Orange I'm glad build. - Page 11 - Ford Bronco Forum
 264Likes
post #201 of 207 (permalink) Old 02-24-2017, 04:10 PM Thread Starter
Finally sat down and assembled my Performer AVS Off Road 800 CFM carb today. Rejetted a little leaner by one size on the primaries and left the secondaries stock jetting. New pump, jets, rods and kit.
BikerPepe`, huck2080 and SRWillis like this.
post #202 of 207 (permalink) Old 03-09-2017, 12:18 AM Thread Starter
Worked a little on prepping my new radiator, had a new copper 4 core big tank left over from my box truck. The truck it was intended for had wider brackets which had to be trimmed and new mounting holes drilled.
post #203 of 207 (permalink) Old 03-09-2017, 12:21 AM Thread Starter
Made mounts to clear the air conditioning condenser and give it some breathing room.
post #204 of 207 (permalink) Old 03-09-2017, 12:25 AM Thread Starter
Cut the aluminum 6001 sheet for the fan, the fan I had left over from my Jeep days. It's a 16" Flexalight 2000 CFM if I remember right.
post #205 of 207 (permalink) Old 03-17-2017, 12:48 PM Thread Starter
Made up my battery + cable to run across the back side of the core support. Class M 3000 strand oil resistant jacket in 4/0 size, doing all the hot leads in orange.
post #206 of 207 (permalink) Old Today, 10:25 AM Thread Starter
Got the solenoid all set up, had to use a copper bar to fit all that big shit and two relays on there. It has one NC terminals on top for run and one NO for the starter.
Quader1 likes this.
post #207 of 207 (permalink) Old Today, 03:14 PM
Fitzy's Avatar
Bronco Info: 1996 Eddie Bauer
How much did the new radiator run you?
Fitzy is offline
