'93 Manual Shift 4x4 Bracket broken off transfer case - Ford Bronco Forum
post #1 of 18 (permalink) Old 07-20-2008, 05:02 AM Thread Starter
rebel33382's Avatar
Bronco Info: '95 U-150 E.B. thats victim of salt, 5.8L E40D, 144k and counting. My proud $500 buck truck
This bracket broke, does anyone know the part number and could I get it anywhere else than the dealership? This is the bracket that the linkage connects to manually enagage 4wd to the transfer case
rebel33382 is offline
post #2 of 18 (permalink) Old 07-20-2008, 11:42 AM
Steve83's Avatar
Do some searching - this is a very common problem for shifters that don't get shifted or lubed often.
post #3 of 18 (permalink) Old 07-20-2008, 11:54 AM
Owned 20 Years
are you referring to the shifter arm that goes into the transfer case? The 4x4 shifter has a long linkage that connects to this arm?
post #4 of 18 (permalink) Old 07-20-2008, 01:17 PM Thread Starter
rebel33382's Avatar
yes the piece that goes into the transfer case with a big hex/allen looking bolt
post #5 of 18 (permalink) Old 07-20-2008, 02:51 PM
Try it now!!
kf4amu's Avatar
You should change to an electric t-case so you dont have all these problems...
kf4amu is offline
post #6 of 18 (permalink) Old 07-20-2008, 03:28 PM
Owned 20 Years
still not sure I am following you so bear with me. You mean this arm going into the Tcase (the one that looks brownish, with NO hex/allen bolt):
The ONLY hex/allen bolts I know of within the whole Tcase setup are the bolts for putting together the Tcase halves, and the hex bolts for the Tcase shifter to attach it to the side of the tranny:
this shows the shifter out of the truck, with hex bolts in it (actually they are a torq T50 IIRC), and they bolt to the side of the tranny into those 2 holes you can just see through the hole in the floor.
post #7 of 18 (permalink) Old 07-20-2008, 03:39 PM
Owned 20 Years
There seems to be a rash of manual Tcase goofiness lately.
But, I suspect in some of the instances it's just a matter of: "You can break anything if you pull on it hard enough."
post #8 of 18 (permalink) Old 07-20-2008, 04:54 PM
Steve83's Avatar
this shows the shifter....
...but it DOESN'T show the similar bolt on the OTHER side that holds the Aluminum casting to the steel plate. The one on which the shifter pivots.
post #9 of 18 (permalink) Old 07-20-2008, 05:55 PM
Owned 20 Years
That's true. Do you think he's talking about that bolt?
This is like a guessing game.
How bout some pics of what you broke and we can then respond on where to get what you need. None of this stuff is actually a "bracket that broke off the transfer case".
post #10 of 18 (permalink) Old 07-20-2008, 11:02 PM
Steve83's Avatar
Yeah, that's where it ALWAYS breaks. If the mechanism doesn't spin inside the tube, then all the sideways force goes onto that bolt, and the Aluminum snaps.
post #11 of 18 (permalink) Old 07-21-2008, 12:17 AM Thread Starter
rebel33382's Avatar
does that mean my transfer case is messed up, i just bought the truck and guy said it was working fine till this bracket broke??
post #12 of 18 (permalink) Old 07-21-2008, 12:50 AM
Steve83's Avatar
post #13 of 18 (permalink) Old 07-21-2008, 09:49 AM
Owned 20 Years
agreed. think I'm outta here, this one's another one I'll chalk up to my post #7.
post #14 of 18 (permalink) Old 08-04-2008, 04:16 PM Thread Starter
rebel33382's Avatar
yes, the cast aluminum piece is the part I need. I am trying to find it, dealership has their issues. They cant give me a part number for some reason. Would anyone know it off hand. or have one they would sell??
post #15 of 18 (permalink) Old 08-04-2008, 04:22 PM
Owned 20 Years
If you need the one I have pictured (for an e4od), you can take them the pic, but I'll tell you now it is very expensive from the dealer. It's unlikely someone has one on here they will sell (have not seen one for sale in quite awhile). A junkyard is your likely source, I was able to find one at a yard in Minnesota off a '97 F250 equipped with E4OD for $65, which is cheap.
post #16 of 18 (permalink) Old 08-04-2008, 04:26 PM
XDAILY's Avatar
Bronco Info: 1990 5.0 Eddie Bauer
SAS D44,D60,10"lift,42's,4.10's,AOD/E4OD internals,Custom Bumpers,Aussie,Lockrite,Home depot
snorkle,K&N,True Duals,Hedman headers,High Flow Cats,Cherry Bombs. Still going.
XDAILY is offline
post #17 of 18 (permalink) Old 08-04-2008, 04:36 PM
wik
wik's Avatar
Bronco Info: 1991 XLT 33" MT/r, 351,355s, Powertrax rear locker, aussie front, 4" BDS long arm, hefty sliders
This guy offers to rebuild the shifter linkage.
http://cgi.ebay.com/Rebuild-YOUR-For...742.m153.l1262
wik is offline
post #18 of 18 (permalink) Old 08-04-2008, 05:33 PM
white92's Avatar
Bronco Info: '92 5.0 XLT ZF5... 'n stuff
The dealer here in norcal wants like $230 for it, just fyi.
'92 Bronco XLT 5.0 ZF5
white92 is offline
