My FiTech EFI Upgrade - Ford Bronco Forum
 15Likes
post #1 of 39 (permalink) Old 08-11-2016, 02:47 PM Thread Starter
Hossrod's Avatar
Bronco Info: 1979 Ranger XLT, 400ci, Auto
Post My FiTech EFI Upgrade
My 79 is a stock 400 motor and awhile back I decided I wanted to upgrade to EFI. Itís my daily driver with lots of daily freeway miles. Also do some light off-roading (forest service roads, beaches, etc.) and some occasional towing (Quads/Snowmobiles/etc.).
After researching options from scavenging junkyard parts to complete install conversions from multiple manufactures, I finally settled on FiTech Go EFI 4-600 HP (30002). It suited my needs feature and price wise.
Originally, I was looking at FiTechís 400 HP model ($200 less) but I wanted the timing control feature. Also, I donít really know full future plans for the engine. If someday I start approaching the 400 HP, I didnít want to that to be the limit. Anyways, for the $200 difference in overall price of the conversion, I felt the 600 HP model was worth the extra cost for myself.
For fuel delivery, I went with FiTechís Fuel Command Center (40003). They had a cheaper inline fuel pump but after talking to their support people, I decided to go with the Fuel Commander and not have to run return lines. I also like the fuel pressure gauges. I also did consider modifying tank, putting in-tank pump, etc., but I just installed a new tank, sending unit, steel lines to engine, and electric fuel pump near tank. I didnít wanted to redo it. I will be hooking up the carb inline electric pump to power off the Fuel Commander, which is powered by the throttle body electronics. FiTech said this would be ok and means both pumps are controlled by the throttle body electronics, which includes shutoff if no RPM detected.
To upgrade to EFI, I also have to upgrade my intake to 4 bbl since stock is 2 bbl. I went with an Edelbrock Performer 400 Non-EGR (2171). Based on another FSB thread of mine, I was told that I can put a non-EGR intake on my EGR engine/heads, that it will just plug the EGR ports on the head. Smog stuff has been removed by PO and the EGR plate under the stock carb is the last thing to go. In WA, I have collector plates on the Bronco so I no longer have to pass any kind of emissions.
My plan is to start with just swapping the carb and intake over to the FiTech EFI. This means installing the Fuel Commander, temp sensor, and O2 sensor. Later I will also change out the dizzy, lock it, and let the FiTech unit handle timing. I will also at some point, upgrade to an aluminum radiator with electric fans and have the FiTech unit control the fans.
I will be using this thread to log my progress as I go, post photos, ask questions, etc.
Darth Bronco: 79 Ranger XLT - 400ci - Auto
(build thread) (vectored master wiring diagrams) (FiTech EFI) (half bronco)
Hossrod is offline
post #2 of 39 (permalink) Old 08-11-2016, 02:55 PM Thread Starter
Hossrod's Avatar
The first part to arrive was the intake and gasket set (not pictured).
ID:	84746   Click image for larger version
Hossrod is offline
post #3 of 39 (permalink) Old 08-11-2016, 03:00 PM
UTfball's Avatar
Man I'm looking forward to the progress/results here. I've been eyeballing the FiTech for a while, primarily due to price. I haven't seen much on the systems, especially for these rigs.
Ben
UTfball is online now
post #4 of 39 (permalink) Old 08-11-2016, 03:05 PM Thread Starter
Hossrod's Avatar
The TBI unit and Fuel Commander was backordered about a month from every place I tried including Jegs and Summit. TBI unit arrived yesterday. Fuel Commander still on the way.
Some un-boxing photos below. Quite well packed.
ID:	84762   Click image for larger version
ID:	84770   Click image for larger version
ID:	84778   Click image for larger version
ID:	84786   Click image for larger version
ID:	84802   Click image for larger version
Hossrod is offline
post #5 of 39 (permalink) Old 08-11-2016, 03:09 PM
vrewald's Avatar
Bronco Info: 1979 Bronco 400m
Subscribed!
Man this is going to be sweet! I have had this system on my next upgrade list for a long time. Can't wait to see the results so I can sweet talk my wife into this upgrade!
vrewald is offline
post #6 of 39 (permalink) Old 08-11-2016, 03:11 PM
78BroncoSteve's Avatar
Sweet. I'll be watching too as I've decided the FI-Tech 600 route is the way I want to go. I plan on pulling my drivetrain this fall though to rebuild the 205, C6 and the 400, so I'm going to do the FI at that point.
The FI guys discouraged me from the Fuel Commander being that they are assuming most trails in Colorado would cause it to hiccup.
Can't wait to hear your feedback on it!
vrewald likes this.
78BroncoSteve is online now
post #7 of 39 (permalink) Old 08-11-2016, 03:13 PM Thread Starter
Hossrod's Avatar
Continued un-boxing photos...
It came with this bung for the O2 sensor. It can be clamped on, or weld just the bung on.
This is the control module you keep in the cab for monitoring and making adjustments. It uses a color touch screen.
Comes with 8 GB SD card for data logging. USB port is for connecting to PC/Device to access data. In more expensive models, you can use USB for laptop based tuning.
ID:	84818   Click image for larger version
ID:	84826   Click image for larger version
ID:	84834   Click image for larger version
ID:	84842   Click image for larger version
ID:	84858   Click image for larger version
Hillbilly Heaven and vrewald like this.
Hossrod is offline
post #8 of 39 (permalink) Old 08-11-2016, 03:31 PM Thread Starter
Hossrod's Avatar
This is an underside shot of 2 of the 4 injectors. All replaceable with off the shelf parts from parts store.
