Does anyone make a core support for my 78? - Ford Bronco Forum
 5Likes
  • 1 Post By huck2080
  • 1 Post By 445 FE Bronco
  • 1 Post By RAMPNT1
  • 1 Post By CrazyBRONCOguy
post #1 of 9 (permalink) Old 03-09-2017, 07:20 PM Thread Starter
Found everything but a core support, mine is pretty rotted. Does anyone make a single headlight core support or do I have to patch mine up?
post #2 of 9 (permalink) Old 03-09-2017, 07:41 PM
huck2080's Avatar
Bronco Info: 79 bronco 460 c6
national auto body list two different ones for your truck .. i can look around down here for a cleaner one for you .. if you can't find one
445 FE Bronco likes this.
huck2080 is offline
post #3 of 9 (permalink) Old 03-09-2017, 08:02 PM Thread Starter
I found that one also but it appears out of stock? If in your wandering you run across one that doesn't look like barnacles are growing on it I would definetly be interested.
huck2080 likes this.
post #4 of 9 (permalink) Old 03-10-2017, 06:30 PM
huck2080's Avatar
when will you be needing ii . i know of a place that has a few 73 to 79 trucks / bronco not sure if any have good core supports ..
huck2080 is offline
post #5 of 9 (permalink) Old 03-12-2017, 10:59 PM
RAMPNT1's Avatar
If you were closer to Vegas I'd give you the one sitting in my backyard.
Jim
RAMPNT1 is offline
post #6 of 9 (permalink) Old 03-13-2017, 06:00 AM
Ford Hoarder
I agree with the above 2 people, I also should have 2 decent ones around. For sure 1 but I am unsure where the 2nd one is.
I think you can find a good OEM one for not a lot of money. Seems the 78/79 core supports held up pretty decently over the years. Even my not so nice mud truck has a good core support and it had huge holes in the floor.
CrazyBRONCOguy is online now
post #7 of 9 (permalink) Old 03-13-2017, 08:23 PM
huck2080's Avatar
not sure if its the one you need but a place called classic auto parts group in okc has one listed on eBay right now
huck2080 is offline
post #8 of 9 (permalink) Old 03-13-2017, 10:15 PM Thread Starter
I need the two headlight core where the ends drop down, the quad one seems more available than the two headlight one? Worse case I could fix mine but it would be a real PITA.
post #9 of 9 (permalink) Old 03-15-2017, 10:49 PM
trustyrusty's Avatar
every 78-79 truck I owned the core support was always perfect
my swiss cheese driver 78 has a mint core support, go figure
on a core ,I never seen a quad headlight 73-79
trustyrusty is offline
