rossisnow-rebuilding a 78 Custom - Page 4 - Ford Bronco Forum
 7Likes
post #61 of 379 (permalink) Old 03-22-2012, 09:33 PM Thread Starter
rossisnow's Avatar
Bronco Info: 1978 Custom, 35" Toyo Open Country, 3"/4" Superlift, C6-mild shift kit, Fresh 400
Originally Posted by raleigh View Post
Those are some good numbers buddy
Break it down for me. Not sure where a 400 averages. Seems like good oil pressure though.
rossisnow is offline
post #62 of 379 (permalink) Old 03-22-2012, 10:00 PM
raleigh's Avatar
Did they break down the compression per cylinder?
My 400 is around 125-130 per cylinder, I am going to do the hone the block and replace the rings and bearings.
Dave
raleigh is offline
post #63 of 379 (permalink) Old 03-22-2012, 10:22 PM Thread Starter
rossisnow's Avatar
They only gave me the three numbers, as shown, without units. they claim all the cylinders are within %10, even though oem is %15. Have to assume that its the average from the sim test.
post #64 of 379 (permalink) Old 03-26-2012, 12:42 PM Thread Starter
rossisnow's Avatar
trans
Little bastard......
Nobody could ever figure out why the tranny would not go into first gear from the column. Guess what I found stuck in the muck between the lever and the casing!
The mean things we do to exhaust systems to pass smog
Best way to remove these buggers. Cut and pound....
post #65 of 379 (permalink) Old 03-26-2012, 01:15 PM
bigredkacy's Avatar
Bronco Info: 1978 Bronco - 460, Dana 60 Front, 14 Bolt Rear, Cage Arms, Deavers, 39.5 Irok
Looking GOOD!!!
Keep up the progress and keep the kids involved
bigredkacy is offline
post #66 of 379 (permalink) Old 03-26-2012, 06:55 PM
jamesgang's Avatar
Bronco Info: 78 BRONCO
If you use a drill bit a little larger then the sleve you can drill it out and then they will fall apart.
Jamesgang
jamesgang is offline
post #67 of 379 (permalink) Old 03-26-2012, 06:59 PM Thread Starter
rossisnow's Avatar
If you use a drill bit a little larger then the sleve you can drill it out and then they will fall apart.[/QUOTE]
Problem was that the rubber was gone, so it would just spin. Suppose I could have clamped it down Now you tell me!
post #68 of 379 (permalink) Old 03-26-2012, 07:08 PM
jamesgang's Avatar
I did the same thing you did & it sucks. A guy at the junk yard told me to use a drill bit. It would work better if the weight of the body was on them maybe.
Jamesgang
post #69 of 379 (permalink) Old 03-26-2012, 08:36 PM
Cody's Avatar
Bronco Info: 1979 Bronco, 400/c6/np205, dana 44/ 9"rear, 3.50 gears, 4" suspension lift with 35"x12.5"x15" tires
Interesting way to remove the transmission!
I just put mine back in the bronco. Let's just say it's a pain in the azz......
1979 Bronco
1979 Ford F-100
1979 Camaro
2003 ranger
Cody is offline
post #70 of 379 (permalink) Old 03-26-2012, 08:38 PM
Resurection Ranch
379sinvb's Avatar
What are you going to replace the old body mounts with?
Rick
My Projects- "Left for Dead"
Filly
379sinvb is offline
post #71 of 379 (permalink) Old 03-27-2012, 12:15 PM Thread Starter
rossisnow's Avatar
Seemed like a good idea.
The local guy is charging me $1250 to rebuild it. Can get a reman delivered for $1080. Both have a warranty. Trying to decide what to do. I dont have the time to do it myself.
I was just gonna order these from LMC.
post #72 of 379 (permalink) Old 03-27-2012, 12:52 PM Thread Starter
rossisnow's Avatar
Carb
Does anyone know if this carb will work for a CA 400? 2 barrel stock manifold with EGR. Seems like the only option. Having trouble finding reman CA emmisions carb.
Update 03/28/12: Never mind. Bought it because I cant find anything else.
post #73 of 379 (permalink) Old 04-01-2012, 10:59 PM Thread Starter
rossisnow's Avatar
The rebuilt C6.
Started pulling the heatercore/rat and leaf trap....
I wondered where my daughters "shopping lists" were going.
This came out the first few shakes.
Looks like vinyl flooring or something wedged in there?
Compost.
Here is everything.
The previous owner installed KC lights. Almost caught it on fire.
I made a new plexiglass cover for this.
trying to remove the patina from the contacts on here with a file. Changed the bulbs. Hoping for a better night display.
Rust proofed the fender aprons, frame, and radiator core support. Trim black on the fender aprons, and core support.
I am going to leave the frame as is with the clear rust stopper, paint the firewall and call it a day.
What is with these fans blades? 7 off kilter blades? WTF?
Drilled a hole in the pedal linkage arm and installed a clip. Was held by bailing wire before.
To match the motor. I will be putting a sticker on the doorjam for the actual milage.
Just keep on keeping on till your on the road!
post #74 of 379 (permalink) Old 04-10-2012, 07:07 PM Thread Starter
rossisnow's Avatar
no, I did not wrinkle paint the bolts....
When your floor jack is to short, and you are alone, you get creative….or stupid.
No cutoff on the accel pump. Should still work though. Internal maybe?
Missing the vac port on the back too? Hoping it dosnt cause any problems.
post #75 of 379 (permalink) Old 04-10-2012, 10:58 PM
Redneck Engineer
79BroncoSpringTx's Avatar
Block looks great. It's coming along nicely. Looks like you did good working by yourself. Keep at it.
79BroncoSpringTx is offline
post #76 of 379 (permalink) Old 04-11-2012, 03:33 PM Thread Starter
rossisnow's Avatar
Thanks for reading. Enjoying your thread too.
No comments for a couple weeks, I was getting lonely......
post #77 of 379 (permalink) Old 04-11-2012, 06:36 PM
Stonewater's Avatar
Bronco Info: #1: 1979 XLT Free Wheeler. #2 1979 XLT.
It's looking great! Great ingenuity getting the trans in there alone.
I'm really looking forward to getting mine to that point.
Stonewater is offline
post #78 of 379 (permalink) Old 04-11-2012, 08:29 PM
fordaholic495's Avatar
I had my instrument panel out today because I was installing some gauges, and I thought about resetting my odometer since I just rebuilt the engine. I couldn't really figure out how, so I just put it back together. Is it easier than I thought to reset it?
fordaholic495 is offline
post #79 of 379 (permalink) Old 04-12-2012, 12:26 PM
Redneck Engineer
I'd be curious to know the answer to that. Would be nice to reset mine. That away I'll know easily how many miles I put on it. I don't ever plan to sell it. Got to much invested. And will have way to much invested when I get it where i want it.
post #80 of 379 (permalink) Old 04-12-2012, 12:34 PM Thread Starter
rossisnow's Avatar
I do not recomend anyone do this to their rig. not sure about legality.
I got lucky on this one i found at the junkyard. The odometer read 996000 when I found it......if you look closely at the picture you will notice a dremel with a felt tip on it. It is true that if you stick the dremel into the speedo cable input, it turns the wrong way, and you will be there for a year at 50 mph.
The little white dial luckily has a clutch in it. I used the felt tip to roll the white wheel, trying not to go to fast, because I dont know what it is made of. It took about 5-10 min to go 4000 miles, and I had to sharpie the portion of the black numbers that wore off. I am sure someone out there knows the "proper" way to do this. Anyway, it worked for me, and I tested the OD with the drill and it still works.
