351 m vs. 351 windsor - Ford Bronco Forum
post #1 of 24 (permalink) Old 03-26-2008, 10:23 PM Thread Starter
firstford's Avatar
Bronco Info: 79 bronco 10" lift 36's 351m 4barrel edelbrock combo ..83 f150 cab
the engine was supposedly rebuilt about 4 years ago and only has 20,000 on it along with the trans .
it sat for so long ,it seem'd so rough at first BUT ,,bam today my bud came by and set the vacuum timing and the dist timing ,adjusted the carb and choke .
i cant beleive this motor spun all 4 tires in the grass and sounds good too.
which engine is better and why .
why do they call this motor 351 modified what is the modified?
however i am suprised at the available power this engine produces.
compared to my friends yota its night and day .
think before you type sometimes the guy on the other side is a BADASS!
firstford is offline
post #2 of 24 (permalink) Old 03-26-2008, 10:37 PM
highhorse78's Avatar
Bronco Info: 78 Bronco-408ci, 6" Superflex lift, 4.56s, Detroit lockers, C6 wide ratio slushbox, twinsticked 205
Modified just means that it is not a Cleveland or Windsor. Thats just the name Ford gave it. By the way modified has nothing to do with Fords newer "modular" motors like the 4.6 or 5.4
highhorse78 is offline
post #3 of 24 (permalink) Old 03-26-2008, 10:50 PM Thread Starter
firstford's Avatar
cool thanks ^^^^^^^
i heard that the 351m is a big block is this true?
post #4 of 24 (permalink) Old 03-26-2008, 10:53 PM
The 351m/400 is a small block but shares the same big block bellhousing bolt pattern as 429/460
post #5 of 24 (permalink) Old 03-27-2008, 12:08 AM
A 351m = a 400 that is destroked. (modified from a 400 to make it a 351)
The only difference between the 400 and 351m is the 351m has a shorter stroke due to the crank and the piston deck height is taller.
redbeast9 is offline
post #6 of 24 (permalink) Old 03-27-2008, 12:32 AM
Bronco Info: 79 Bronco, 460 36's c6/205, 78 Bronco, built 400 c6/205
If you read a ford book from that era, it is actually a 351midland because that's what plant they were built in.
Timothypm is offline
post #7 of 24 (permalink) Old 03-27-2008, 02:32 AM
Bronco Info: 1995 f 150 I6, 5 spd, 7" lift, 35's
is there a difference in fuel consumption between the 400 and the 351. if there is, is there any major difference between a windsor or the modified for example horsepower, reliability, and of course mileage?
suburbanpat is offline
post #8 of 24 (permalink) Old 03-27-2008, 02:53 AM
Big Wurmb's Avatar
Bronco Info: 79Bko:400,c6,np205,d44,9",35"tires.
funny, I thought it to be a Modified Cleveland block....and thus have a Crap load of interchangeable parts......
I thought ford took a 351C made it taller, to fit 400 Cu., then also had it destroked to 351 for light cars ans trucks... there goes that theory .
depends, but usually 2 or 3 Mpg seeing teh 400 is hungry...er
yes, the 351m was a torque engine, the 351w was a hp engine
reliability,
depends
GOSH yes. main bearing #4...5 I forget, are last to get oil and usually increased mileage = decreases oil pressure ALOT sooner then a Windsor
and I think it goes along the line of 351m = torque, 351w = horsepower
2003 Ford Lightning SVT F-150: Sonic Blue, 2.76 upper, CAI, OBX exhaust
2003 Ford Cobra: Metallic Silver Vert, 2.76 upper, CAI, MAC's exhaust
1988 Ranger: Flatbed, 33" xtreme terrains, 2.9L, 5-speed
1979 Bronco XLT (ex-freewheeling package): 6.6L, C6, NP205, D44, 9", 35"tires, Flowmasters, K&N.
Big Wurmb is offline
post #9 of 24 (permalink) Old 03-27-2008, 03:21 AM
rkymtnbrnc's Avatar
Bronco Info: 79 Ranger XLT 302 engine
a 351M is a 351M. No idea where the misnomer "modified" comes from.
