IIRC, for complete compatibility (including reusing your potentially existing tire carrier) you're stuck with 80-86 for your truck. I believe that you can swap wiring and such over and physically bolt-up and use the 89-96 tailgate, it's just going to look different and it doesn't have the two hole reinforcement bracket for the 80-86 tire carrier striker, it will have a three hole one so you'll either have to swap carriers or have one hole left over if the other two holes somehow line up. I could be wrong, so I suggest you check with others on this.
That's fine. I can send you instructions in a PM, which you can pull up if you have a smartphone. Even if the window's up, you can still move it down if the regulator in the donor truck is FUBAR. It's what I had to do to Eddie when I first got him. Easy peasy lemon squeezy.
That's cool. I'll post that to you later this evening when I get home.
Related Threads
3.9M posts
99.4K members
Since 2003
