1978 bronco emissons - Ford Bronco Forum
post #1 of 13 (permalink) Old 10-18-2007, 07:23 PM Thread Starter
i was told that their was zero emission equipment on my 78 400 motor. is this true? i wonder if there is no emissions if the cam and timing is retared as on the motors with emissions
getitdone2007 is offline
post #2 of 13 (permalink) Old 10-18-2007, 08:09 PM
49 state = egr valve, retarded cam timing, various vacuum systems.... No Catalyst or smog pump.
I dunno about California, I don't live there nor do I plan to. I think the 78 Cali editions had catalysts and smog pumps.
In Texas, the '78 is exempt from emissions tests
BigWheelz is offline
post #3 of 13 (permalink) Old 10-18-2007, 08:31 PM
yes
Mikes79Bronco's Avatar
Bronco Info: 79, 460, 6.5" lift, 38" TSL Super Swampers < Thats the old...check my sig for progress thread
Same in Illinois...
1979 Bronco - In progress
Build Thread
Eating chevys and shitting hemis
Mikes79Bronco is offline
post #4 of 13 (permalink) Old 10-19-2007, 10:17 AM
Bronco Info: 79, 460 stroked & bored, C6 Tranny with E40D guts, 4" susp, lift 35" Swampers, Spooled rear.
We dont have to take emissions tests in Indiana.
Later
RK
Ratking is offline
post #5 of 13 (permalink) Old 10-19-2007, 12:47 PM
78 was the last year of non emisions on broncos and pickups, but yes they still have the retarded cam timing like, think they actually started that in about 72 or so.
crowebait is offline
post #6 of 13 (permalink) Old 10-20-2007, 07:31 PM
nacman's Avatar
Bronco Info: 94 Eb Copper
I live in massachusetts and I had an inspection station tell me that my truck was supposed to have cat converters. Even though they do not do a smog on the truck he was going to flunk it on a visual inspection basis. I drove away before he got started and found a different station and got a sticker. Just for future information did the 78 Bronco have cat converters on them from the factory?
nacman is offline
post #7 of 13 (permalink) Old 10-20-2007, 07:34 PM
Retired Staff
I know 79 was the 1st year for cats in the F-series. I thought I had heard the 78 Bronco's came with cat's because of there lighter GVW.
Ranger429 is offline
post #8 of 13 (permalink) Old 10-20-2007, 07:44 PM
Bronco Info: '78 Bronco Ranger XLT - 400, C-6, NP-205, 4" lift w/35's. 3G w/ Lincoln fan.
78 - only Cali. Boncos had Cats.
79 & up - All Boncos have cats. I'm told Canadian Broncos did not get Cats until sometime in the 80's.
Winder is offline
post #9 of 13 (permalink) Old 10-20-2007, 07:50 PM
Retired
79F150's Avatar
Look at the gas filler neck. If it has a small hole in it like new cars then it is a Ca model and had cats. If it has the large hole in it was designed full regular leaded gas with no emissions.
79F150 is offline
post #10 of 13 (permalink) Old 10-20-2007, 08:20 PM
If it has the stock sticker under the hood it will say Non-Catalyst.
My 78 has the Non-cat sticker.....but it also has the small hole in the filler neck so I don't know how accurate looking at the filler neck would be.
Winder is offline
post #11 of 13 (permalink) Old 10-20-2007, 10:02 PM
OIIIIIIIO's Avatar
Bronco Info: 89 Bronco DD, 78 Bronco play toy
From ProjectBronco.com:
"The 1979 Bronco was basically a direct carry over from the 1978 models. The big difference for the 1979 model year was a full array of emissions equipment, including smog pumps and catalytic converters, that were now standard on all 1/2 ton trucks. Probably the most amazing accomplishment for the '79 Bronco was that Ford managed to satisfy the EPA emissions requirements with very little, if any, loss of performance over the previous model year."
Don't know how accurate that is... but its something.
-Pat
1989 EB Bronco D/D. 302/AOD/D44 TTB/8.8/FoMoCo Shorty headers/3" full exhaust with FM 50/31" BFG ATs
1984 Jeep CJ-7 Trail Rig. 4.88's/Locked front/spooled rear/37" Iroks.
1999 F150 Tow Rig. 5.4L Triton, super cab step side, 305/70-16 BFG ATs.
1978 Bronco XLT Ranger Re-built 351m/C6/np203/d44/9"/37" MTRs/38" TSLs
OIIIIIIIO is offline
post #12 of 13 (permalink) Old 10-20-2007, 10:59 PM
[QUOTE=OIIIIIIIO;1431603]Probably the most amazing accomplishment for the '79 Bronco was that Ford managed to satisfy the EPA emissions requirements with very little, if any, loss of performance over the previous model year."[/I]
When performance is pathetic and anemic like a 150 hp 400cid engine, then a small loss from pathetic is still pathetic in any book. Factory power sucked sooooo bad in the 1970's
post #13 of 13 (permalink) Old 10-20-2007, 11:40 PM
F1rocco's Avatar
Bronco Info: 1978 460
More of just making sure the visual things are good....Get valve covers with stickers that say non cat.............Also make sure your guage cluster inside doesnt read unleaded fuel under the gas guage......Another is when you open the gas door shouldnt read unleaded....not on the cap not on the door.....
F1rocco is offline
