My '81 Bronco complete Frame Off Rebuild - Page 3 - Ford Bronco Forum
 17Likes
post #41 of 72 (permalink) Old 08-16-2016, 08:13 AM
johnnyk8's Avatar
Bronco Info: 1984 Rebuilt 5.0 Free Wheeling Package
Man you are doing a great job.
My bko was trashed worse than yours when I started. Seeing this makes me want reconsider not pulling the tub off and doing it like you.
Now I have a 2 post lift the next project WILL be done like this.
Again... AWESOME WORK!
Sent from my Nexus 7 using Tapatalk
1984 Full Size Ford Bronco w rebuit 302 and Auto w/OD
Lotsa Rust - Lotsa Noise - Lotsa fabricating
Project for my son and me
Here is the blog of our progress
Project Alpha Bronco
johnnyk8 is online now
post #42 of 72 (permalink) Old 08-16-2016, 09:45 AM
phobos2deimos's Avatar
Wow... That is impressive. Way to keep the truck alive!
Sent from my Nexus 6 using Tapatalk
phobos2deimos is offline
post #43 of 72 (permalink) Old 08-29-2016, 05:02 AM Thread Starter
david-09's Avatar
Bronco Info: '81 Bronco
Custom made Cap with my 3D printer to avoid that sand comes in
hey buddy, lets got to the Sandblaster
oh, what is here wrapped?! :-)
fresh blasted Frame in Paintbooth
Epoxy primer
it's hard to get new ones here in germany and shipping from US is a bit to expensive - but I think I can fix it ;-)
///'81 Bronco
My Build
david-09 is offline
post #44 of 72 (permalink) Old 08-29-2016, 05:38 AM Thread Starter
david-09's Avatar
Radiator Core Support Mount Bracket
JGR likes this.
///'81 Bronco
My Build
david-09 is offline
post #45 of 72 (permalink) Old 08-29-2016, 09:58 AM
Wow, the amount of work you are putting into that thing is impressive. When you get that thing back together this is full size of the month material.
1990 Eddie Bauer Bronco
scparrish is offline
post #46 of 72 (permalink) Old 08-29-2016, 02:49 PM Thread Starter
david-09's Avatar
Thanks! For me it's going to be the full size for life
scparrish and tylerwdavis like this.
///'81 Bronco
My Build
david-09 is offline
post #47 of 72 (permalink) Old 09-01-2016, 04:57 AM Thread Starter
david-09's Avatar
The old Coil Springs - not beautiful but nothing broken
Back from a specialized company - they made them like new, shot-blast, special primed to prevent rust and finished with black powdercoat for about 80 bucks ;-)
///'81 Bronco
My Build
david-09 is offline
post #48 of 72 (permalink) Old 09-01-2016, 02:09 PM
No1hedberg's Avatar
Bronco Info: 95 XLT 5.0
Holy cow. Where did you get that thing, The bottom of the ocean? You should get some kind of Bronco mother Theresa award for saving this one. Amazing work. Can't wait to see this one.
2015 F150 SCREW Lariat ECO
1995 Bronco XLT
1969 U15 Bronco Wagon
No1hedberg is offline
post #49 of 72 (permalink) Old 10-17-2016, 04:28 PM Thread Starter
david-09's Avatar
Next Update
Wow - The Frame is back
Rebuild the Calipers
I couldn't find these Parts to buy, so a friend made them for me ;-)
old vs new
///'81 Bronco
My Build
david-09 is offline
post #50 of 72 (permalink) Old 10-17-2016, 04:45 PM Thread Starter
david-09's Avatar
Finally some of my Parts arrived
///'81 Bronco
My Build
david-09 is offline
post #51 of 72 (permalink) Old 11-20-2016, 02:12 PM Thread Starter
david-09's Avatar
...and the next steps:
the rest of the parts arrived:
Couldn't find the right Leaf spring bolt, so made it from a normal bolt.
79BroncoSpringTx likes this.
///'81 Bronco
My Build
david-09 is offline
post #52 of 72 (permalink) Old 11-20-2016, 02:59 PM Thread Starter
david-09's Avatar
///'81 Bronco
My Build
david-09 is offline
post #53 of 72 (permalink) Old 11-20-2016, 03:06 PM Thread Starter
david-09's Avatar
///'81 Bronco
My Build
david-09 is offline
post #54 of 72 (permalink) Old 11-20-2016, 03:19 PM Thread Starter
david-09's Avatar
For torquing the Radius arm/Axle bolts with 240-340 ft-lbs i needed a bigger torque wrench and a bigger socket...
///'81 Bronco
My Build
david-09 is offline
post #55 of 72 (permalink) Old 11-20-2016, 04:09 PM
johnnyk8's Avatar
Based on seeing this work you have done so far this truck is going to be gorgeous!
Mad props to you!
Sent from my SCH-I545 using Tapatalk
huck2080 likes this.
post #56 of 72 (permalink) Old 11-21-2016, 08:03 AM Thread Starter
david-09's Avatar
@johnnyk8 thank you!
///'81 Bronco
My Build
david-09 is offline
post #57 of 72 (permalink) Old 11-21-2016, 02:08 PM
I do lot of rust repair . . your work looks great. But to me, the most impressive thing is that you are doing all of this from Germany? I know that makes it terrifically difficult.
1983 Bronco
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline
post #58 of 72 (permalink) Old 11-22-2016, 04:25 AM Thread Starter
david-09's Avatar
Thank you! Yes, it's not always easy doing this from Germany. That's why I had to made a lot of parts on my own for fixing the bad spots on the Bronco. In the states I could by most of the things. But I can see the light at the end of the tunnel
///'81 Bronco
My Build
david-09 is offline
post #59 of 72 (permalink) Old 03-03-2017, 06:23 AM Thread Starter
david-09's Avatar
Fresh Dry Ice cleaned
///'81 Bronco
My Build
david-09 is offline
post #60 of 72 (permalink) Old 03-03-2017, 06:37 AM Thread Starter
david-09's Avatar
Tested my new Powder Coating Gun:
///'81 Bronco
My Build
david-09 is offline
