Orange I'm glad build. - Page 5 - Ford Bronco Forum
 78Likes
post #81 of 182 (permalink) Old 07-12-2016, 12:31 PM Thread Starter
I guess from here I am going to bead blast with 80 grit to remove the remainder of base paint that refuses to come off and etch the metal for paint. Should go easy now as 99% is stripped clean and no sealer or undercoat to deal with. I need to do a few floor repairs before paint also and cut the front pans out. I'll have to order the pans in a couple weeks when funds permit.
post #82 of 182 (permalink) Old 07-12-2016, 12:37 PM
Quader1's Avatar
Bronco Info: 78 W/400 in progress
Lockin good , man what a ton of work . But it n the end you'll know what you have .
445 FE Bronco likes this.
Quader1 is online now
post #83 of 182 (permalink) Old 07-24-2016, 10:49 PM Thread Starter
Back on the 78 again, rebuilding the Performer EPS off road 800 I have. Took two weeks to get the accelerator pump from Advance WTF.
post #84 of 182 (permalink) Old 07-24-2016, 11:11 PM Thread Starter
Giving it a soak in mag wheel cleaner, kinda crusty from sitting for 15 years or so.
JGR likes this.
post #85 of 182 (permalink) Old 10-31-2016, 11:24 AM Thread Starter
Going to pick her up today, that is if the GOV. actually pays me on time.
post #86 of 182 (permalink) Old 11-01-2016, 05:47 PM Thread Starter
Well made it home, needs help but OOHBOY i got some work to do.
post #87 of 182 (permalink) Old 11-01-2016, 05:51 PM Thread Starter
Needs exhaust for sure right away and one of these. I would say that ignition box's days are numbered.
post #88 of 182 (permalink) Old 11-01-2016, 05:54 PM Thread Starter
There's that pesky steering shaft, may as well do a stabilizer too.
post #89 of 182 (permalink) Old 11-04-2016, 10:30 AM Thread Starter
Replacement lines all painted and ready to go, things cleaned up pretty good after the wire wheel and aluminum paint.
post #90 of 182 (permalink) Old 11-04-2016, 10:34 AM Thread Starter
Blew the goo off everything is pretty clean dritrain wise, the driveshaft was rebuilt already and all new T/C seals on the outputs. That will save me some work and $.
post #91 of 182 (permalink) Old 11-04-2016, 10:40 AM Thread Starter
And here is why i need a new tub, the back floor does not look much better. I do not want to be chasing this for the rest of my life so i am starting with a clean Texas tub.
post #92 of 182 (permalink) Old 11-05-2016, 10:19 PM Thread Starter
Picked up new lines, hoses and master cylider today, tomarrow replumb the brake system.
post #93 of 182 (permalink) Old 11-12-2016, 05:50 PM Thread Starter
New lines installed to the rear, brake and fuel with new hoses.
post #94 of 182 (permalink) Old 11-12-2016, 05:54 PM Thread Starter
Rear axle right and left lines
post #95 of 182 (permalink) Old 11-12-2016, 05:58 PM Thread Starter
Proportion valve cleaned up painted and plumbed.
post #96 of 182 (permalink) Old 11-12-2016, 06:00 PM Thread Starter
New master and lines.
post #97 of 182 (permalink) Old 11-12-2016, 06:04 PM Thread Starter
Right outer knocked down, gonna need everything SUPRISE WTF.
post #98 of 182 (permalink) Old 11-12-2016, 06:07 PM Thread Starter
Well that stub shaft is toast on the right.
post #99 of 182 (permalink) Old 11-12-2016, 06:15 PM Thread Starter
Left side same story, buyers regret going on here.
post #100 of 182 (permalink) Old 11-12-2016, 06:18 PM Thread Starter
Super crappy backing plates, hardware and everything else.
