Lifted Fords long awaited build. 96 with 460 and tons - Ford Bronco Forum
 113Likes
post #1 of 107 (permalink) Old 01-01-2017, 09:38 PM Thread Starter
Lifted Fords's Avatar
Bronco Info: 96 EB Bronco
So here it is..... MAF obII 460 swap and D60 and 10.25 swap. The SAS started in Oct 2015 and 460 swap was started in Feb 2016.
The back story, I picked the bronco up from gadawgz71 in Aug 2013 with just over 128k on it, a 6" ttb lift and 35 ats, but it was some kids off road toy before gadawgz71 picked it up. I spent a week cleaning and pressure washing and it still wasn't clean.
I then add some 37" claws.
I also added a e303 cam and changed the exhaust up some.
Then the ice storm of 2014 came. I drove it to work and it was frozen in place for 3 days. Had over an inch of ice on it. I work for a power company and didn't go home for 4 days anyway but my extra clothes were in there.
I pretty much just drove it and enjoyed having a running and driving bronco. I took it out a few times on some dirt roads but that's about it for off-roading.
More to come
JGR, 79BroncoSpringTx and CDA 455 like this.
96 EB Bronco- Efi odII MAF 460, D60, 10.25, detroit lockers, 4.88s, 38 toyos, deaver springs, psc steering.
09 civic- DD
Lifted Fords is offline
post #2 of 107 (permalink) Old 01-01-2017, 10:18 PM Thread Starter
Then in Oct of 2015 I decided to use the parts I've been gathering and saving for the last 4-5 years.
The plan was swap in my Dana 60 that was rebuild. It had Detroit locker, 4.88s, stock axles for now, Yukon flat flange, new king pins and bearings and seals, ruff stuff diff cover, sky manufacturing high steer arm, ruffstuff 7/8s heim steering with 1.5 dom, PSC hydro assist, ruffstuff track bar mount, new rotors and wheel studs, and warn hubs.
In this pic you can see I had to modify the cover to clear my steering and the ram mount.
The rear is a 10.25 with a Detroit locker, 4.88s, new bearings and seals, ruffstuff diff cover, and ruffstuff disk brake conversion.
Both axles geared by a friend.
The suspension will be James Duff arms, with cage weld on mounts, home made lower coil mounts, 78-79 deaver 6" coils and 78-79 6" deaver leafs, ruffstuff 3/8" thick U-bolt plates, fox shocks.
09 civic- DD
post #3 of 107 (permalink) Old 01-01-2017, 10:43 PM
gadawgz71's Avatar
First day it was bought.....rear driveshaft missing and all. Towed it 150 miles home.
In the waiting area with another Bronco awaiting surgery by Dr. Lifted Fords.
JGR, PJCHANNING and CDA 455 like this.
1996 Wht Sport MAF/OBD II 466-1995 Blk XLT 351
SOLD
1996 PG EB 351-1996 Wht EB 351-1996 Wht Sport 351-1994 Wht Sport 351
1996 MB EB, KR Interior 302-1996 Wht EB 351, 3" BL, 33's-1996 PG EB 351
1996 Wht/Tan XLT 351w-1996 PG EB 351-1996 Black Sport 408w, SAS, 40's
1995 Blk EB 351-1996 MB EB 351, 6", 35's-1996 Wht Sport 351-1996 PG EB 351
1996 M EB, 302, SAS D44-1995 Blk Sport-1990 302, M5OD, 3" BL, 33s
1996 Wht EB 351-1993 G EB 357w-1978 XLT 351m-1971 Sport, 331w, 4.5", 35's
gadawgz71 is offline
post #4 of 107 (permalink) Old 01-01-2017, 10:53 PM Thread Starter
It was now time for the swap.
Everything old coming off
New springs going in.
Rear axle under it
Braided stainless lines with AN fittings ran and ruffstuff U bolts and spring plates.
Time for the front 60.
Close but it's clears
Angles look good!
09 civic- DD
post #5 of 107 (permalink) Old 01-01-2017, 11:40 PM Thread Starter
More
Sitting on its own weight. I have 37/13.50r17 toyo m/ts on 17x9 classic locks.
That's all for tonight.
itwasFREE!!!!, Scoop, JGR and 6 others like this.
09 civic- DD
post #6 of 107 (permalink) Old 01-01-2017, 11:45 PM
Thread Killa
jowens1126's Avatar
Damn you GA guys make me sickly envious. Fantastic Work!
Is this going to get another STOCK EFI Mass Air 460?
CDA 455 likes this.
jowens1126 is offline
post #7 of 107 (permalink) Old 01-01-2017, 11:56 PM Thread Starter
Thanks!
Yes it gets a oem ford parts MAF obII efi 460. That's next in the build.
Teaser pic
09 civic- DD
post #8 of 107 (permalink) Old 01-02-2017, 12:02 AM
Thread Killa
jowens1126's Avatar
well hopefully you guys bought 2 of everything when yall did the last one. lol
post #9 of 107 (permalink) Old 01-02-2017, 12:21 AM Thread Starter
I bought a lot of it while doing gadawgz71 swap and made notes on what worked. I tried to be different on some stuff but let's face it. Our broncos are built very similar and they perform very good.
