Battery washer thingies, Do they work ? - Ford Bronco Forum
post #1 of 26 (permalink) Old 10-06-2009, 11:10 PM Thread Starter
MARBLE GARGLER!
351w500's Avatar
I just bought a new Interstate Megatron battery, But before I install it should I use those green and red terminal washers ? Do they really work ?
351w500 is offline
post #2 of 26 (permalink) Old 10-06-2009, 11:12 PM
F.O.T.M. - MAY 2014!!!
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs Daystar leveling kit
I would, if it prevents any problem its worth it to take a second and slip them on.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options. 4.10 gears LSD 33" MTs First ever Stock Fullsize of the Month...
J A S N http://www.supermotors.net/registry/19528
fartman is offline
post #3 of 26 (permalink) Old 10-06-2009, 11:14 PM
OOPS GIVE A DAMN IS BROKE
gearrat's Avatar
Bronco Info: 94 xlt 302. 4 in lift 3in body lift and 35's. 84 soon to have a 300-6 and np 435
some people say they do and other say they dont. i have never had any luck with them
94 bronco XLT
36x12.50x15 swamper tsl
tuff country 4" suspension lift
3 in PA body lift
http://azrockrat.4t.com/index.html
gearrat is offline
post #4 of 26 (permalink) Old 10-06-2009, 11:15 PM Thread Starter
MARBLE GARGLER!
351w500's Avatar
Fartman, Your entire reply is sig worthy-
351w500 is offline
post #5 of 26 (permalink) Old 10-06-2009, 11:22 PM
themike's Avatar
Bronco Info: 86 302efi t18 9in. rear 3g alt. electric fan sas and maf sitting on 33's with a sunroof
a cover would be better. The washers just let the dumb a$$ know which one is pos.(red) and neg.(grn./blk).
No Pavement? No Problem.
themike is offline
post #6 of 26 (permalink) Old 10-07-2009, 12:08 AM
Owned 20 Years
No, that's not all they are for. they have a chemical that is supposed to react and prevent corrosion. I always use them. Cover on the + terminal certainly doesn't hurt either.
post #7 of 26 (permalink) Old 10-07-2009, 12:10 AM
Cleaning the trails
Tony R's Avatar
Bronco Info: 96 Forest Service Retired 188K original miles on the odometer and still going strong
Get the anti-corrosion spray. It works. Along with the felt washers and you should have little corrosion problems.
Looking for So Cal West Coast AAT Volunteers
96 Fed Gov't Surplus 5.8L XL 4" BDS Lift
KI6FGI 146.520
Tony R is offline
post #8 of 26 (permalink) Old 10-07-2009, 12:13 AM
bwill's Avatar
Bronco Info: 1990 Retired Forest Service Bronco with the 302
I have used those felt washers. i still got corrosion. They didn't work for me but it has for others
bwill is offline
post #9 of 26 (permalink) Old 10-07-2009, 12:19 AM
HHH69's Avatar
Bronco Info: SOLD the F-150.
I heard that if you put a little bit of vaseline on the terminals, it prevents corrosion.
HHH69 is offline
post #10 of 26 (permalink) Old 10-07-2009, 12:31 AM
Bronco Info: 1995 5.8 E4OD. Rancho 4in.Ext. Radius Arms. 35x12.5 BFG Muds. Resi Shocks
NO. Sorry but I work at a 76 service station and 9/10 when we see a car with those things they are all corroded and nasty, once they get corrosion on them they tend to collect it and are then Junk, do yourself a favor and do like Tony said and get terminal protector spray, we buy ours from Napa and give the terminals a good shot every time and we've never had a car that had the spray come back with nasty terminals.
Oh and it may sound hokie but to clean the terminals we go to the stock room grab a bottle of Coke , pour it in a cup and let the Battery cables soak, you'll see the crud and corrosion float to the top and it will literally be smoking and bubbling, then follow up with terminal cleaner and protector.
-END RANT-
:EDIT: Oh by the way we sell Interstate batteries and IMHO they are great batteries with clean terminals they usually last 5-9 years
BB33's is offline
post #11 of 26 (permalink) Old 10-07-2009, 01:25 AM
I have never had any luck with the felt washers either. Get some protective spray (I use the CRC stuff) and some terminal covers and you're good.....
ranger1968 is offline
post #12 of 26 (permalink) Old 10-07-2009, 01:37 AM Thread Starter
MARBLE GARGLER!
351w500's Avatar
I'll get the spray, Thanks fellas-
351w500 is offline
post #13 of 26 (permalink) Old 10-07-2009, 03:06 AM
Seattle FSB's Avatar
I have always used the chemically treated felt washers in conjunction with Permatex Battery Protector & Sealer and I have never had any corrosion whatsoever.
Then again, I keep my battery and engine compartment clean and in good repair...
Seattle FSB is offline
post #14 of 26 (permalink) Old 10-07-2009, 03:36 AM
ViralBronko's Avatar
Bronco Info: 1994 FSB 351w 5.8
Forget about them they are worthless.
ViralBronko is offline
post #15 of 26 (permalink) Old 10-07-2009, 09:28 AM
Owned 20 Years
that's exactly what I do. I just think for folks having a problem it's a case of putting a batt in and forgetting it for a few years. I keep everything reasonably clean and there are no issues.
post #16 of 26 (permalink) Old 10-07-2009, 03:33 PM
I ♥ TTB
Weber's Avatar
If they are the good ones with the chemicals they are great. Corrosion is typically caused by a battery venting through the area were the post connects. The washers do a great job of trapping the gases and preventing corrosion... If you end up with a really gassy battery then eventually the washers will stop working... The spray works very well too...
Well try snatch next time.
Weber is offline
post #17 of 26 (permalink) Old 10-07-2009, 03:48 PM
JKossarides's Avatar
YES YES YES, use the red & green felts but make sure the cable ends are all the way down on the post so they touch the felts, they also prevent corrosion from spreading to the cables right there.....
I use anti-seize on the battery cable end and bolt threads to prevent corrosion BUT common sense would dictate that you will need to change felts periodically because they do get absorbed....
They're cheap enough for preventative maintenance.....
Good Luck ~
JKossarides is offline
post #18 of 26 (permalink) Old 10-07-2009, 04:20 PM
skaterbro's Avatar
Bronco Info: '93 F-150 XLT, 2WD, 302, E4OD
I've used em since i first got my truck. The PO didn't and the terminals were corroded to all hell. Once i got a hold of it i cleaned it up, had it charged and used the felt washers when putting everything back together. To this day, with the same battery, i still have zero corrosion.
As JK pointed out, they do need to be replaced a couple times a year.
skaterbro is offline
post #19 of 26 (permalink) Old 10-07-2009, 04:50 PM
Redneck Romeo
BigUgly88EB's Avatar
Bronco Info: SOLD.
I've never had a problem with the felt washers, and I've always been told to smear some dielectric grease on the "top" of them before installing the cables.
I figure they can't hurt, they're cheap as hell, so it's not like you're wasting a ton of money if they really don't do anything.
The last REAL SUV was built in 1996!
Chase
4" Rough Country, 130A 3G, RJM Battery Cables, Sixlitre Tune-Up, more to come!
Don't forget to vote for FSB!
BigUgly88EB is offline
post #20 of 26 (permalink) Old 10-07-2009, 08:28 PM
themike's Avatar
they are worthless yes they a treated with stuff to help. however the vapors are the main problem so the spray a cover or nothing and get a optima
themike is offline
