351w supercharger input needed - Ford Bronco Forum
post #1 of 20 (permalink) Old 04-13-2008, 12:12 AM Thread Starter
Anti D's Avatar
Bronco Info: 94 EB Supercharged 351w 6" lift 35/12.50/15 xterain on procomp alloy rims
well a local shop has rebuilt my 351w and i was offered a supercharger for it for 1500 dollars is this a good deal or is it a scam the super charger comes with full MSD ignition and everything needed to get me going
i just dont know enough about them to make a smart decsion so i need some input i think its a eaton if that makes any sense
thanks everyone!!!
JACK IT UP cause fat chicks can't jump
Anti D is offline
post #2 of 20 (permalink) Old 04-13-2008, 01:08 AM
broncobamf's Avatar
Bronco Info: 94 ford bronco with 4 inch rancho lift and 31s. 3.55 gear and 5.8 also a e4od transmission.
do it
its better to be hated for who you are than to be loved for who your not.
broncobamf is offline
post #3 of 20 (permalink) Old 04-13-2008, 01:10 AM Thread Starter
Anti D's Avatar
price
is the price fair or should i dicker around with it
Anti D is offline
post #4 of 20 (permalink) Old 04-13-2008, 01:49 AM
BoulderBronco's Avatar
First off try breaking your words up into sentences. Second it sounds like your getting had. $1500 for a supercharger with MSD ignition, installed, is way too cheap. Something is up.
BoulderBronco is offline
post #5 of 20 (permalink) Old 04-13-2008, 01:57 AM
Resident Moron
borflink's Avatar
Bronco Info: 1982 5.8L C6 Megasquirt York OBA 3G Headers Saginaw pump
This is a roots type blower? $1500? That includes install? That seems a lot low for what you seem to be getting.
There are quite a lot of things to deal with. What would the boost pressure be? would it require premium fuel? Is the added hassle worth the extra horsepower for you?
Consider that at a conservative boost of 6PSI assuming 8.0-1 static compression ratio, and assuming you are at sea level, you will see 11.27-1 effective compression ratio. That would mean you are committed to premium fuel.
To have the garage asking after the rebuild if you want the blower seems odd. This is something you build your engine to handle, not add as an after thought.
Originally Posted by Strahan View Post
Hmmm.. a smoked sausage wrapped in that cheesy bacon weave may be good.
borflink is offline
post #6 of 20 (permalink) Old 04-13-2008, 02:08 AM
nitrorustlerpro15's Avatar
Bronco Info: 1985 Bronco FS, 351W, C6, NP208F, 32" Trail Handler's, HEI Dizzy.
dont ask questions, just do it. DO IT!
nitrorustlerpro15 is offline
post #7 of 20 (permalink) Old 04-13-2008, 02:16 AM
trying to go fast!!
RGJ 58's Avatar
Bronco Info: 93 EB 347 Stroker, NP435 swap,35" BFG M/T,
dang sounds like somthin is up i might just go and pick up the supercharger and then figure more about it later and then put it on later after you know what your dealing with
347, Summit block, Air Flow Reasearch Outlaw heads, Comp Cams 282,292, 565. 574., Forged Eagle crank, Forged Eagle connecting rods, Speed Pro Pistons, Victor Jr. Intake, Comp Roller rockers, Engine works timing gears, Kevoko 9 qt baffled oil pan, Meling M68 oil pump, Holley Truck Avenger 670 (too small).
RGJ 58 is offline
post #8 of 20 (permalink) Old 04-13-2008, 07:25 AM
flomaster's Avatar
Bronco Info: 95 XL 302-M5R2-1356-3L55-31's
No balls!
flomaster is offline
post #9 of 20 (permalink) Old 04-13-2008, 10:05 AM
Trying to finish it
AHeavyBronc's Avatar
Bronco Info: 1988 w/ 351W, C6, NP 208, 6 inch superlift front, BDS rear leaf, 37 inch Boggers, 9" 4.88 detriot
don't do it, it sounds fishy. plus, you have to get certain parts for your engine to handle the s-charger.
AHeavyBronc is offline
post #10 of 20 (permalink) Old 04-13-2008, 11:56 AM
Bronco Info: 1989 bronco bone stock for now
i have worked at local speed shops here in memphis and we use to try and upsell items to people. i can tell you that their is tunning out their for obdII vehicles that they can plug and play on .. not sure what your veh is. but 1500.00 sounds too cheap . unless the shop has a used blower laying around . we did a lot of vetts and i think the cheapest kit for them was like 3200. + install. you will have to use premium fuel. and if you have 8.5 or 9. to 1 comp . it should be fine. they would try to put fmu on it which works good. i would get more details and try to search the kit on google and read all reviews before i made up my mind ..
minimeswapd16z is offline
post #11 of 20 (permalink) Old 04-13-2008, 03:06 PM
I seriously doubt they are talking a roots , im sure they are talking about a centrifugal ... in order to run a roots you would have to go carb , mechanical injection or serious custom stand alone. 1500 does sound really cheap , i would want to know what the head unit for the supercharger is first off .... if its a nice brand like pro charger , vortech or paxton ... then i would jump all over it , its worth 1500 even if its worn out and needs new bearings.
