Ford Bronco Forum - View Single Post - 15x10 Ride Height
post #3 of (permalink) Old 01-09-2017, 07:42 PM
CDA 455
MidlifeCrisisUndrWay
CDA 455's Avatar
The short answer: Not enough difference for you to care.
The long answer: Maybe .5"+/- shorter due to spreading the tire out; Maybe.
Are your Goodyears 'D' or 'E' rated tires? Or rather; What's the max inflation for said tires? 35PSI sounds like max PSI unless it's rated for 45PSI.
FWIW; I inflate my tires so that there's an even footprint across the entire tread. I don't go by PSI because the tires I use are rated for a full size truck with a max load heavier than what I can carry.
μολὼν λαβέ
CDA 455 is offline