09 civic- DD
post #10 of 107 (permalink) Old 01-02-2017, 08:15 AM
Bronco is lookin good
The only thing that caught me off guard, was the braided brakelines being zip tied to the front axle. That wouldn't last an hour off road up here in the coal region.
Motor looks good. Full build? Stock rebuild??
reptillikus is offline
post #11 of 107 (permalink) Old 01-02-2017, 08:17 AM
Foolsize Member
92BroncoXLT's Avatar
I remember seeing this truck at the M&G in macon years ago on a set of boggers. Then fast forward to april 2016 at the super celebration and its on one tons with a big block while im still messing with 33's and ttb
1992 XLT 300/M5OD
1978 Custom 351M/C6
1991 XLT 351W/Blown Up E4OD
1988 Custom 302/AOD
92BroncoXLT is online now
post #12 of 107 (permalink) Old 01-02-2017, 11:24 AM Thread Starter
Then this showed up! Hefty bumper
I also added 2" wheel spacers in the rear to match the front axle width.
All done around Dec 2015. It took a little bit to get done but pretty much did it by myself on weekends, when I wasn't working.
But now I was having trans issues. They have been coming and going but instead of putting money in a small block set up, it was time for a big block swap. It's time to start ordering parts I don't have yet. BTW it only has 130k on it now.
The main decision I had was rebuild the 460 I have or order a short block or order a long block. I priced it out every way and it was cheaper and faster to go long block and the long block comes with a 3 year unlimited mile warranty. So I ordered it.
A week later this comes in
And this
And this
New radiator and fans
This also showed up. Hefty front bumper
09 civic- DD
post #13 of 107 (permalink) Old 01-02-2017, 12:20 PM Thread Starter
Thanks!
They were a temp fix but I still haven't gone back and welded the tabs I have for it yet. I haven't wheeled it much yet so not a issue.
09 civic- DD
post #14 of 107 (permalink) Old 01-02-2017, 12:41 PM
hoping for details on maf swap on 460.
GetBent4x4 is offline
post #15 of 107 (permalink) Old 01-02-2017, 01:19 PM
Thread Killa
jowens1126's Avatar
you dont mess around.
post #16 of 107 (permalink) Old 01-02-2017, 01:44 PM Thread Starter
Motor now put together and new cam swapped in. It's a Comp thumper cam. #34-601-5. New injectors, new water pump, all sensors (for a 96 351w)are new and the harness is the stock 96 351w cut and modified for the 460.
O2 bung welded in headers
The big block E4od I had cleaned up and painted
Ready to go in
I also have a PSC power steering pump and all AN lines for it. The trans lines will all be AN lines too.
09 civic- DD
post #17 of 107 (permalink) Old 01-02-2017, 03:58 PM Thread Starter
Getting the small block ready to pull. I also decided to pull the front clip. It will make it a lot easier in the long run.
So much more room to work now. But getting it off by yourself is a challenge.
Gadawgz71 came over and helped me move my bronco down the road to my in laws, where the new 460 was and to help me swap the motors.
Transfer case out
And it's on its way out
Old e4od out, still had to pull my pan off it and the valve body out.
New motor finding its new home
It's in
And back at my house
92BroncoXLT, JGR, huck2080 and 4 others like this.
09 civic- DD
post #18 of 107 (permalink) Old 01-02-2017, 04:27 PM Thread Starter
So now I have decided to try and make bronco super celebration, that's a month away! I better get busy.
Doug Thorley Headers going on
Remote mount oil filter
After a few phone calls I found the rare factory 460 MAF intake tubes in a junkyard in CA. I already had the computer and the air box and meter.
Trying to figure out the exhaust. I bought a universal summit racing kit.
I also added a heat blanket for the starter and heat sleeve for the starter wire.
And 0/1 grounds
Had to add the crank trigger tone ring also
JGR, bmad01 and CDA 455 like this.
09 civic- DD
post #19 of 107 (permalink) Old 01-02-2017, 04:46 PM Thread Starter
Built a new cross member out of 1.5" .250 wall dom and some 1/4" plate.
I don't seem to have any pics but the front clip is back on now and finishing the plumbing of everything. I pulled all the abs stuff and put a F-350 booster and master cylinder on. Installed the PSC reservoir.
09 civic- DD
post #20 of 107 (permalink) Old 01-02-2017, 05:08 PM Thread Starter
Then I had to do this
I went to fire her up and she hit for a second but something went pop. Tried again and nothing and something sounded off. Pulled the cap and the rotor wasn't turning. I then pulled the distributor and the cam wasn't turning. Not good! I'm leaving for super celebration next week.
Cam pin broke off
The cam seized up in the motor. I had to use a pry bar to get it out. Yes I used comp cam lube when installing it and primed the motor before starting.
No pics but I installed the cam that came with the long block and the turned smooth as butter. So I put it back together with that cam and took the comp cam back to summit. I also did some searching on line and found that a lot of guys were getting bad cams from comp at that time. My cam looked perfect and had no scarring on it. Summit first said you didn't buy comp break in oil so your out of luck sorry. I said yes I did, look at my order history. I forgot it the day I ordered the cam and ordered it the next day. He said ok I see that now but he was very hesitant. In the end they warrantied it out for a new one but it was backordered for 2 months.
JGR and CDA 455 like this.
09 civic- DD
