engine wont turn over after reinstalling transmission - Ford Bronco Forum
post #1 of 41 (permalink) Old 01-06-2010, 10:01 AM Thread Starter
corruption41's Avatar
Bronco Info: 1993 ford f-150 xlt 302 v8 E4OD
Question engine wont turn over after reinstalling transmission
Hey guys I'm kind of stumped right now. We just put my transmission back in a couple of weeks ago and I went to put the torque converter bolts back on and the engine wouldn't turn over, and we had it running before we took it out, so any suggestions are appreciated. Anyway my truck is a 93 f150 with the 302 and E4OD transmission. Thanks alot guys
corruption41 is offline
post #2 of 41 (permalink) Old 01-06-2010, 10:35 AM
Mud God - R.I.P.
Rockford514's Avatar
Bronco Info: 66,79,79,87
Are you sure the toque converter was in all the way?
Buddy
Rockford514 is offline
post #3 of 41 (permalink) Old 01-06-2010, 10:39 AM Thread Starter
Yes Rock we put the converter in turned it until it seated and turned it a lil more and put a straight edge to it and it was seated, could it be that my transmission is binding up, my grandpa says its just condensation in the cylinders.
post #4 of 41 (permalink) Old 01-06-2010, 10:51 AM
sackman9975's Avatar
Torque converter not fully seated.
You might think it is, but its not. If the studs of the converter went into the flexplate without pulling it into the flexplate once tranny was bolted up, then the converter is the problem. The studs should just barely be into the holes of the flexplate, then you reach in through the starter hole and pull the converter the rest of the way through.
sackman9975 is online now
post #5 of 41 (permalink) Old 01-06-2010, 11:18 AM
Big Six
AbandonedBronco's Avatar
That's what I'm thinking. It still sounds like the TC isn't fully seated. I accidentally did this on my car when I put the engine and tranny back together, and the engine would barely turn a 1/4" when I tried to start it. Took it apart, seated it correctly, and it fired right up.
March 2016 FOTM
Supermotors Pics
AbandonedBronco is online now
post #6 of 41 (permalink) Old 01-06-2010, 11:21 AM
Lick my balls
waltman's Avatar
When you say wont turn over, you mean if you try to turn the motor over by hand even it just wont...I would say torque converter is not fully seated, otherwise it is more likely an electrical problem
waltman is offline
post #7 of 41 (permalink) Old 01-06-2010, 11:30 AM
Shane C.'s Avatar
Bronco Info: 78 Bronco, FI 460/1995 RIP
X2. Could be something as simple as the starter not being wired in correctly. Or, the TC is not seated depending on what "wont turn over" means...
My other car has doors.
Shane C. is offline
post #8 of 41 (permalink) Old 01-06-2010, 11:35 AM
shad351's Avatar
Bronco Info: 90 fsb 5.8
Dont full tighten tranny bolts w/o tc engagaed or you crack front pump housing= BADDDDDDD NEWS>
shad351 is offline
post #9 of 41 (permalink) Old 01-06-2010, 11:44 AM
Simple test to confirm torque converter.
You said you can't turn the motor over to bolt the converter up. Well if you have one nut on the converter, take it off. Then push on the stud to see if the converter will slide back to the point where the stud is barely into the hole. If it does, then the converter isn't at fault. If it doesn't move back, then its bound up from the converter not setting into the front pump properly.
post #10 of 41 (permalink) Old 01-06-2010, 12:05 PM Thread Starter
Okay one more problem i accidentally striped the torque converter nut, And the transmission is tightened all the way, does this mean i ruined the pump? and it seems like im taking 2 steps foward and 3 back, plus this is my first vehicle to, but nonethe less its a great learning experince for a younger guy like myself,lol
post #11 of 41 (permalink) Old 01-06-2010, 12:10 PM
Lick my balls
waltman's Avatar
That clears nothing up for me as for my question, but you do have to remove the tranny now to retap the threads you stripped.
waltman is offline
post #12 of 41 (permalink) Old 01-06-2010, 12:20 PM Thread Starter
Oh sorry Waltman, and yes it wont turn over by hand,and no I mean I rounded the head off of the nut a little bit, sorry for the confusion of words, im sick so i cant think all that well right now.
post #13 of 41 (permalink) Old 01-06-2010, 12:25 PM
Stripped the nut as in rounded the edges? Or messed the threads?
Its hard to so if you ruined the pump, it is possible. Most guys that do this get lucky. Pray your one of those guys.
post #14 of 41 (permalink) Old 01-06-2010, 12:32 PM Thread Starter
Yeah Sackman as in rounded the edges off a little bit and I'm afraid to do anymore damage to it. Man I really hope I didn't mess anything up.
post #15 of 41 (permalink) Old 01-06-2010, 12:46 PM
Mud God - R.I.P.
Pray for luck ,lot of times the pump gets broke
Buddy
post #16 of 41 (permalink) Old 01-06-2010, 12:53 PM Thread Starter
dang it.... If the pump is broken, do you have to send it to a transmission shop, and if so I'm out of luck there,because I'm only 16 and don't have that much money. I guess I better start saving my pennies
post #17 of 41 (permalink) Old 01-10-2010, 02:43 PM Thread Starter
Ok guys i finally got it to turn over yesterday. Me and my cousin double teamed it with me at the flywheel and him at the crank bolt, so after we loosend it up it was turning over with just him on the bolt, now my question is i went to turn it over by hand again a little while after we did that and i cant turn it over again, If my torque converter wasnt seated would it turn over? and if not, i guess i let it sit for to long with out starting it.
post #18 of 41 (permalink) Old 01-10-2010, 02:49 PM
Lick my balls
waltman's Avatar
Take the thing apart already! If it takes two guys to turn over the motor, something just isn't right and it's very very likely the converter is not seated.
waltman is offline
post #19 of 41 (permalink) Old 01-10-2010, 02:57 PM
post #20 of 41 (permalink) Old 01-11-2010, 11:01 AM
Big Six
No. When I did mine improperly, the TC wasn't seated all the way, and that motor was JAMMED. I couldn't get it to turn over to save my life. I, too, thought it was something else. Replaced the starter (at least got a new starter out of it), starter solenoid, checked wiring, etc. But a improperly seated TC will jam the engine so hard it won't budge.
Finally pulled them apart, seated it correctly, and put it back together, and it fired right up the first try. Just be glad you don't have to do it in a compact front wheel drive car.
March 2016 FOTM
Supermotors Pics
