rebuilding a np 205 - Ford Bronco Forum
 3Likes
  • 1 Post By 79broncoowner
  • 1 Post By OX1
  • 1 Post By marshallnoise
post #1 of 7 (permalink) Old 02-26-2017, 09:38 AM Thread Starter
79broncoowner's Avatar
Bronco Info: 1979 bronco 390 4 speed
rebuilding a np 205
I have a np 205 in my 79 bronco that has up and down play in the rear yoke and I can not keep the nut tight. So I tore into a spare 205 I have in the shop and once apart the shifing fork was broke. How in the world do you break a shifter fork. Was it caused by abuse. The thing is the gears look fine So should I rebuild it or look for another one to rebuild. I dont want to rebuild the one in my bronco because I dont want it down. I want to rebuild one and just swap them.
vrewald likes this.
79broncoowner is offline
post #2 of 7 (permalink) Old 02-26-2017, 08:25 PM
vrewald's Avatar
Bronco Info: 1979 Bronco 400m
Any pictures of the breakage?
If you have some good, clear, closeup pictures of the broken pieces in the cross sections they broke, we may be able to tell you if the failure mode was:
1) Overloading failure
2) Fatigue failure
3) Failure due to material defect/other
This can be done by looking at the metal grain patterns in the failure areas.
vrewald is offline
post #3 of 7 (permalink) Old 02-27-2017, 07:25 AM Thread Starter
I looked at the broken pieces but they were black from sitting in the old grease for several years. It broke the pieces off the end of the fork on both sides. Nothing else was broken so this should be a good one to rebuild?
post #4 of 7 (permalink) Old 02-27-2017, 08:03 AM
OX1
OX1's Avatar
Guess it depends upon what you mean by rebuild. Doing all the bearings?
Not sure I'd reuse any bearing with larger metal parts possibly
being run through it for a long time (unless you think it was
unusable as soon as fork broke)........
huck2080 likes this.
OX1 is offline
post #5 of 7 (permalink) Old 02-27-2017, 04:49 PM
marshallnoise's Avatar
Bronco Info: '79 Custom
Might be cheaper to source another unit.
Pwalli (Paul)
1995 BMW 540i
'79 SHTF Daily Build
1997 Toyota 4Runner (locked)
marshallnoise is offline
post #6 of 7 (permalink) Old 02-27-2017, 07:33 PM Thread Starter
I got another 205 It looks better and shifts like it should. And yes this is a all bearing and seal rebuild. Any tips
post #7 of 7 (permalink) Old 03-14-2017, 03:50 PM
fordaholic495's Avatar
Not really a tip, but NP205's are cake to rebuild. Check out this link if you want a guide NP205 Rebuild Guide
My build thread!
fordaholic495 is offline
