Steering Links with Extended TTB Beams - Ford Bronco Forum
post #1 of 2 (permalink) Old 09-15-2016, 04:15 PM Thread Starter
panabax's Avatar
I currently run a set of C&T beams on ProComp 4" coils with Deaver J40s and extended shackles in the back, 35" tires. The C&T on my beams was done at the lower ball joint. They are OK, but not great. I think my ball joints need replacing and I suspect the C&T is wearing them faster than is acceptable to me. Rather than just get in the habit of replacing ball joints annually (which is a total PITA), I am thinking about a new set of beams.
I have a spare set of beams and have been considering (for a long time) doing a more sophisticated C&T on them, by cutting and rotating the beam and clocking the 3rd member rather than just kicking out the lower ball joint. However, I also experience tire rubbing on my extended radius arms. It's no big deal, but it is annoying. Accordingly, I have also been considering a slight extension of the beams as well, probably 2" on each side, mostly for clearance.
Here's the question. On an extended TTB, what are people using for steering links? Will the stock center and drag links still work or will they be too short for 2" wider beams? I have searched but have not stumbled across the answer to this question. I suspect most folks going to the trouble and expense of putting in extended beams probably put in custom steering links as well. If I have to go that route, I may not extend them at all and just live with the occasional rubbing (it's not like I'm not used to it by now). Anyway, I am thinking about breaking out the band saw and tig welder this weekend so I'm all ears.
Thanks,
Baxter
My family came to this country from Texas!
panabax is offline
post #2 of 2 (permalink) Old 09-22-2016, 01:10 AM Thread Starter
panabax's Avatar
So I am going to answer my own question after several days of research. It seems that if the stock steering links are too short but you want to remain stock (or HD stock) then the solution is to extend and sleeve the connecting link so you can still swap in parts store suspension parts. Of course, many just fab up custom steering systems but the point of this question was related to stock components.
Baxter
panabax is offline
