Power Steering Pump Bracket - Ford Bronco Forum
 8Likes
  • 1 Post By kochic
  • 1 Post By OX1
  • 2 Post By grovermyson
  • 1 Post By OX1
  • 3 Post By grovermyson
post #1 of 18 (permalink) Old 02-15-2017, 03:25 PM Thread Starter
grovermyson's Avatar
Not sure what the deal is with this, but when I bolt on the stock power steering bracket to the water pump and engine block it doesn't exactly fit properly. It doesn't line up on the drivers side where it attaches to the front side of the head. Any ideas?
grovermyson is offline
post #2 of 18 (permalink) Old 02-15-2017, 03:39 PM
Joyride20's Avatar
Bronco Info: 78 Bronco Ranger XLT, 400 over .030 w/ RV cam, C6, 205, 2-3" lift w/ 33"s D44, 9in
I've never had an issue and never seen that happen. The only thing I can think of, and its highly unlikely, but could you have mixed up the water pump bolts with where the power steering bracket goes? I'll be in front of my 78 later and ill take a look and see what I notice.
Hope you get it resolved.
Joyride20 is offline
post #3 of 18 (permalink) Old 02-15-2017, 04:01 PM Thread Starter
I found this pic online. This is how its supposed to look but even with that half inch spacer I don't think it will align correctly..
post #4 of 18 (permalink) Old 02-15-2017, 04:48 PM
huck2080's Avatar
Bronco Info: 79 bronco 460 c6
what brand water pump is that . i could swear there should be some addiltional bolt holes in that thing
huck2080 is offline
post #5 of 18 (permalink) Old 02-15-2017, 05:01 PM Thread Starter
I checked that. Its a stock replacement. I matched it up to the old one.
post #6 of 18 (permalink) Old 02-16-2017, 04:36 PM
78BroncoSteve's Avatar
78BroncoSteve is offline
post #7 of 18 (permalink) Old 02-16-2017, 07:35 PM
kochic's Avatar
Maybe if you start with the stud first it will bolt to the water pump?
I don't remember a spacer on mine.
Marc
huck2080 likes this.
kochic is offline
post #8 of 18 (permalink) Old 02-17-2017, 09:50 AM
OX1
OX1's Avatar
Remanufactured or new chinese? Could be new one with holes cast/tapped wrong...............
OX1 is offline
post #9 of 18 (permalink) Old 02-18-2017, 09:15 AM
I agree, seeing the angle it's at.
the Son is offline
post #10 of 18 (permalink) Old 02-18-2017, 11:21 AM Thread Starter
Well I put the bracket on with the top right stud first and wouldn't you know it fit. I don't think I will need the spacer on the stud but I will mock it up to make sure the pulleys align properly.
post #11 of 18 (permalink) Old 02-18-2017, 04:29 PM Thread Starter
Looks like the alignment is just fine......
post #12 of 18 (permalink) Old 02-19-2017, 08:57 AM
OX1
OX1's Avatar
After looking at the pics again, it should have been obvious
to me too that it was one of those deals where something
would not fit, just due to it not being in the right spot
(especially with the studs sticking out)
Glad to see you got it on and ignored me
OX1 is offline
post #13 of 18 (permalink) Old 02-19-2017, 01:22 PM
I don't think I will need the spacer on the stud but I will mock it up to make sure the pulleys align properly.[/IMG]
The AC compressor bracket "is" the spacer. I have a spacer because my AC bracket is gone.
the Son is offline
post #14 of 18 (permalink) Old 02-19-2017, 02:53 PM Thread Starter
I kind of thought that Son but when I mocked it up it was off by a hair less than 1/4 inch....it just looked off to the eye. I looked at some old pics and noticed there were a couple of washer added. I added two washers which brought it into alignment.
BikerPepe`, huck2080 and the Son like this.
post #15 of 18 (permalink) Old 03-20-2017, 10:45 PM
Bronco Info: 79 400m c6
great looking engine and bay!
FordGuy615 is offline
post #16 of 18 (permalink) Old 03-21-2017, 04:35 PM Thread Starter
Thanks FordGuy.. Hope the damn thing starts up....
post #17 of 18 (permalink) Old 03-21-2017, 05:59 PM
biggum's Avatar
Bronco Info: 1986 XLT 351HO and 1985 base 302FI
You've got some rust on that nut - totally unacceptable!
biggum is offline
post #18 of 18 (permalink) Old 03-21-2017, 06:44 PM Thread Starter
Your right! could have caused a fire. Ill get right on it.
