Ford Bronco Forum - View Single Post - 350 Brake Booster
post #7 of (permalink) Old 01-11-2017, 12:16 AM
the Son
Originally Posted by Kingfish999 View Post
you probably wont see any gains in the F350 master cylinder unless you put in bigger brakes however
This is mostly true. I machined ("machined" ...slow and careful with a Dremel) my stock master cylinder mounting holes just wide enough to fit correctly on the F350 booster. It made a big difference without having to change calipers or wheel cylinders.
the Son is offline
