Ford Bronco Forum - View Single Post - Open differential sucks help!!
post #3 of (permalink) Old 01-10-2017, 09:32 AM
BigBlue 94
A factory LS part can be "upgraded" with an extra steel and clutch disk. This tightens it up quite a bit.
Mini spools are pretty cheap and can be done without messing up the gear mesh.
Otherwise, I'd go Detroit locker, but then youre talking 600 plus re-setting your gears. Traction is phenomenal, and street manners aren't bad, once you've heard and felt the locker pop in and out once. First time is a bit sketchy sounding.
BigBlue 94 is offline
