Sterling 10.25/10.5 Width Hub To Hub - Ford Bronco Forum
post #1 of 5 (permalink) Old 03-24-2009, 04:08 PM Thread Starter
MidlifeCrisisUndrWay
CDA 455's Avatar
Question Sterling 10.25/10.5 Width WMS to WMS
After searching and not finding answers, I ask these questions:
1) What is the width (WMS to WMS) of a Sterling 10.25/10.5 SRW axle?
2) What is the width difference (WMS to WMS) between the Sterling SRW and the 8.8?
3) Does/Has anyone ever run one without swapping out the front axle?
My rig: '94 Bronco XL; bone stock; 33X12.5 Goodyear MT/R on factory rims.
Through searching I've found that the spring perches are the same width on the Sterling SRW as my 8.8.
And that I need a VSS axle as well.
I also know that I'll need a pair of rims to deal with the 8 lug set up.
Thanks
μολὼν λαβέ
CDA 455 is offline
post #2 of 5 (permalink) Old 03-24-2009, 07:28 PM Thread Starter
CDA 455's Avatar
Anyone?
Bueller? Bueller?
μολὼν λαβέ
CDA 455 is offline
post #3 of 5 (permalink) Old 03-24-2009, 11:06 PM Thread Starter
CDA 455's Avatar
TTT
μολὼν λαβέ
CDA 455 is offline
post #4 of 5 (permalink) Old 03-25-2009, 12:19 AM
MikE2's Avatar
I can't answer your question exactally, but the width is pretty much the same between the 8.8 and 10.25 axle. If there is a difference its not enoufgh for you to notice. I don't know about the 10.5 axle, but its probably close too. If anything it may be slightly wider but not by much.
MikE2 is offline
post #5 of 5 (permalink) Old 03-25-2009, 07:38 AM Thread Starter
CDA 455's Avatar
O.K., that's a start. Thanks!
I plan on running my stock front axle with a 10.25/10.5 so I'm looking to match the offset of both sets of rims.
My Bronco is my DD and not used for any serious offroading.
μολὼν λαβέ
CDA 455 is offline
