Trailer/Hauler: Goodyear Endurance | Tow with Confidence - Ford Bronco Forum
post #1 of 2 (permalink) Old 02-27-2017, 01:34 PM Thread Starter
FSB Vendor
Discount Tire's Avatar
The Goodyear Endurance Trailer Tire is a durable trailer tire that provides towing stability, heat resistance, and high load carrying capacity for trailers, toy haulers, and RVs. It features a tough internal construction and specialized inner liner for load stability and resistance to air loss. The hardworking Goodyear Endurance has Durawall technology for resistance to cuts and punctures. Whether it's for work or play, the Goodyear Endurance trailer tire is designed so you can tow with confidence. Made in the USA.
Goodyear Endurance
UTQG: N/A
Click here for online: Goodyear Endurance Availability and Sizing
Also available in-store HERE
-KEY FEATURES-
  • An optimized tread depth and decoupling groove, which help it remain cool while towing heavy loads
  • Rugged fabric-steel construction, which offers improved durability and carrying capacity while remaining compatible with tire pressure monitoring systems and typical tire inflation stations
  • A specialized inner liner, which minimizes air loss in trailer applications
  • A scuff guard, which helps protect sidewall
  • The Endurance features a N Speed Rating (87 mph)
Low Prices! More Choices! Trusted Experts!
At The Store: www.discounttire.com
To Your Door: www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Discount Tire is offline
post #2 of 2 (permalink) Old 02-27-2017, 02:37 PM
nra1ifer's Avatar
Bronco Info: 1981 w/302
I look forward to seeing how this ST tire does in the real world.
We have a 1987 Avion 34' travel trailer with 3 axles under it. When we got it 3 years ago, we towed it home 1,000 miles on an older set of Marathons, no issues whatsoever. Then, once I get to reading several travel trailer forums, you'd think the world was coming to an end if you listened to others bash the quality of the Marathon trailer tires. Especially in the Airstream crowd..... those lemmings think that you're not safe unless you get rid of anything but 16" rims and Michelin LT tires. Personally, I have a feeling that a lot of woes were caused by operator problems.
Although I have since replaced my six Marathons with a Commodore brand ST tire, the next time I need trailer tires I will definitely be interested in these new Endurance tires.
Hoping for good things to come.
nra1ifer is offline
  Ford Bronco Forum > Vendor Forum > Discount Tire
You may not post replies
