Four Door Bronco Build Thread - Page 2 - Ford Bronco Forum
 40Likes
post #21 of 63 (permalink) Old 11-09-2016, 06:12 PM
House of Windsor 4ever!
Handy_andy_cv64's Avatar
In post 3, when you said you filled the pinholes before applying the POR-15--how did you fill the pinholes? Welding, or just filled them in with something?
Handy_andy_cv64 is offline
post #22 of 63 (permalink) Old 11-09-2016, 10:45 PM Thread Starter
1985 Bronco's Avatar
Bronco Info: 1995 C150 Centurion 4 Door Bronco, 351, E4OD, 4x4
Welding, but that was before we decided to replace the passenger side wheel tub instead of patching it. Part of that area is a little thin, but I think it will be okay.
1995 C150 4 Door Bronco: 351, E4OD, 4x4, Bullnose conversion in progress
Build Thread: http://www.fullsizebronco.com/forum/...ld-thread.html
1985 Bronco: Sold
1985 Bronco is offline
post #23 of 63 (permalink) Old 11-10-2016, 07:46 PM
OK, I'll keep that in mind. Have you tried one of those metal flame spray rigs? A member on Ranchero.us says his has given him the ability to rescue thinned, pockmarked panels without having to cut and patch.
post #24 of 63 (permalink) Old 11-21-2016, 03:44 PM Thread Starter
Haven't seen those before. Interesting process
Rear floor 90% complete, just need to add a few brackets and paint the floor. The small dents in the wheel tubs will be hidden by the large boxes that go on both sides of the seat. One houses the rear heat/AC unit. The other is just storage, but I think I'm going to build a sub box into part of it.
Passenger quarter welded on
Put a small hole in the gas tank, so that was dropped. It was kinda rusty anyway.
New tank, broke the sending unit pulling it out, so I'm still waiting on one of those.
Sandblasted and painted the tailgate access panel
Adding the second fuel door to the drivers quarter panel. Tabco disappointed me again :( The whole fuel door area isn't indented as much as the factory one we are grafting in, and the finger cup area is not as defined as the factory one.
Panel got a little warped after the welding. Out comes the stud gun.
Better
Done
1985 Bronco: Sold
post #25 of 63 (permalink) Old 11-21-2016, 08:08 PM
Bronco Info: 1995 XL stock for now.
Great thread so far. Love watching the progress.
Hixster is offline
post #26 of 63 (permalink) Old 11-21-2016, 10:23 PM
Cheese5.0's Avatar
Bronco Info: 1996 Bronco Eddie Bauer
For someone that knows very little about metal and body work like myself, this thread and its pictures are very interesting. Keep up the good work.
FTA Boy likes this.
Cheese5.0 is offline
post #27 of 63 (permalink) Old 11-22-2016, 08:19 AM
Redneck Engineer
79BroncoSpringTx's Avatar
You're doing some Excellent work there. Enjoying the build!
79BroncoSpringTx is offline
post #28 of 63 (permalink) Old 11-22-2016, 11:26 PM Thread Starter
Thanks guys! Hopefully we will get this done soon. It just snowed here, and I'd like to get it in storage for the winter before they start salting the roads.
1985 Bronco: Sold
post #29 of 63 (permalink) Old 11-23-2016, 03:39 AM
I did all for the Nookie
huggyb1972's Avatar
Wow that looks fantastic I would run from a truck like that. You are one patient son of a gun.
FOTM DEC. 2011
huggyb1972 is offline
post #30 of 63 (permalink) Old 11-23-2016, 10:51 PM Thread Starter
It's my dream truck, it was pretty hard to run away from it. I searched for one of these for 3 years before I found this one close to me. I planned on changing the quarters out anyway, so the rust didn't seem like that big of a deal to me when I bought it. Centurion only built a few Bullnose 4 doors (I have seen pictures of maybe 5), and they are impossible to find now, so I knew I was going to have to build my own. This build is no where close to done. I plan on having a 1 ton frame, diesel power, and a Bullnose interior when I'm done with it, probably won't happen for a few more years though.
V8BB and mrbollero like this.
1985 Bronco: Sold
post #31 of 63 (permalink) Old 11-27-2016, 12:50 PM
mrbollero's Avatar
Bronco Info: 1979 Custom 351m
Awesome progress. Sucks that the tank doors didn't line up- I ran into some similar problems using my Tabco floor panels. Close, but not quite (and just close enough to be really frustrating).
Rusty Custom Build
mrbollero is offline
post #32 of 63 (permalink) Old 12-06-2016, 12:52 PM Thread Starter
Thanks, ran into more issues with the fuel doors, this time it was my own fault
Did a little more grinding
Seat brackets painted
Installed
Inner wheel houses installed, and extra drain holes added. Still need to paint this side with POR15. The top was painted before they were welded in.
New gas tank going in. Had some fitment issues, for some reason it didn't want to go up far enough. Got it mounted good enough to drive it home. I will have to drop it again and figure out why it doesn't fit.
Finally home!! Used 2 colors of primer to match the existing paint job.
Before and after:
We put it in storage for the winter the Sunday, and it snowed the next day, so that was good timing. Also still need to combine an 86 fuel door with the 95 one because the 86 hinge won't work in that tight space in the front, and we never mocked up the fuel door before the panels were welded in Front clip will be going on in the spring, and hopefully paint
1985 Bronco: Sold
post #33 of 63 (permalink) Old 12-06-2016, 03:16 PM
mrbollero's Avatar
Looks awesome! That is good timing- I'm sure it's nice to have all that done so that come spring you can get it out and enjoy it.
Rusty Custom Build
post #34 of 63 (permalink) Old 12-06-2016, 03:35 PM
broncoblair's Avatar
Bronco Info: 1993 Bronco XLT
Great Progress
Your build is looking great so far. Cant wait to see it progression. Love the 80-86 front clip swap
broncoblair is offline
post #35 of 63 (permalink) Old 12-06-2016, 08:13 PM
Can't tell it was ever damaged nice work
post #36 of 63 (permalink) Old 12-06-2016, 10:48 PM
trustyrusty's Avatar
wow,awesome job,doesnt look like the same rig!
trustyrusty is offline
post #37 of 63 (permalink) Old 12-07-2016, 11:16 PM Thread Starter
Originally Posted by trustyrusty View Post
Wow, awesome job, doesn't look like the same rig!
Thanks guys! I can't wait till it's done
Thanks, it's nice that it's done, but I wish I could have driven it a little more before putting it in storage
1985 Bronco: Sold
post #38 of 63 (permalink) Old 12-12-2016, 10:34 AM
Very cool rig. Good job on the resurrection.
1985 Bronco likes this.
1990 Eddie Bauer Bronco
scparrish is offline
post #39 of 63 (permalink) Old 12-12-2016, 07:15 PM
FTA Boy's Avatar
Bronco Info: 92 XLT 5.8L 6" w/ 35x12.50
Same!
Originally Posted by fartman View Post
Seriously, signature material.
Originally Posted by buckingbronco351 View Post
i know thatl get quoted but whatever.
FTA Boy is offline
post #40 of 63 (permalink) Old 01-07-2017, 08:27 PM
CrawlTunes's Avatar
Good work. Keep it up.
It took me 3 years to find a Centurion without that kind of rust or worse, that the seller wasn't asking way too much.
It's crazy the conversations these vehicles start with strangers when pumping gas "Uh...excuse me....what is that?"
mrbollero likes this.
CrawlTunes is offline
