My FiTech EFI Upgrade - Page 2 - Ford Bronco Forum
 15Likes
post #21 of 35 (permalink) Old 08-29-2016, 11:03 AM
Resurection Ranch
379sinvb's Avatar
We got a little carried away with the discussion and the primary topic of that discussion was already underway over here. All of your posts were moved to this thread : FI Tech and in tank fuel options
Rick
My Projects- "Left for Dead"
Filly
379sinvb is offline
post #22 of 35 (permalink) Old 09-17-2016, 12:37 AM Thread Starter
Hossrod's Avatar
Bronco Info: 1979 Ranger XLT, 400ci, Auto
Quick update. Well, nothing really. Got email yesterday from JEGS that the back order of the fuel commander was pushed out another two months to early December.
Will see if I can track one down somewhere else, otherwise, won't be installing for a couple months at least.
Darth Bronco: 79 Ranger XLT - 400ci - Auto
(build thread) (vectored master wiring diagrams) (FiTech EFI) (half bronco)
Hossrod is offline
post #23 of 35 (permalink) Old 09-17-2016, 10:39 AM
Hillbilly Heaven's Avatar
Bronco Info: 1979 Bronco
Sounds like they are having troubles sorting out the problems they are having with the fuel command center. Have you considered using the Edelbrock one? Looks like 3605 would be an exact spec replacement for FiTech's. If you wanted more fuel volume then maybe the 36033 would be a better choice.
Hillbilly Heaven is offline
post #24 of 35 (permalink) Old 09-17-2016, 11:58 AM
deathmobile2's Avatar
I cancelled my command center order after talking to them - between the massive back order and the fact they said the command center is not good for off roading. I am now going in tank using 89 pick up, stealth pump & AN all the way to the throttle body & back. Will cost ~$150 more than the command center when all said and done, but will look killer.
deathmobile2 is online now
post #25 of 35 (permalink) Old 09-17-2016, 02:09 PM
Thread Killa
jowens1126's Avatar
i think that is a good idea anyway. You will be much happier with an in-tank solution.
jowens1126 is offline
post #26 of 35 (permalink) Old 09-22-2016, 12:41 PM
mrbollero's Avatar
Bronco Info: 1979 Custom 351m
Definitely following progress on this. I'd love to start an engine build in the future and put this style of EFI on- keep it coming! Looking forward to seeing your progress now that you're bypassing the out of stock problems.
Rusty Custom Build
mrbollero is offline
post #27 of 35 (permalink) Old 09-24-2016, 12:09 AM Thread Starter
Hossrod's Avatar
Well, I'm still willing to wait for the fuel commander. I did look at the Edelbrock one (someone mentioned it awhile back), but like the fi tech one better.
Hossrod is offline
post #28 of 35 (permalink) Old 02-27-2017, 10:25 PM
vrewald's Avatar
Bronco Info: 1979 Bronco 400m
Any updates on this?
I have a specific question. I'm looking at the Holley Sniper system but I believe my question will apply to the FiTech system as well.
The ECU in the Holley setup requires a switched +12v power supply while in the Run & Start key positions. What keyed power supply (which wires) will you be tapping into, to supply the power in the Run & Start positions?
If I interpret my wiring manual correctly, there is no single wire that is powered in both Run & Start. What I believe this means, is that I will need to tap into BOTH a hot Run wire and a hot Start wire (2 separate wires) and use a relay to switch between the two.
What do you think?
vrewald is offline
post #29 of 35 (permalink) Old 02-28-2017, 05:38 PM Thread Starter
Hossrod's Avatar
Stuff is sitting in my shop. Just dealing with life and waiting for better weather.
As for the question, I've not actually looked yet. Was going to look at wiring diagrams when I got ready to install. But I think a good place to start is the solenoid. I maybe remembering my old cars wrong, but I think there is a wire/post there that is hot in both run and start.
Let me know what you find, I'll need to know later as well. :)
vrewald likes this.
Hossrod is offline
post #30 of 35 (permalink) Old 02-28-2017, 05:56 PM
Marty in Md's Avatar
Bronco Info: 1993 XLT, 302, 1979 Ranger XLT,351M
Did you end up finally getting the fuel command center?
Marty in Md is offline
post #31 of 35 (permalink) Old 02-28-2017, 09:59 PM Thread Starter
Hossrod's Avatar
Yup. Finally arrived.
Hossrod is offline
post #32 of 35 (permalink) Old 03-07-2017, 03:26 AM
KopfenJager's Avatar
Bronco Info: 78 Ford Bronco Ranger XLT
I found with my FCC, that plumbing it like the directions say, that it works great. I first plumbed the FCC vent to the ground, but it was pissing fuel out the vent. Plumbed it into the vapor line and it works great. My 78 Bronco is a CA model so it has the return line and vented cap. I hope this takes a little of the anxiety out of "will the command center work on MY vehicle?"
KopfenJager is offline
post #33 of 35 (permalink) Old 03-07-2017, 03:08 PM
Klsmith's Avatar
Bronco Info: 1978 bronco lifted 6" with 36" tsl got the 400 on her
This is exactly the set up ive been looking into also for my 78 with a 400. Ill be using it about the same highway driving with some off roading and a little bit of rock crawling. Havent pulled the trigger on it yet but seeing this post has definantly got my curiosity back up on this set up.
Monster bronco rock crawler
Klsmith is offline
post #34 of 35 (permalink) Old 03-07-2017, 08:03 PM
Is there a great disadvantage in not having the timing control? Will it still be good for cold weather starts?
Hossrod, what dizzy are you using for your install?
Marty
post #35 of 35 (permalink) Old 03-11-2017, 10:30 PM Thread Starter
Hossrod's Avatar
Marty
I don't think it's a great disadvantage. Although I do plan on enabling it later. You still have the normal vacuum advance curve.
I don't know what dizzy it has in it, but it looks like a cheap OEM reman one. I think it will be fine cold starting. Of course haven't tried. But it should be better than carb.
Hossrod is offline