Well, that's it for now.
ID:	84874   Click image for larger version
ID:	84882   Click image for larger version
ID:	84890   Click image for larger version
ID:	84898   Click image for larger version
Hossrod is offline
post #9 of 39 (permalink) Old 08-11-2016, 03:48 PM Thread Starter
Hossrod's Avatar
This is a really good point. For the cost and time of such upgrades, I recommend people email/call such companies about their use scenarios.
I talked to them about this because I saw a concerned raised in another thread about the needle and seat being a failure point. FI confirmed that for my usage (they asked me a couple pointed questions about my limited off-road use), the fuel commander will work great. In general they said the mechanism is "extremely" dependable as far as reliability.
vrewald likes this.
Hossrod is offline
post #10 of 39 (permalink) Old 08-12-2016, 08:11 AM
Resurection Ranch
379sinvb's Avatar
I think you are going to be very happy with this system once it's installed. When I had mine installed we went away from that bung/clamp option FITech provides and got a standard bung. Drilled hole and welded on. The command center was recommended to me when I called and told them I was a wheeler. As it was explained to me "the command center is more reliable for fuel delivery than our electric pump option we provide for you to install outside of the the tank" "There is a possibility of air getting into the fuel line at angles with the pump return line system" " That is not going to happen with our command center".
The at the moment reading & adjustments made by this system are awesome. The display shows air/fuel ratio( no need for a wideband) as well as rpm and water temperatures.
I'd look into the Lokar kickdown cable set up when adding this. A bracket had to be fabbed up to connect the FItech to the kickdown. Mine is kinda ghetto and the Lokar is imo a better option. One I will eventually get to.
For those reading this thread and interested in purchasing the system. I purchased mine from LMCtruck and got the system in 4 days. Other vendors like paceperformance, wildhorses and ebay also carry them.
Not trying to hijack your thread here, just validate what you are getting into.
UTfball, vrewald and mrbollero like this.
Rick
My Projects- "Left for Dead"
Filly
379sinvb is online now
post #11 of 39 (permalink) Old 08-12-2016, 10:46 AM Thread Starter
Hossrod's Avatar
No, not hijack, this is one of the reasons for posting this thread, for feedback, questions, etc. Discussions/info welcome!
As for the kickdown, my current setup isn't a cable, it's bent rod that comes up from transmission and connects directly to throttle linkage on the carb (see photo below). Is the Lokar a conversion from a rod to a cable based setup?
Hossrod is offline
post #12 of 39 (permalink) Old 08-12-2016, 11:06 AM
Resurection Ranch
379sinvb's Avatar
Yes bent rod is what I have and here is how we mated that rod to the FItech
not the best picture but you should have the idea. I'll grab another more detailed one.
The Lokar is a cable and should work a little better than what we came up with above.
https://www.summitracing.com/parts/l...c6ht/overview/
Hossrod likes this.
Rick
Filly
post #13 of 39 (permalink) Old 08-12-2016, 07:33 PM
Maybe I didn't eat enough Wheaties this morning, but are they not giving contradicting info here? They told me don't do the command center and do an aftermarket in-tank pump.
I would much rather do the command center. My tank has maybe 3000 miles on it, as well as the filler hoses, rubber lines, etc. I don't want to drop the tank again.
Thoughts?
post #14 of 39 (permalink) Old 08-12-2016, 08:29 PM
Resurection Ranch
379sinvb's Avatar
The way I understand it as long as there's fuel in the command center it's pushing fuel to the throttle body. So the stock pump would have to quit for the fuel delivery to be interrupted. Where as with the hp pump option they sell could pull air at certain angles and push that bubble to the throttle body.
Rick
Filly
post #15 of 39 (permalink) Old 08-12-2016, 08:43 PM
Hillbilly Heaven's Avatar
Since it's a 78 just use the tank and mechanical pump you have now and use the command center.
Hillbilly Heaven is offline
post #16 of 39 (permalink) Old 08-12-2016, 09:45 PM
Yee, that all makes sense. Command center it is. Plus, I think it's kind of cool too.
Thanks for the great thread start here Hossrod. Looking forward to further discussions.
post #17 of 39 (permalink) Old 08-17-2016, 01:47 PM
KopfenJager's Avatar
Bronco Info: 78 Ford Bronco Ranger XLT
Following. My fitech is on back order. Think there is going to be a few threads on this in the near future.
KopfenJager is offline
post #18 of 39 (permalink) Old 08-17-2016, 03:32 PM Thread Starter
Hossrod's Avatar
Yeah, both TBI and Fuel Commander were backordered. TBI unit finally arrived, but just got email from Jeg's yesterday that they now expect it to ship end of September.
Contacted FiTech to see if they knew who had them in stock, they didn't. They are backordered on their site as well.
Hossrod is offline
post #19 of 39 (permalink) Old 08-17-2016, 04:34 PM
Ford Hoarder
Do not know if it is plug and play with this, but Edlebrock also makes a system that has the pump and reservoir in a self contained unit that fills using the mechanical pump.
CrazyBRONCOguy is online now
post #20 of 39 (permalink) Old 08-18-2016, 12:30 AM Thread Starter
Hossrod's Avatar
Thats a good point. I looked into it, but the Edelbrock EFI sump kit is more expensive and doesn't have gauges. I believe it would work though. It's 60 psi while FiTech needs 58 psi, but not sure that 2 psi matters. I'm guessing electrical wise its draws roughly same current, etc. I'm also not sure I like the overall design/materials and mounting system.
Hossrod is offline