351M/400 is correct.
rkymtnbrnc is offline
post #10 of 24 (permalink) Old 03-27-2008, 09:03 AM
is hazardous to others
hav24wheel's Avatar
Bronco Info: Wagoneer, 351M, C6, upside down 205
I've also read that the M in 351M is just a M. that stands for nothing.
hav24wheel is offline
post #11 of 24 (permalink) Old 03-27-2008, 09:08 AM
Bronco Info: '66-'78 bunch o' Broncos...and one Filly
Correct. It was simply a 400..which is all that Ford called it as part of the Cleveland or 335-series engine family when it came out in '71. A few years later (1975) Ford decided they needed a smaller-displacement version of their 'big' Cleveland, crudely destroked the 400 to 351 CI, and slapped an "M" on the end of it so it could be identified as different from the 'other' 351 that was in production at the same time..the 351W..and the one that had only a year before ceased production..the 351C.
'M=Midland'.??.LMAO..why does that keep popping up?...all of the blocks were cast at Michigan, Dearborn and Cleveland foundries. That one was easy.
bmc69 is offline
post #12 of 24 (permalink) Old 03-27-2008, 11:06 PM
mrw
mrw's Avatar
Bronco Info: 78, 79, 66, 73 +
Oh, Mr. know-it-all has to ruin everyones fun . . .
(Side note: should I get my dive gear together to pull that project of yours off the bottom of the bay?)
mrw is offline
post #13 of 24 (permalink) Old 03-28-2008, 12:27 AM
fender hacking extremist
i would hesitate to say that the 351m is a torque engine and the 351w is a hp engine... ive got a 351w that makes an awful lot more torque than horsepower.
1998 formula, LS6 430rwhp/395rwtq
1991 yoter "truck", rust
SMurray is offline
post #14 of 24 (permalink) Old 03-28-2008, 01:31 AM
rkymtnbrnc's Avatar
I'm thinking with those gears you don't lock that up in 4WD too often.
post #15 of 24 (permalink) Old 03-28-2008, 08:59 AM
I would not hesitate to say yr right. Kinda hard to explain in an engineering sense (as opposed to a parochial sense) how two pieces of iron that each have 4" bores and 3.5" strokes are going to be much different at the end of the day..ain't it? In fact..it can be argued that the W, with its smaller intake runner volume, snaller head ports and smaller valves, is more likely to be the one with higher low-end torque, between the two. But that's just a wild guess..er..no wait...something just poked through my alcohol-ridden Alzheimer's-clouded memory..Edelbrock created the SP-2P intake manny for one reason: to reduce the intake runner volume and CSA on the 351M/400 (and a few other 'big breathing engines like those) to increase the bottom-end torque..making it more "Windsor like' in that sense.
bmc69 is offline
post #16 of 24 (permalink) Old 03-28-2008, 09:01 AM
What?..you don't think I can keep that thing afloat with the 8 bilge pumps I got in it?
Thread pirate....
bmc69 is offline
post #17 of 24 (permalink) Old 03-28-2008, 01:58 PM
Big Wurmb's Avatar
sorry its been awhile since ive had a 351m. Ive upgraded to 410, and my 351w bko cant match it.
post #18 of 24 (permalink) Old 03-28-2008, 02:19 PM
rkymtnbrnc's Avatar
Not you Wurmb. SMurray says he's got 4.10's out back & 3.55 up front.
post #19 of 24 (permalink) Old 03-28-2008, 07:18 PM Thread Starter
firstford's Avatar
IVE got the performer 400 edelbrock intake and edel 4bbl carb .
the engine was rebuilt and my mech beleives he did summin to it!
the son of a bitch is crazy strong .
now that the timing on the dist and vac are set this thing starts right up and idles good .
considering my truck has a lot of added metal stuff all around and a rail road rail for a bumper ,i thought it would be slow and heavy BUT NO ,it will burn the rear tire at a light its wierd ,,i almost cant beleive it ,its like a ****ing hot rod,ill take some video and youtube it ..
post #20 of 24 (permalink) Old 03-28-2008, 07:26 PM
Seeing a vid of your rig doing a huge burnout would make my day.
