Alternator Connections - Ford Bronco Forum
post #1 of 8 (permalink) Old 03-17-2017, 01:46 PM Thread Starter
grovermyson's Avatar
So I want to make sure that I don't start a fire or screw something up. Can you all check this to make sure I'm connecting the wire to the proper terminals on the back of the ALT?....
Thick gauge black w red stripe connects to "BAT terminal on ALT
Solid orange wire -orange cap connects to the "FLD" terminal on ALT
Yellow wire w/black stripe - black cap connects to "STA" terminal on ALT
grovermyson is offline
post #2 of 8 (permalink) Old 03-17-2017, 10:48 PM
Ziggy's Avatar
Bronco Info: 79 Bronco
Your connections are correct by my 79' wiring manual, I know they are the same for the 78'. You can double check by Ohming the yellow w/black strip to the electric choke connection as this wire supplies power to the choke.
Ziggy is offline
post #3 of 8 (permalink) Old 03-18-2017, 01:52 PM Thread Starter
Thanks again Zig. Im not that much of a screw up I guess. I have a hot air choke on my stock 2150 carb - maybe I should swap out to an electric one due to I no longer have a hot air supply with my new Edelbrock manifold.
post #4 of 8 (permalink) Old 03-19-2017, 02:09 AM
Ziggy's Avatar
Stock 2150 came with an electric choke, if yours doesn't have one then someone swapped it out. I would put the electric choke back on so the choke will unload after it heats up.
Ziggy is offline
post #5 of 8 (permalink) Old 03-19-2017, 11:24 AM Thread Starter
I thought my Bronco Carb was the stock original- No electric choke. I came across this on the Gran Torino website that stated ....
Automatic choke systems
There were three automatic choke systems used on Motorcraft 2150 carburetors:
Hot-air choke
Hot-air choke with electric assist
Electric choke
Maybe the Broncos only came with the electric choke - like you said....
post #6 of 8 (permalink) Old 03-21-2017, 12:18 AM
Ziggy's Avatar
Every Ford truck with a 351M/400 that I've ever come across in the JY with the 2150 in it has the Hot-air choke with electric assist in it. Not sure how much the hot-air contributed to the choke as most of time the hot air tubes are clogged with carbon, voltage for the electric choke is only 7 VDC and it doesn't take much to heat the choke spring up.
Ziggy is offline
post #7 of 8 (permalink) Old 03-21-2017, 12:38 PM
Redneck Engineer
79BroncoSpringTx's Avatar
Grover how close are you to firing this thing up?
79BroncoSpringTx is offline
post #8 of 8 (permalink) Old 03-21-2017, 04:32 PM Thread Starter
Yeah, when I took off my hot air tube from the manifold and removed the inner manifold tubing it was completely clogged. I didn't see any mention of just a hot air choke in my Bronco Manual.
As far as starting up the engine, I hopefully will try in about a month. I have to do a few more things. When I take parts off I make sure I put them back on completely clean. I cleanup up every single bolt that goes back on.
Ill probably first start it up without the radiator for 15 seconds or so. Ill definitely roll it out of the garage and away from the house. Maybe have the Fire Dpt. and Paramedics standing by....lol
