jowens1126 is online now
post #34 of 42 (permalink) Old 12-17-2016, 11:26 AM
Bronco Fan78's Avatar
Bronco Info: 78 Bronco Custom 400m project stalled and 96 Bronco XLT
With 38's and stock gears I automatically lock out overdrive immediately upon shifting into gear in the 96. That being said it actually starts to feel right on the highway at about 70-80ish. My 2011 F-150 with a 5.0, That thing will hit 100 coming down an on ramp if I don't watch it.
96 Bronco XLT 5.8L w/ Bassani headers, Y pipe, full stainless 3" exhaust, 6" lift, 3" body lift, 38" Toyo MT's on 16" Mickey Thompson wheels, and 78 Bronco Custom 400M that needs a lot of work
Bronco Fan78 is offline
post #35 of 42 (permalink) Old 12-17-2016, 07:24 PM
It's kinda funny but if you give it enough room my dads Duramax Diesel has no limiter, I rode up the ass of a dude on a crotch rocket doing way over 130.he was straddling lanes in a construction zone and almost got squished between a car and a wall, then between me and a semi. By this time I am pissed, I passed him up on an off ramp about twenty miles later after he tried to loose me in the corners. Then he discovereda 4/4 with ABS stops a whole lot faster than a fat chick and a crack head on a bike LOL. He dumped it and I drove away, guess he should have gotten a bigger bike.
YatriSA likes this.
post #36 of 42 (permalink) Old 12-22-2016, 01:07 PM
Foolsize Member
92BroncoXLT's Avatar
I've got no desire to go that fast in older american trucks, thats why I bought a BMW
1992 XLT 300/M5OD
1978 Custom 351M/C6
1991 XLT 351W/Blown Up E4OD
1988 Custom 302/AOD
92BroncoXLT is offline
post #37 of 42 (permalink) Old 01-11-2017, 08:32 PM
Bronco Info: 1995 XLT. Ghetto K&N setup. That's all for now. Also have a 1980 in the garage in pieces.
Originally Posted by YatriSA View Post
Anyone ever taken their bronco into this fun/dangerous place? I have taken my bronco up to 103mph confirmed by gpsv and I think i pushed that a little yesterday on my way down from Gainesville.
Down a STEEP hill.
YatriSA likes this.
shustring is offline
post #38 of 42 (permalink) Old 04-09-2017, 12:58 AM
Bronco Info: 1988 Bronco XLT 351W Still stock for now
I had 2 motorcycles 100+ and 3 Peterbilts grossed out at 79,000+ the speedo needle pointing straight down so 100+
Don't know that I would push a large car that fast again, who can afford the tickets?
Some Gave All, All Gave Some Thank the families of those that gave all. Thank those that gave some GO ARMY 43rd Engineer Btln Fort Benning Ga. Jesus died on the cross because of sin, He stayed on the cross for His Love for all sinners
amfmtxca is offline
post #39 of 42 (permalink) Old 04-09-2017, 09:31 PM
B.U.F.F.'s Avatar
Bronco Info: 74 bronco, 78 xlt ranger
I've had both a 70 eb and my 78 over 100 mph. Back when I was in my 20's and thought I was invincible. Would I do it again. NO! 70 is plenty fast enough in these things
Hagan likes this.
78 bronco xlt ranger 351m .030 over
4 wheel disc with hydro boost
4" Lift (deaver coils and 11 pack leaves)
Tru-trac rear, trac-loc front
6-way adjustable seats, power windows, custom interior
B.U.F.F. is offline
post #40 of 42 (permalink) Old 04-10-2017, 05:00 PM
Bronco Info: 90 w/a 95 roller 351 auto, E40d, manual 1356, Warn hubs, skyjacker kit, fully locked
Mine gets pretty sketchy at around 80. These things have pretty bad vibes for being such short wheelbased rigs. I don't get it.
michael.pennock.79 is offline