DonnieF is offline
post #12 of 20 (permalink) Old 04-13-2008, 05:19 PM
Satyr of the Midwest
SigEpBlue's Avatar
It could very well be a Kenne Bell twin-screw setup, but those aren't any cheaper than a centrifugal (ball-bearing, geared, or belted). $1500 is too little for a brand-new blower unit, let alone the accessories to go with it. You could barely get a head unit for that much.
SigEpBlue
SigEpBlue is offline
post #13 of 20 (permalink) Old 04-13-2008, 05:32 PM
Resident Moron
borflink's Avatar
He mentioned Eaton in his first post. That had me thinking roots
IF it is a new unit, installed and tuned for $1500, even a centrifugal, that is a steal.
borflink is offline
post #14 of 20 (permalink) Old 04-13-2008, 05:45 PM
topfisherman's Avatar
Bronco Info: 1992, 5.0, M5OD, warn hubs, Catco y-pipe
You don't have to go carb to run a roots blower, EFI would work fine, you would just need to tune it for the extra air.
Agreed, I would be weary of his offer. Just a supercharger kit is in the neighborhood of $2500 and thats before the install.
1992 Custom, Rebuilt 5.0L, M5OD swap, BW1356.
Warn hubs, K&N filter, Catco Y-pipe, Ford Racing Headers, 3G Alt, Saginaw PS Pump, E-Fan.
Pioneer head unit and 220W 3-way speakers.
My Supermotors.
topfisherman is offline
post #15 of 20 (permalink) Old 04-13-2008, 08:03 PM
Bronco4Life's Avatar
FMU's are gay.
+ lots of cool crap.
Originally Posted by dgmid61
Bronco4Life is offline
post #16 of 20 (permalink) Old 04-13-2008, 08:35 PM
bad96's Avatar
Bronco Info: 96 EB 351 blown, Edelbrock intake,MSD,Ford motorsports headers,pro-M, SAS Suspension 35's,e-lockers
Originally Posted by Bronco4Life View Post
FMU's are gay.
wanna buy my old FMU
Originally Posted by DomesticDisturbance
i have 6"s and have no problem with my shaft
http://www.supermotors.net/vehicles/registry/16733
bad96 is offline
post #17 of 20 (permalink) Old 04-13-2008, 09:08 PM
Since i was corrected twice in this post , i feel the obligation to explain a few things. First off , topfisherman ...i said it could be EFI with a roots with a serious custom stand alone .... stand alone meaning ECU such as accel DFI gen 7 , motec , haltech or Felp pro sefi8lo ,i am not writing this being a smartass .... just trying to inform a big misconception in the automotive world.
Supercharger 101
There are 4 types of superchargers out there .....
CENTRIFUGAL such as vortech , pro charger , powerdyne and paxton
ROOTS such as Holley , weiand , littlefield , BDS , Kobelco Ect.
TWIN SCREW/WHIPPLE such as Kenne Bell , Eaton ect.
WATER DRIVE which i will not get into , because you guys will never see it on a automobile
A roots has flat rotors with a slight pitch , a screw is exactley what it says , it has 2 rotors overlapping each other like a screw. Centrifugal has a rotor like a turbo and is remote mounted. Hope this helps a little to understand superchargers more then they are all blowers.
DonnieF is offline
post #18 of 20 (permalink) Old 04-13-2008, 09:18 PM
Hell no, if I wanted crap under my hood, I'd put a carb on.
Tuned EFI is the correct way to do sheet.
BTW, where the hell were you! You missed out something fierce!
post #19 of 20 (permalink) Old 04-14-2008, 01:19 AM
Bronco Info: 1995 ford XLT...K&N FIPKGEN2......BFG's MT SOON: Bassani Y-Pipe, bassani headers, high flow cat. ETC
i would not do it. for a couple of reasons; too cheap, sounds scetch, and SC's mess up your engine more than benefit your engine. as stated by one of the fellas on here...your going to have to tune your engine some more and spend a little more money on some stronger parts for your engine to handle the SC. my train of thought, if you dont have money to do it right, and it did not come with a SC from the factory....its not worth it. JUST my .02
If it sounds too good to be true.......it most likley is....sad but ture!
KPNorCalBronco95 is offline
post #20 of 20 (permalink) Old 04-14-2008, 12:05 PM
Swat's Avatar
A used Powerdyne could come in that cheap. The install doesn't take much. You got to find out what type of blower it is and how much boost is expected. More boost equals more tuning, larger injectors, bigger fuel pump and more expense. Still sounds cheap or maybe a great deal on a used unit.
Get more info!
01, Ranger Edge 4X4, 4.10's, 265/70R16, lowered, lightened, and with a Supercharged 4.0
Swat is offline
