Acceptable ammeter hookup locations for stock gauge? - Ford Bronco Forum
post #1 of 4 (permalink) Old 02-06-2017, 09:10 AM Thread Starter
So I am working on finishing up my charge circuit and I am down to ignition feed and ammeter. Should I place my red wire to the starter solenoid and place the other green and red wire to the alternator Battery lead? Thinking an inline fuse would not hurt either, what amperage, thinking 5 amp?
post #2 of 4 (permalink) Old 02-06-2017, 05:08 PM
xMUDBUCKETx's Avatar
Bronco Info: 1979 Ranger XLT/ Free Wheeling
Did you change over to a single wire alternator? I sent in the stock ammeter to get converted to voltage meter.
http://www.rccinnovations.com/index.php?show=cores
1979 Bronco Ranger XLT
xMUDBUCKETx is offline
post #3 of 4 (permalink) Old 02-07-2017, 04:27 AM Thread Starter
Rocketman's Classic Cougar Innovations
Nope I put an adjustable regulator and 2G big case external regulated.
post #4 of 4 (permalink) Old 02-07-2017, 10:44 AM
Hillbilly Heaven's Avatar
Bronco Info: 1979 Bronco
The factory ammeter uses a special wire and the meter is actual a millivolt meter. The special wire acts like a current shunt and they measure the millivolts across the shunt. The higher the current draw the higher the voltage to the gauge. FOrd did it this way so they didn't have to run large gage wires thru the firewall for a true ammeter. I haven't looked at the diagrams in a long time but I can tell you it does hook at one end to the battery side of the starter solenoid and the other end of it supplies power to the rest of the whole electrical system not counting the starter. If someone would kindly post a pic of the diagram for the ammeter gauge I can show what I am talking about. I don't have access to all of my filers right now.
Hillbilly Heaven is offline
