Ford Bronco Forum - View Single Post - Four Door Bronco Build Thread
post #1 of (permalink) Old 10-31-2016, 05:01 PM Thread Starter
1985 Bronco
1985 Bronco's Avatar
Bronco Info: 1995 C150 Centurion 4 Door Bronco, 351, E4OD, 4x4
I have decided to start my build thread now that the rust repair is coming along. It is a 1995 Ford Centurion C150 (4 door bronco). It has a 351, E4OD, push button 4x4, with locking hubs. I will be converting it to a Bullnose (80-86). I bought a 84 F150 as a donor that provided a front clip for me, and bought new rockers, quarters, and inner wheel wells. I also picked up an 86 f150 bed trailer that donated inner tubs, and the gas tank area.
You can see my earlier thread here: http://www.ford-trucks.com/forums/14...nco-today.html
In that thread I swapped on a new tailgate, sport bumper, and new rims and tires. You can also see the rust we are dealing with.
Here is what I am starting with:
Cut the quarters off, rockers are pretty rough.
New ones mocked up
After some sand blasting
Test fit
Fabbed up part of that channel
End cap and other parts remade
Hit with some primer, welds need to be ground down still, and long cut has to welded up after the quarter is attached
Other side
Done
1995 C150 4 Door Bronco: 351, E4OD, 4x4, Bullnose conversion in progress
Build Thread: http://www.fullsizebronco.com/forum/...ld-thread.html
1985 Bronco: Sold
1985 Bronco is offline
