Dulaney's 82 Bronco Frame Off Rebuild - Ford Bronco Forum
 32Likes
post #1 of 670 (permalink) Old 07-21-2013, 11:07 PM Thread Starter
VOTED FOTM SEPTEMBER 2014
oubeast34's Avatar
Bronco Info: 1982, 427w, AOD, 4" Lift, 33x12.50, 4.10 gears, Detroit Locker 9", Posi-Trac Dana44 TTB, NP208
Just want to share/document my 82 Bronco Restoration. I have had this Bronco since I was 14. Now 31, I have pulled the trigger on making this Beast new again. My vision is to make the 82 look like my 2008 F250. Hope you enjoy!
Current Photo 9-27-14
oubeast34 is offline
post #2 of 670 (permalink) Old 07-22-2013, 12:13 AM Thread Starter
oubeast34's Avatar
This should be a picture of my 1982 Bronco Before I began the Restoration in March of 2013. Weak 302 HO motor with rear main seal leak, C6, 3.00 gears, open differential. Does have 4" Rancho Lift Kit up front and 4" Skyjacker leaf springs in the rear.
post #3 of 670 (permalink) Old 07-22-2013, 12:22 AM Thread Starter
oubeast34's Avatar
GT500 Fiberglass Hood from US Body Source. Will eventually be cutout and made functional. The doner Red 1985 Bronco is in the background. The Bronco now has 4.10 gears, limited slip up front and detroit locker in the rear. I am doing a Cab swap and going with the AOD transmission for overdrive. Tired of turning over 3000 rpm going 65mph.
post #4 of 670 (permalink) Old 07-22-2013, 12:26 AM Thread Starter
oubeast34's Avatar
I did go with the Mastercraft Suspension Seats and F250 center console after some research on FSB Forums.
post #5 of 670 (permalink) Old 07-22-2013, 12:28 AM Thread Starter
oubeast34's Avatar
Here is my 427 Stroker Motor from Engine Factory.
post #6 of 670 (permalink) Old 07-22-2013, 12:34 AM Thread Starter
oubeast34's Avatar
Going to do a cab swap with this 1985 Bronco I found at a salvage for $850. Going to rebuild the AOD in it. The body and floor are in amazing shape.
post #7 of 670 (permalink) Old 07-22-2013, 12:36 AM Thread Starter
oubeast34's Avatar
I went with a new tailgate, strikers, and check cables from LMC Truck. Got the diamond plate cover from JBG. I put a Softtopper on the blue bronco in the background.
post #8 of 670 (permalink) Old 07-22-2013, 12:39 AM Thread Starter
oubeast34's Avatar
Went with a tubular style rear bumper to match the front and side steps. Also, put in a 7-pin trailer plug and 6" drop hitch. So far, I like the Cooper STT 33x12.50 tires.
post #9 of 670 (permalink) Old 07-22-2013, 12:42 AM Thread Starter
oubeast34's Avatar
Taking the Broncos to a Restoration Shop in Tulsa. Last Drive of the Blue Beast 3-28-13.
post #10 of 670 (permalink) Old 07-22-2013, 12:44 AM
rhauf's Avatar
so i saw this thread.. and i was like ok, thats cool.. fixing up the old bronco.
then i saw the engine pic... came.
so what are the specs on that 427w?
-Ryan
rhauf is offline
post #11 of 670 (permalink) Old 07-22-2013, 12:45 AM
JLasvegas's Avatar
Looks like an awesome project, that engine is a beast
JLasvegas is offline
post #12 of 670 (permalink) Old 07-22-2013, 12:54 AM Thread Starter
oubeast34's Avatar
The Blue Cab been removed and bodywork has started on the Red Cab. The frame body mounts were in great shape. I upgraded to polyurethane mounts a long time ago. The gas tank is one of those plastic tanks. The original tank rusted out several years ago.
post #13 of 670 (permalink) Old 07-22-2013, 12:58 AM Thread Starter
oubeast34's Avatar
Bodywork on the Red Cab.
post #14 of 670 (permalink) Old 07-22-2013, 12:58 AM Thread Starter
oubeast34's Avatar
Poor Blue.
post #15 of 670 (permalink) Old 07-22-2013, 01:03 AM Thread Starter
oubeast34's Avatar
The cab will be sealed top and bottom then bedlined. Here is the bottom on 7-3-13.
post #16 of 670 (permalink) Old 07-22-2013, 01:05 AM Thread Starter
oubeast34's Avatar
Here is the frame all cleaned up and prepped for primer and custom Ford CX tinted bedliner. I had them drop the side steps a couple of inches and bring them out a couple of inches to make them useful. They were tucked to far up before.
post #17 of 670 (permalink) Old 07-22-2013, 01:07 AM Thread Starter
oubeast34's Avatar
The frame primered and about half way sprayed with the Ford CX colored bedliner.
post #18 of 670 (permalink) Old 07-22-2013, 01:09 AM Thread Starter
oubeast34's Avatar
Here is what she looks like as of 7-19-2013. Firewall as been bedlined and axles redone. My AOD will be completed this week and they already have my motor.
post #19 of 670 (permalink) Old 07-22-2013, 01:11 AM Thread Starter
oubeast34's Avatar
More to come.
post #20 of 670 (permalink) Old 07-22-2013, 01:17 AM Thread Starter
oubeast34's Avatar
Engine Factory liked my motor so much that it is now on there website. There is some of the information and cost at the link below. I picked every part on it and they built it, ran it, and tuned it. I was sent photos and videos throughout the build.
Checkout the video of it running on facebook.
https://www.facebook.com/video/video.php?v=543093710831
