budget 84 i6 daily driver. Amateur hour has arrived - Page 4 - Ford Bronco Forum
 135Likes
post #61 of 181 (permalink) Old 06-23-2016, 10:17 AM
Scoop's Avatar
Originally Posted by disturbio View Post
It's all gone but the cat
Looks great! Cleaned it up nicely.
Scoop is offline
post #62 of 181 (permalink) Old 06-23-2016, 06:47 PM Thread Starter
disturbio's Avatar
Bronco Info: 1984 i6
needs painted still but shes getting there.
84 i6 DD
"El Jugo"
disturbio is offline
post #63 of 181 (permalink) Old 06-23-2016, 08:00 PM Thread Starter
disturbio's Avatar
Does anyone know what the dome light bulb itself is?
post #64 of 181 (permalink) Old 06-23-2016, 08:01 PM Thread Starter
disturbio's Avatar
There are no number o bulb and Google doesn't know
84 i6 DD
"El Jugo"
post #65 of 181 (permalink) Old 06-29-2016, 07:15 PM Thread Starter
disturbio's Avatar
hey there
can you look at the light in your dome light and tell me what it is?
84 i6 DD
"El Jugo"
post #66 of 181 (permalink) Old 06-29-2016, 07:16 PM Thread Starter
disturbio's Avatar
HEI Set ups...
What do i6 guys run? Need a new dist.
84 i6 DD
"El Jugo"
post #67 of 181 (permalink) Old 07-20-2016, 10:05 PM Thread Starter
disturbio's Avatar
HEI Set ups...
Let me know if anyone is running a GM style. I think that may be best bet
Got my new shoes, went from the 31 by 10.5s to 33x12.5
84 i6 DD
"El Jugo"
post #68 of 181 (permalink) Old 07-20-2016, 10:49 PM Thread Starter
disturbio's Avatar
A lot wider now... Bit pinched but I like the look and stance
84 i6 DD
"El Jugo"
post #69 of 181 (permalink) Old 07-20-2016, 10:54 PM Thread Starter
disturbio's Avatar
So next up I think is a remanufactured stock 1 barrel. The PO drilled little holes in this one and i can't get it tuned quite right.
84 i6 DD
"El Jugo"
post #70 of 181 (permalink) Old 07-21-2016, 05:52 AM
Resident Nice Guy
schwim's Avatar
Can I ask where he drilled these holes? I'm picturing some goofball drilling holes willy nilly in an effort to improve "flow".
dash_cam and disturbio like this.
schwim is offline
post #71 of 181 (permalink) Old 07-21-2016, 10:59 AM
dash_cam's Avatar
a 1-barrel just makes me chuckle. just considering that a 302 could easily make use of a 4bbl, a 1bbl seems extremely anemic.
disturbio likes this.
it's fun to do bad things
my "build" thread
dash_cam is offline
post #72 of 181 (permalink) Old 07-21-2016, 11:33 PM Thread Starter
disturbio's Avatar
I'll do you one better. Ill take pics when I switch it this weekend.
[Q
84 i6 DD
"El Jugo"
post #73 of 181 (permalink) Old 07-21-2016, 11:39 PM Thread Starter
disturbio's Avatar
True but I'm not exactly drag racing my inline and I'm doing all of this with goal of the most mpg I can squeeze out of her. Having owned a few 302s I'd say they are a solid engine but I don't need revs I need low end grunt. Plus this is an extreme budget project. The 200 on a reman is hopefully the most I ever spend on her outside of tires. If I put this same carb on her I don't have to change anything.
I won't get into a 302 vs. 300 debate, but if I were to have wanted a v8 in a bronco it wouldn't be a 5.0.
dash_cam, SRWillis and Booma like this.
84 i6 DD
"El Jugo"
post #74 of 181 (permalink) Old 07-21-2016, 11:43 PM Thread Starter
disturbio's Avatar
Its easy to keep your foot out of the secondaries when there is no secondaries
captainpicard300 and dash_cam like this.
84 i6 DD
"El Jugo"
post #75 of 181 (permalink) Old 07-21-2016, 11:47 PM Thread Starter
disturbio's Avatar
Re hatching an older idea.... Today it was 115 deg. The roof of the bronco was 132 deg. The driver floor was 113.
I found this crap at home depot that looks like Fatman but it was 16 bucks. This is going to be my headliner since I can find a single person who has home brewed their own. If it doesn't work out at that price.... I'll feel okay about it
79BroncoSpringTx and dash_cam like this.
84 i6 DD
"El Jugo"
post #76 of 181 (permalink) Old 07-22-2016, 10:10 AM
Resident Nice Guy
schwim's Avatar
Would love it if you posted the details on the install of the insulation as well as some comparison temp numbers. Would love to get rid of the "4th ring of hell" feeling of driving in the summer.
schwim is offline
post #77 of 181 (permalink) Old 07-25-2016, 01:13 AM Thread Starter
disturbio's Avatar
Well I did a before and after that I think is pretty close. It was 119 when I started, I took great stuff and took 3 of the plastic straw things that the foam comes out of, spliced it all together so I could get to the edges of the roof and filled in the gap. The temp when I started was 119 deg. The roof was 129
After I gave it an hour or so to fill up and dry, the outside temp dropped to 118. The roof temp was 122 on the inside. Safe to say that dropped 5- 6 degrees.
So still 118 outside I put three layers of the thermo king stuff on which went up easy....very sticky, easy to cut with my fiskar work scissors. Maybe 20 mins start to finish. It also didn't mind binding to the hot surface.
I immediately felts the difference. 118 outside. 105 on roof. 13 deg.
So now I gave it a bit to cool down, today 115 outside and 94 inside. 22 degree difference for 50 bucks.... Now I just gotta cover it with something aesthetically pleasing. Only bummer is the foil backing has some sort of light oil to it. I'm not sure what will stick. Open to suggestions
84 i6 DD
"El Jugo"
post #78 of 181 (permalink) Old 07-25-2016, 01:20 AM Thread Starter
disturbio's Avatar
I am going to user a foam sheet for the shell in the back. I need to suspendit in a way that it doesn't look like ass, and willhave a bit if a gap for air to be between the top and the foam. That gap is what actually gives any RValue
84 i6 DD
"El Jugo"
post #79 of 181 (permalink) Old 07-25-2016, 01:21 AM Thread Starter
disturbio's Avatar
Also worth noting, it wasn't my goal but it's far quieter in cab too
84 i6 DD
"El Jugo"
post #80 of 181 (permalink) Old 07-25-2016, 08:15 AM
Resident Nice Guy
schwim's Avatar
That's fantastic results! I appreciate you sharing the process. I know it can be a pain in the ass to snap pics in 100+ heat :)
I've been following a build thread on another forum and he's using this same material on the floor, but he's using a peel and stick foil backed roll intended for seam sealing on roofs from Lowe's first against the metal then placing the Frost King on top. It's appealing only because my feet feel like baked potatoes after rides longer than 20 minutes.
schwim is offline
