Ford Bronco Forum - View Single Post - tailgate window safety/latch switch
post #6 of (permalink) Old 01-10-2017, 07:06 AM
CrazyBRONCOguy
on KIK as same
That switch by the latch is very simple momentary switch. You maybe able to use another style in its place fairly easily. Such as one for dome lights near the door. All it does is interrupt the power going to the window motor. So to bypass it all you have to do is connect the wires going to it (there are 2) together. You could even do this temporarily while a switch can be found. I maybe able to find the one from my tailgate as I deleted it, if I can find it you can have it.
CrazyBRONCOguy is offline
