rossisnow-rebuilding a 78 Custom - Page 2 - Ford Bronco Forum
 7Likes
post #21 of 379 (permalink) Old 01-23-2012, 04:13 PM
Bronco Info: 1978 Bronco 1978 F150 1985 Bronco
I hear that. If mama aint happy, aint nobody happy.
78 Bronco Dana 44 Front, Dana 70 Rear, 4.56 gears, 6 inch lift,351M C6, 205
85 Bronco XLT 351w C6 9"rearend 32s
rolnthunder is offline
post #22 of 379 (permalink) Old 01-27-2012, 02:34 PM
Bronco Info: 1991 EB 5.8l E4OD manual 1356 lifted manual hubs sittin on 35's custom exhaust no smog still passes
good luck on the build. shop around for a shop to send your motor to. i just got mine back from the rebuild shop and the end total was 1226.16. this was for a long block that included new cam, crank, lifters, pushrods, pistons, and having the heads rebuilt.
not a bad price i'd say. the two week wait was more than worth what i got for that price.
if you can i would recomend having a couple puzzle boxes for bolts. they work great since you can just poke a hole and stick the bolt in and label it.
i say this because im doing a very similar thing to what you doing and in the rebuilding process it is amazing how easy it is to loose track of which bolt goes where.
brunus is offline
post #23 of 379 (permalink) Old 01-28-2012, 06:21 PM
Thats a beautiful 78. My first vehicle was a 78 that was a candian built bronc got myself in alot of trouble with the old brown terd some 18 yrs ago. lol
ready to ride
rocktoy78 is offline
post #24 of 379 (permalink) Old 02-02-2012, 12:04 PM Thread Starter
rossisnow's Avatar
Bronco Info: 1978 Custom, 35" Toyo Open Country, 3"/4" Superlift, C6-mild shift kit, Fresh 400
These heater core outlets almost gone.
Hoping to get the hoist and stand over to the shop this weekend.
Hopefully I will get it out without much trouble.
Superbowl is getting in the way, but I hate both those teams anyway. Should throw a party and trick someone into helping me!
It is pretty easy to get out with the clip off I imagine. Any thing I should be aware of?
rossisnow is offline
post #25 of 379 (permalink) Old 02-06-2012, 03:32 PM Thread Starter
rossisnow's Avatar
Not a bad price at all. Was it all pretty stock? Federal Mogul or what? Still putting my package together.
I have been using the old "ziplock and label" trick for my bolts, but my garage looks like a drug bust!
post #26 of 379 (permalink) Old 02-13-2012, 07:29 PM Thread Starter
rossisnow's Avatar
FINALLY
Got it out!
A little greasy.
Sludge.
Sludger...
Random bit o FOD....
Now for the fun stuff!
post #27 of 379 (permalink) Old 02-16-2012, 11:31 PM Thread Starter
rossisnow's Avatar
Three wishes:
1. I had an engine stand.
2.I had air tools
3.That I knew what the heck I am doing.
Oh well, hasnt stopped me yet.
post #28 of 379 (permalink) Old 02-17-2012, 12:22 AM
Toms78's Avatar
Bronco Info: 1978 Ranger XLT. Half Cab, 472CI, 4.56's.
Nice!
Good luck on the project and keep the pic's coming!
Tom
Toms78 is offline
post #29 of 379 (permalink) Old 02-17-2012, 12:43 AM Thread Starter
rossisnow's Avatar
Thanks Tom! Your 78 is the datum as far as I am concerned. Very nice.
post #30 of 379 (permalink) Old 03-04-2012, 08:38 PM
Bronco Info: 78 Bronco 2wd Cummins
Nice looking Bronco, looks a lil bit like mine!
If It Feels Good **** It!
cummin in my bronco is offline
post #31 of 379 (permalink) Old 03-05-2012, 11:57 AM Thread Starter
rossisnow's Avatar
Finally got the engine stand over.
Good lord that intake is heavy.....
DT7E-A2B.....70's truck, 77, bronco- (what is A2B again?)
Appears to be the same type of FOD I found under the valve cover....
Wonder what it was?
Ok, so I am not sure how to do much more. I dont have the cylinder honing thing that removes the lip from the top of the cylinder so you can get the pistons out. I dont have a pulley puller thing for the waterpump, and other pulley. I dont have the valve spring compressor....Cant seem to get the flywheel bolts loosened up. Think I am going to have to ask for some help now.
post #32 of 379 (permalink) Old 03-05-2012, 12:42 PM
raleigh's Avatar
Those shavings look like bearing to me.
You don't need a puller for the water pump, just the power steering.
Undo the 4 bolts and it will come off, it will be tight, but it is not pressed on.
The harmonic balancer on the other hand is pressed on and you will need a puller for that.
Valve spring compressors are not very expensive, and you can get one from Vatozone on the loan a tool program.
Easiest way to get the flywheel bolts off is with an impact, otherwise you have to prevent the crank from turning some how.
Dave
raleigh is offline
post #33 of 379 (permalink) Old 03-05-2012, 01:54 PM Thread Starter
rossisnow's Avatar
Thanks, wasn't sure about the water pump. Seems like it is trapped behind the main pulley anyway. I tried the breaker bar on the fly wheel, but like you said, it is hard to keep the rest of it from moving. Gonna have to borrow some air tools i think.
post #34 of 379 (permalink) Old 03-05-2012, 02:03 PM
raleigh's Avatar
Oh yeah, the crank pulley has 4 bolts that hold it to the balancer, that will come right off too, then pull the balancer.
Dave
raleigh is offline
post #35 of 379 (permalink) Old 03-05-2012, 05:51 PM
ScottTX's Avatar
Bronco Info: Stock '79 XLT 400
Those shavings look exactly like what I found...I still have no clue what they are from. I changed all my bearings (except cam) and wasn't able to figure it out. Let me know if you do.
ScottTX is offline
post #36 of 379 (permalink) Old 03-05-2012, 06:16 PM Thread Starter
rossisnow's Avatar
Left over bits from the last Chevy it ate....should have flossed.
post #37 of 379 (permalink) Old 03-05-2012, 07:44 PM
norfolkff05's Avatar
Bronco Info: 1985 EB current 1-ton sas and diesel/zf5 swap in progress
Originally Posted by rossisnow View Post
Three wishes:
2.I had air tools
i'm right there with ya bro! i am having the hardest time spending almost $200 for the 1500lb stand i need for my 7.3, it's gonna hurt to pull the trigger on that one. air tools? what are they?
norfolkff05 is offline
post #38 of 379 (permalink) Old 03-05-2012, 08:06 PM Thread Starter
rossisnow's Avatar
ha ha. I didnt work on it for a couple weeks because I didnt want to buy a $90 one.
post #39 of 379 (permalink) Old 03-05-2012, 09:41 PM
raleigh's Avatar
FYI I am doing a frame off with no air tools! haha
Breaker bars are your friend...
I paid $50 for the engine stand and $90 for the hoist on a local classified site!
Dave
raleigh is offline
post #40 of 379 (permalink) Old 03-08-2012, 07:28 PM Thread Starter
rossisnow's Avatar
If anyone wants to chime in on the "motor rebuild advice" thread I have going, here it is:
http://www.fullsizebronco.com/forum/...93#post2836793
I am just starting to post some parts......
