E4OD to E4OD compatibility questions - Ford Bronco Forum
post #1 of 15 (permalink) Old 08-26-2009, 02:38 PM Thread Starter
Cobra Jet's Avatar
Bronco Info: 94 XLT, 5.0 GT40P engine, mass air, E4OD, 33's, etc.
Question E4OD to E4OD compatibility questions
I've been searching on here, but have not come up with a definitive thread or answers I am seeking...
Is there an online list or reference as to which E4OD's are compatible between the 1991-1996 Bronco's? I'm not interested in E4OD's from the F-Series trucks, specifically and only Broncos.
Was there any major differences and/or changes to either the transmission itself, the transmission's electronics OR the transmission ECU from 91-96?
For instance, will an E4OD from a 91 Bronco be a plug-n-play into a 93 Bronco w/ E4OD?
I've read that the MLPS sensor had some minor changes (more so just connector/wiring changes). I'm assuming this change has no bearing or effect on my questions (not unless someone wires it up wrong... LOL).
What about the E4OD trans linkage, did this change from 91-96, and if so, how?
How about differences between engines - meaning, is the 5.0 E4OD the same as the 5.8 E4OD?
- Phil
Click here for my eBay auctions
1994 Cobra coupe #0013, 2011 Genesis Coupe, 2011 Tucson GLS
Cobra Jet is offline
post #2 of 15 (permalink) Old 08-26-2009, 04:29 PM
Owned 20 Years
ya know, those are all good questions. Here is my answer based on opinion, not fact:
The E4OD meant for a smallblock v8 is the same, period. over the years there were "upgrades", but to my knowledge any of the years are totally interchangeable. many of the changes were either "programming" or internal "part" but to my knowledge it does not affect in any way being able to pull one from one model year and replace with a different year. From my vantage I'd never buy an older E4OD though since I'm starting from the '95 model year. There were also 2wd and 4x4 versions so I'm not sure if you're interested in going there? Only difference with those might just be the tailhousing and output shaft for attachment to the Tcase, dunno?
post #3 of 15 (permalink) Old 08-26-2009, 07:49 PM
gadawgz71's Avatar
I know there are 3 different casting numbers. I know that if you want to put a 95/96 E4OD into something older you need to remove your old solenoid and put in on the newer tranny so that you don't have to change connectors. The connectors were changed from 93-95. Thats about where my knowledge stops.
1996 Wht Sport MAF/OBD II 466-1995 Blk XLT 351
SOLD
1996 PG EB 351-1996 Wht EB 351-1996 Wht Sport 351-1994 Wht Sport 351
1996 MB EB, KR Interior 302-1996 Wht EB 351, 3" BL, 33's-1996 PG EB 351
1996 Wht/Tan XLT 351w-1996 PG EB 351-1996 Black Sport 408w, SAS, 40's
1995 Blk EB 351-1996 MB EB 351, 6", 35's-1996 Wht Sport 351-1996 PG EB 351
1996 M EB, 302, SAS D44-1995 Blk Sport-1990 302, M5OD, 3" BL, 33s
1996 Wht EB 351-1993 G EB 357w-1978 XLT 351m-1971 Sport, 331w, 4.5", 35's
gadawgz71 is offline
post #4 of 15 (permalink) Old 08-26-2009, 09:37 PM
the connectors were changed starting in 95 for both the mlp senser and the solenoid pack. other than that they are interchangeable. the internals were changed in 95 for the better but i dont have that kind of time right now....lol.....
lightning2fast@aol.com
E4OD's and 4R100's... Towing, Street and Comp valve bodies.
95 lightning... former bronco owner.
thePUNISHER is offline
post #5 of 15 (permalink) Old 08-27-2009, 11:35 AM
Cobra, did you buy another bronco?
Btw, I remember Steve83 having or posting some info on what the updates were. I think he did anyway?
Need4racin is offline
post #6 of 15 (permalink) Old 08-27-2009, 12:31 PM Thread Starter
Cobra Jet's Avatar
not yet, however, still looking around and hope to have one purchased by year end - so hopefully I'll be back in the FSB arena 100% again.
- Phil
post #7 of 15 (permalink) Old 08-27-2009, 12:57 PM
Service before Self
RescueBronc's Avatar
Bronco Info: 1988 XLT 393 Stroker. MAF All LED/HID 10.25 rear 4 whl disc 8 Lug/Chevy Hubs D44HD SAS E-Locker
The shift shaft and shift linkage changed in '92 with the body style change (and steering column change). The 90-91 E4OD had mechanical push rod linkage and then '92 and up has a shift cable. When I swapped in my E4OD to replace my C6 I used a '95 transmission. I had to change the shift shaft on the tranny and I had to fab up linkage (pushrod)....
"Service before Self So That Others May Live"
RescueBronc is offline
post #8 of 15 (permalink) Old 08-27-2009, 01:48 PM
good info!!! what about tail housings...where the xfer case bolts to....did they ever change throught the years? they are the same as the f-series correct?
post #9 of 15 (permalink) Old 08-27-2009, 02:23 PM
monkei's Avatar
Bronco Info: 1992 5.0 E40d 6"lift, MAF conversion in progress, 351 roller block waiting... much more
My 92 e40d has 8 wires running to it, a 94 e40d I took a buncha parts from had 9 wires going to different trans solenoids/sensors than my 92. Couldn't get it to shift right...
monkei is offline
post #10 of 15 (permalink) Old 08-27-2009, 02:26 PM
Service before Self
Thats what FSB is all about. Someone has been there, done that or swapped it in/out..
tail housings never changed for the 4x4s.... yes they are the same as the F-series...
post #11 of 15 (permalink) Old 08-27-2009, 02:27 PM
Service before Self
thats because the pinouts changed. You had to change the wires around in the plug. Nothing was added just changed locations of a some stuff...
post #12 of 15 (permalink) Old 08-27-2009, 11:33 PM
Bronco Info: 1992 Bronco, 6" lift, 35" Tires, 351, E4OD
I replaced my E4OD in my 92 Bronco with a 351, with a E4OD out of a 93 Bronco with a 302. Everything bolted right up, all electrical plugs plugged right in. Transmission works great. So to answer the question, are the transmissions the same on both the 302 and 351? Yes they are.
stinger is offline
post #13 of 15 (permalink) Old 08-28-2009, 01:57 AM
my bko ate my money
yoomooman's Avatar
Bronco Info: 92 Eddie Bauer Bronco 5.0, E4OD,MAF Conv, sixltre tune-up, OBA, on 31x10.50x15s
linkage in 92, planetarys were updated in 93-94, solenoid packs in 94....IIRC
all interchangable
92 Eddie Bauer bronco 5.0--Travis
Originally Posted by jopes
11:47 pm: hand pack it on the shaft. it's something you should be good at
Originally Posted by yoomooman
some bucks is better than no bucks!
yoomooman is offline
post #14 of 15 (permalink) Old 08-28-2009, 07:33 AM
all interchangable
nope the o/d planet was revised as well as the input shaft in 95 the solenoid connector was also changed but the solenoid body itself it identical......
post #15 of 15 (permalink) Old 04-01-2010, 09:32 PM
BeastBronk's Avatar
Bronco Info: 175k+ 92 Bronco, 351W,E4od, 35 x 12.50 x R15 Tires
all interchangable
Im looking at a tranny from a 91 F250 HD
How hard is it to change the linkage? Any special tool or rusty bolts that will break on me?
Also the trans is for 2wd, What needs to be done to make it work in my 4x4 Bronco?
92 Bronco, 351 Motor.
BeastBronk is offline
