'90 FSB Eddie Bauer "Serenity" build thread - Ford Bronco Forum
 3Likes
post #1 of 42 (permalink) Old 01-15-2014, 02:27 PM Thread Starter
PJCHANNING's Avatar
Bronco Info: 1990 Eddie bauer 302. Bought dead. Runs better n better.
Looking back, I should have started this build thread a while ago. Please be patient as I'll have to wait 'til the weekend to do a photo shoot.
*Pics coming asap*
Second new battery. New OEM alternator. Reman OEM starter. New gaskets all over top end. New Motorcraft OEM dizzy, module, cap, wires, ig. coil, switch, cylinder, rod. NGK platinum plugs. New OEM a/c clutch n coil. New OEM brake master cylinder. Rebuilt rear drum brakes. New front calipers. Hubs regularly torn down, inspected, regreased. Custom fishing pole rack. Custom cargo area table top (for sleeping). New OEM thermostat and gasket. '91 FSB headlight switch. '96 FSB 145k E4oD transmission with updated reverse gear and MLPS tsb completed. '91 F-150 bank 2 exhaust manifold. Custom 3" single chamber with flowmaster post cat. New OEM O2 sensor. TPS cleaning via FSB thread. Blue interior ambient LED lighting. Custom all season floor mats. Front bumper realigned. Headlights original but restored.Bed tent project coming soon. Side step project coming soon.
'90 Eddie Bauer 302 5.0 >250k, class E, Stock wheels (if it ain't broke...) rebuilt under hood (oem). HD rotors. R-134A conversion. Flowmaster and 3" single chamber. Custom fishing pole rack. 145k '96 e4oD upgrade. 33" BFG A/T. Modern Am/FM/Bt/CD/USB. 1500w amp/ sub combo. Custom Roof rack. Check out my build thread...http://www.fullsizebronco.com/forum/...d.php?t=281530
PJCHANNING is offline
post #2 of 42 (permalink) Old 01-16-2014, 06:55 PM
wuzz-upp's Avatar
Bronco Info: 1990 Eddie Bauer 5.0L, AOD, Stock
Another 1990, can't wait to see the pictures. Sounds like you have done a good amount already. Keep us posted with pic's of course. 3G alternator mod, consider it, it is a great mod.
1990 Eddie Bauer 5.0L, AOD, Stock, 165K
wuzz-upp is offline
post #3 of 42 (permalink) Old 01-17-2014, 08:09 PM Thread Starter
PJCHANNING's Avatar
What is this "3G" alternator mod?
post #4 of 42 (permalink) Old 01-17-2014, 09:21 PM
AFBronco235's Avatar
Bronco Info: 91 Bronco w/ 5.0 L V8, Auto w/ E40D
Its simply a better alternator. It provides more amps for charging your battery and running your electronics.
1991 Bronco w/ 5.0L V8, Auto w/ E40D trans, factory spare tire rack, factory limited slip diff, dual batteries, custom air intake, 8K lb. winch, tactical seat covers, drop down TV w/ CD/DVD player, 31's on stock suspension, roof baskets, new injectors, rear bumper w/ tire rack, 33" Goodyear Wranglers, 2" suspension lift.
To Do List: paint,
My BKO build: Project Farmhand
AFBronco235 is offline
post #5 of 42 (permalink) Old 01-18-2014, 09:18 PM Thread Starter
PJCHANNING's Avatar
Do you have a suggestion as to which "3g" alty is best for a '90 application? And by you, I mean anybody.
post #6 of 42 (permalink) Old 01-18-2014, 09:24 PM
It all depends on what you'll be doing with your build and what your power needs are. For me, I'm adding an auxiliary battery for a winch install latter on this summer. Since I'll be charging two batteries and running a winch, I'm going with a 150 amp 3G alternator.
But basically, the more electrical power you'll be using, the more amps you'll need from your alternator. Keep in mind, not all 3G alts are alike. You'll want to do some research before you sink any money into buying one. You may not even need one.
To Do List: paint,
post #7 of 42 (permalink) Old 01-18-2014, 09:24 PM Thread Starter
PJCHANNING's Avatar
Work work work.
Fought with my new bypass hose. Got it on. Re-tightened everything. Filled 'er back up with coolant. Reads normal immegitchly(immediately) and blows hot n cold like a dream. I'm sure I needa recharge my AC, oh well. No more leaky leaky.
Took pictures of the side step project and of course of my pretty new water hookups. I'll try to upload them tonight, if I'm allowed; that is if I can post pictures or if I need some special access. Cheers!
