budget 84 i6 daily driver. Amateur hour has arrived - Page 3 - Ford Bronco Forum
 106Likes
post #41 of 145 (permalink) Old 06-18-2016, 01:25 AM
88LiftdBronco's Avatar
Bronco Info: 1988 Bronco Custom, 300 4.9L, ZF5 Manual, and the rest is under construction
Originally Posted by Decker View Post
Edited
Ok. From the sound of it, I thought you meant it was (in general) a bad idea to combo those together. Regearing is always key when going up or down in tire sizes so that was my bad in misunderstanding what you meant lol
Originally Posted by disturbio View Post
Edited
Well, it's your bronco, so it's always up to you on how to build it. There's plenty of support on here no matter what route you go, but I agree with your brother
As far as the gearing, there SHOULD be a tag on the diffs but who knows if they're even there after this long. Just seems odd to me that they'd put it on the trans.
disturbio likes this.
They're like the Chuck Norris of engines.
88LiftdBronco is offline
post #42 of 145 (permalink) Old 06-18-2016, 01:59 AM Thread Starter
disturbio's Avatar
Bronco Info: 1984 i6
I thought of that too. Who knows what's been done in 30 some years. I can say that at idle in four low I could pull a cargo ship through the sand dunes
84 i6 DD
"El Jugo"
disturbio is offline
post #43 of 145 (permalink) Old 06-18-2016, 10:04 AM
Scoop's Avatar
I don't think a tag on the tranny will indicate your diff gears. Best way to tell is to jack up the rear, turn a tire and count the turns of the pinion. You have an NP435 tranny, same as mine. I am a fan of having the lowest lift that will clear your tire size. This works best both on and off road. The size of your lift was no correlation to manhood - so tell your brother he's a poser!! (Actually, maybe there is a reverse correlation! LOL)
Scoop is offline
post #44 of 145 (permalink) Old 06-18-2016, 08:51 PM
Cobra07's Avatar
Bronco Info: 1996, 5.8L stock for now
has anyone ran a 12 inch tire on the 7 inch rim?
I currently run 33"x 12.5 duratrac wranglers on my stock rims. No problemo.
Kelly G
Cobra07 is offline
post #45 of 145 (permalink) Old 06-20-2016, 06:47 PM Thread Starter
disturbio's Avatar
Wait if you have a newer bronco i think you have a 7.5 or 8 inch rim though
84 i6 DD
"El Jugo"
post #46 of 145 (permalink) Old 06-21-2016, 12:53 AM Thread Starter
disturbio's Avatar
Do I need a smog pump hooked up. Could the rest of what's cut up just be removed? I'm thinking about having a machine shop make an adapter plate for carb and just pulling all the crap off. Like scoop said I probably have a ton of vacuum leaks as is. Has anyone done this before I mess with mine? If so how did it turn out
post #47 of 145 (permalink) Old 06-21-2016, 11:32 PM Thread Starter
disturbio's Avatar
Well I pulled it all off. I'll see if it was a mistake
post #48 of 145 (permalink) Old 06-22-2016, 03:32 AM Thread Starter
disturbio's Avatar
I got an 84 dealer brochure from eBay today. They really touted all the computer control junk I'm deleting. Pretty cool piece though
SRWillis likes this.
post #49 of 145 (permalink) Old 06-22-2016, 09:02 AM
Yeah, that is cool. I picked up one for my 81 at a Ford swap a few months ago.
SRWillis is offline
post #50 of 145 (permalink) Old 06-22-2016, 01:25 PM
mrbollero's Avatar
Bronco Info: 1979 Custom 351m
Late to the party, but this is a beautiful truck- great find. I didn't originally like the 80-86 nose at first, but since owning one for a few months I've fallen in love with it and that may be my next project after my current 78. Looking forward to seeing the progress!
Rusty Custom Build
mrbollero is offline
post #51 of 145 (permalink) Old 06-22-2016, 11:51 PM Thread Starter
disturbio's Avatar
It's all gone but the cat
84 i6 DD
"El Jugo"
post #52 of 145 (permalink) Old 06-22-2016, 11:57 PM Thread Starter
disturbio's Avatar
84 i6 DD
"El Jugo"
post #53 of 145 (permalink) Old 06-23-2016, 12:17 AM Thread Starter
disturbio's Avatar
The tag is on the diff too. There is also a plate on the block that says "awesomely....". Can't make out the second word so who knows what's on this strange truck
dash_cam likes this.
84 i6 DD
"El Jugo"
post #54 of 145 (permalink) Old 06-23-2016, 12:23 AM Thread Starter
disturbio's Avatar
Got the cheapy cover stitched up. Not bad
84 i6 DD
"El Jugo"
post #55 of 145 (permalink) Old 06-23-2016, 12:33 AM Thread Starter
disturbio's Avatar
Center console cleaned and painted and floor painted to match panels. I already had the paint so it's free. Hopefully it holds up
Very 80s. We've travelled back to 1984
captainpicard300 and dash_cam like this.
84 i6 DD
"El Jugo"
post #56 of 145 (permalink) Old 06-23-2016, 12:39 AM Thread Starter
disturbio's Avatar
Ya they are hotrod style lights not KCs or....light bars... which I hate on older stuff. I like them, already owned them and needed some lower lights
They came off this caddy . when she got stolen and stripped, It was the only thing I took before the insurance guy showed up
84 i6 DD
"El Jugo"
post #57 of 145 (permalink) Old 06-23-2016, 12:49 AM Thread Starter
disturbio's Avatar
So as soon as I can figure out how to get to it the next steps in extreme budget makeover will be fabricating a functional headliner. * Finishing up the back shitty cargo area and the cardboard insert panels on the sides. * Polishing all the plastics inside and out*. More engine bay clean up. Im hesitant to do so again because last time I sprayed it off she wouldn't start for 2 days
84 i6 DD
"El Jugo"
post #58 of 145 (permalink) Old 06-23-2016, 01:30 AM
I would just count the driveshaft to tire rotations... that's going to be the best way to tell gear ratio besides pulling the diff cover. Especially since you mentioned the block tag lol
post #59 of 145 (permalink) Old 06-23-2016, 01:39 AM
Man, that was one clean Caddy!
The engine compartment clean-up looks good. What did you make the carb spacer out of? Aluminum?
I like the steering wheel cover. I've been thinking about getting one 'cause mine's kinda nasty and they're thin too, but then forget when I'm in the parts store.
She's comin' along nicely!
SRWillis is offline
post #60 of 145 (permalink) Old 06-23-2016, 03:24 AM Thread Starter
disturbio's Avatar
I took it to Napa machine shop and they made it from an aluminum plate. It runs exactly the same and took me like 10 hours to pull everything out so.... I'm going to say it was not worth the effort. I don't know what they are going to charge for the machining cause the guy was out when I picked it up but I bet it's not cheap. I got that steering wheel cover for like 8 bucks on Amazon. Way better than my chewed up stick wheel.
Ya I loved that caddy. I way over did that car. Makes me glad all the bullnose stuff is so cheap and plentiful
84 i6 DD
"El Jugo"
