S.P.2.P Edelbrock - Ford Bronco Forum
post #1 of 29 (permalink) Old 12-20-2008, 12:20 AM Thread Starter
79FordBlake's Avatar
Bronco Info: '78, NP203, Dana44, 9", 351M, C6, 31x10.50-15
S.P.2.P Edelbrock
I just picked up a s.p.2.p edelbrock intake for 100 bucks I thought it would be good for a stock 400 that is going to turn only up to 5,000rpms. I figured it would give me more torque and better performance and better reliability since I can put a 4barrel on it now. After looking at some of the things people have said about them on other forums I think I made a bad choice. Is this intake worthless?
"Look Theres A Jeep, Point And Laugh"
79FordBlake is offline
post #2 of 29 (permalink) Old 12-20-2008, 12:37 AM
highhorse78's Avatar
Bronco Info: 78 Bronco-408ci, 6" Superflex lift, 4.56s, Detroit lockers, C6 wide ratio slushbox, twinsticked 205
Thats a pretty decent intake. I had one on my 351m when it was mostly stock and liked it a lot. It made a huge difference in low end with an edelbrock 1405 over the stock intake and 2150. I find it funny that people bash this intake, and I have a feeling its just because its out of production and not as popular. Search "SP2P" here, as its been brought up a few times and theres some more info on it.
Light travels faster than sound. That is why some people appear bright until you hear them speak.
highhorse78 is offline
post #3 of 29 (permalink) Old 12-21-2008, 01:35 PM
Full Floater's Avatar
Bronco Info: Project 79 F150
I saw in this thread there was a few more posts the other day. They must have been erased by the recent crash. Anyway, someone said the sp2p is "old technology". They may be right, but isnt the performer intake "old technology" also? Have they ever changed the casting on the performer? On the bottom of my performer intake it has "1989" cast into it. Im assuming thats the year cause it was in really bad shape when I found it at the pick and pull.
Full Floater is offline
post #4 of 29 (permalink) Old 12-21-2008, 09:25 PM
Larston's Avatar
Bronco Info: Broncoless, but I got a 1987 F250 to make up for it
I ran an SP2P on a 318 in 1980. It was the worst fawking manifold I've ever seen. Most stock 2bbl intakes will outflow it. Even on my 318, it ran out of steam by 4200 rpm. I bet you'll never see 5000 rpm out of one, and since they are designed for a torque peak around 2500 to 3000 rpm, it wouldn't matter anyway.
Performers are old school tech. In general, they are direct copies of the "best of" the manufacturers low rise 4bbl intakes. The Performer RPM's are generally based on the OEM's best high rise 4bbl intakes with some slight modifications in some cases.
Larston is offline
post #5 of 29 (permalink) Old 12-21-2008, 10:38 PM Thread Starter
Cant be that bad with my stock 2barrel to the floor I can't even get up to 4,000 rpm and it is a gutless wonder. I have tuned it a million times and it still has flat spots and bogs. The only credit I can give my 2barrel carb on the stock intake is that it cranks good and will take pretty steep angles thats about it.
post #6 of 29 (permalink) Old 12-21-2008, 11:10 PM
Thats a 318 though. Cant give credit where credit isn't due. On my 351m with the SP2P and 1405 I've taken it up to 5500rpm. Although it was leaned out of the torque curve by then, I dont doubt that setup could make enough rpm to self destruct.
Its most likely you're carb. A blown power valve or accelerator pump would lead to you're problems.
post #7 of 29 (permalink) Old 12-21-2008, 11:16 PM Thread Starter
Im still switchin to 4v, lol. In a earlier post that you made that got deleted you said I will need a valley pan gasket set and the 's' gaskets. Do I have to have the valley pan gasket or can I just use the individual gaskets that go to each side of the manifold? Also will I need any special gasket or adapter to put a 600 Holley on the S.P.2.P intake?
post #8 of 29 (permalink) Old 12-21-2008, 11:24 PM
On these motors I would stick with the valley pan and "S" gaskets to prevent any leaks, thats just me though. As long as your Holley is a square bore carb, theres no adapters needed.
post #9 of 29 (permalink) Old 12-21-2008, 11:31 PM Thread Starter
Do I need rvt sealer around the water ports or leave that off using the valley pan gasket? I assume to still put some rvt on the ''s'' gaskets?
On my 302 when I did a carb and intake swap I used the regular gaskets with rtv around the water ports and I didnt use ''s'' gaskets just a bead of sealer.
post #10 of 29 (permalink) Old 12-21-2008, 11:38 PM
Yeah, you can use a little RTV around the ports. I would use just enough RTV on the "S" gaskets to hold them in place while you position the intake. Keep in mind if you use too much RTV, it and the gasket will seperate over time and form a leak.
post #11 of 29 (permalink) Old 12-21-2008, 11:43 PM Thread Starter
As always thanks for the good info and help.
post #12 of 29 (permalink) Old 12-21-2008, 11:51 PM
No problem. Are you going to use your existing valley pan or a new one? A lot of times the new pans wont fit right out of the box and need to be hand formed a little. When using RTV around the ports with the new pan you might need to set something heavy in the middle of the pan (like a brick) while its on the motor. This will help the RTV setup and get tacky so the pan will stay in place while you position the intake.
post #13 of 29 (permalink) Old 12-22-2008, 12:06 AM Thread Starter
I haven't took the old intake off yet so ill have to wait and see what kind of condition it is in first. I am waiting on the carb that way I can do all this in one day and not have any down time.
Wow untill I seen you type Rtv in capital letters I never noticed I was typing rvt instead of rtv. I guess that shows how good I am with computers.
post #14 of 29 (permalink) Old 12-22-2008, 01:48 AM
rkymtnbrnc's Avatar
Bronco Info: 79 Ranger XLT 302 engine
What carb you goin with?
rkymtnbrnc is offline
post #15 of 29 (permalink) Old 12-22-2008, 09:39 AM
Larston's Avatar
With the 340 high rise intake I normally ran, this was an 11 second car. We tried the SP2P as an experiment since it was rated as a "high fuel mileage intake with great bottom end." It was neither. It didn't work any better on a stock 318 or a 360.
Larston is offline
post #16 of 29 (permalink) Old 12-22-2008, 10:30 AM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
here is one of those wierd sp2p intakes on a 400.
Let's Go Fishing.
jopes is online now
post #17 of 29 (permalink) Old 12-22-2008, 11:31 AM
Wrenching for a Livin'
magnumpi's Avatar
Dude, it cam stock with injector bungs?!?!?! j/k
but seriously, i thought you were running a performer intake
My SuperFord
'85 Bronco......
magnumpi is offline
post #18 of 29 (permalink) Old 12-22-2008, 01:56 PM Thread Starter
600cfm Holley manual choke. I have a Edelbrock on my other truck and don't really like it, so Im going to try Holley this time.
post #19 of 29 (permalink) Old 12-22-2008, 06:25 PM
gone fish'n
jopes's Avatar
not when the efi went in
Let's Go Fishing.
jopes is online now
post #20 of 29 (permalink) Old 12-22-2008, 10:38 PM Thread Starter
Anybody have the Holley model 4160 600cfm carb on their Bronco? The one I am looking at is part number 0-1850S. I would think it should be fine for my application.