Oh, and I took pictures last night of my lights.Theyr'e not as bright as the blue light special dude but still cool.I'll try to upload this new content all at the same time. Thanks for your interest so far.
post #8 of 42 (permalink) Old 01-18-2014, 09:28 PM Thread Starter
PJCHANNING's Avatar
My gauge always seems to read high already. But, wouldn't that allow me to use a larger battery as well. Since the truck is California acclimated it doesn't like super cold or hot temperatures and the battery takes the piss when it isn't sunny and Cali out. Thoughts sir?
post #9 of 42 (permalink) Old 01-18-2014, 09:35 PM
The stock gauge isn't exactly reliable or accurate. What I would suggest is take your current alt to autozone and get it tested. They should be able to tell you how many amps its putting out. Should be around 75 if its stock. You should also get your battery tested while you're there. If you're battery isn't being reliable, it could be either a damaged cell in the battery, or the alt isn't putting out the amps you need.
To Do List: paint,
post #10 of 42 (permalink) Old 01-18-2014, 09:38 PM Thread Starter
PJCHANNING's Avatar
Battery is new, but, from AZ. Also, I have a replacement from smothers, Interstate from there, I could just take the alty and battery to them and use the "store credit on the battery to replace something else as I'm pretty sure I got the alternator there when I started restoring this machine.
post #11 of 42 (permalink) Old 01-18-2014, 09:44 PM
So alt and battery are both new? I've gotten bad alts before, so go ahead and get it tested. But if neither the battery or the alt are the problem, it could be your starter or the starter motor. In fact, go ahead and take the starter in with the alt and get it tested as well.
This is what we call "diagnosing the problem". You'll have to check over every part of the starting system before you're done. Its all part of the fun of building up your bronco. Wait till you get into the mods you want to do. Even more gremlins then.
To Do List: paint,
post #12 of 42 (permalink) Old 01-18-2014, 09:47 PM Thread Starter
PJCHANNING's Avatar
So far, so good, I've tested all of the stuff before, but it's all taken a beating since installed. I think I'm just going to replace it since I just need to find all the receipts. Thank you.
And thank you for your service.
post #13 of 42 (permalink) Old 01-18-2014, 11:52 PM
wuzz-upp's Avatar
Here is a 3G thread I posted a while back, If you search you will find several more that will provide you with the wiring diagrams, alternator potential donors, clocking the alternator for connector clearance etc..... In fact you will find the threads I used to help me.
3G alt upgrade for dummies (Like Me)
My set-up is still working like a champ! It is an awesome upgrade.
wuzz-upp is offline
post #14 of 42 (permalink) Old 01-20-2014, 03:07 PM Thread Starter
PJCHANNING's Avatar
Doing it! Thanks for the great writeup, and thanks for posting it into my build. BTW, thanks for the entertaining banter on your thread.
post #15 of 42 (permalink) Old 02-12-2014, 06:32 PM Thread Starter
PJCHANNING's Avatar
Well, I have some pictures now. Just need to upload them.
post #16 of 42 (permalink) Old 02-12-2014, 06:48 PM Thread Starter
PJCHANNING's Avatar
Pulled the trigger on a set of Rockford Fosgate 12's in a box. At some point I'll be tearing the box apart to make a new one that'll sit between the wheel wells, until then... ..I needa get an amp and wiring and prollyoughtabetter upgrade to a higher output alternator. LMC has a direct fit OEM upgrade available for pennies on the dollar. If you don't already have a catalog from LMC Truck, get one.
Oh yeah, almost forgot. I took out the cargo bed surface. It's hella heavy. Seems like I have more clearance now. I'll have to refab it with more lightweight material.
Last edited by PJCHANNING; 02-12-2014 at 06:49 PM. Reason: Almost forgot something.
post #17 of 42 (permalink) Old 02-13-2014, 06:51 PM Thread Starter
PJCHANNING's Avatar
New wipers today. New wiper motor last night. New switch and governor on their way. Re-routed vacuum lines and washer tube while I was in there last night. So much cleaner now. Oh, and I tested a worklight a vendor is trying to get me to stock at the dealership.
post #18 of 42 (permalink) Old 02-14-2014, 09:37 AM
wuzz-upp's Avatar
!Pictures please! They compliment the thread and makes it more interesting.
wuzz-upp is offline
post #19 of 42 (permalink) Old 02-14-2014, 09:49 AM
X2
jermil01 is offline
post #20 of 42 (permalink) Old 02-14-2014, 01:52 PM Thread Starter
PJCHANNING's Avatar
Yes, I know. "I'll see what I can do." - Michael Weston
