Heater Hoses - Ford Bronco Forum
post #1 of 31 (permalink) Old 01-23-2010, 12:44 AM Thread Starter
timmayh2's Avatar
Bronco Info: 1989 Bronco 4x4 302, 33" Goodyear All Terrains, Flowmasters 40 series, MSD Coil, 8.5mm Wires, SR C&R
Heater Hoses
I have two hoses coming from the passengers side firewall. I believe they have something to do with the heater for inside the cab. But these hoses are cut and left hanging. What looks like the same size hoses next to them are together in a loop like someone cut the original setup from the firewall and just put them together. Any ideas Cause my heater doesnt work. Searched but couldnt find pictures to explain why its like that. Pictures of what it should look like under the hood on an 89 EB 302 would be great. Thank you.
....[____] "Its cool I've got skid plates"
_=()||||||| ()=_
|x|* ....... *|x|
|X| ----O--|X|
|x|_______ |x|
timmayh2 is offline
post #2 of 31 (permalink) Old 01-23-2010, 01:17 AM
Roller rockers are gay
TheUnforgiven's Avatar
those are your heater hoses for your heater core. the heater is is probably leaking (i'd bet $10 on it) and the PO just looped the heater lines because he didn't want to fix it. i'd bet he didn't fix it because he thought it was a horrible job involving the entire dash coming off, 6 hour job.
it ISN'T! you can have it done in an hour TOPS! from draining the coolant, to having the coolant system burped of air, and nice hot heat. easy to do, and cheap. get new hoses while your at it, and fresh coolant. there are a couple of write-ups on how to change it.
New nuts are in the plan.
TheUnforgiven is offline
post #3 of 31 (permalink) Old 01-23-2010, 01:22 AM
Redneck Romeo
BigUgly88EB's Avatar
Bronco Info: SOLD.
When you say the heater doesn't work, you mean it blows air but it's not hot?
I don't have any pics, but I'm betting it went something like this, if I understand you correctly:
Heater core started leaking all over the passenger side floorboard, so rather than fixing it right, they cut the heater hoses and tee'd them together.
Take a piece of your heater hose to the parts store and ask for about 10 feet of it. IIRC, the upper connection on the passenger side of the water pump goes to the upper connection on the heater core. Lower to lower.
If you discover you've got a leaky heater core, don't freak out. on the '87-91 trucks, they're easy as hell to change.
EDIT: Damn, Bri_Guy beat me to it.
The last REAL SUV was built in 1996!
Chase
4" Rough Country, 130A 3G, RJM Battery Cables, Sixlitre Tune-Up, more to come!
Don't forget to vote for FSB!
BigUgly88EB is offline
post #4 of 31 (permalink) Old 01-23-2010, 02:05 AM Thread Starter
timmayh2's Avatar
Well right now much heater doesnt blow any air at all. I dont think cold a/c either...
_=()||||||| ()=_
|x|* ....... *|x|
|X| ----O--|X|
|x|_______ |x|
timmayh2 is offline
post #5 of 31 (permalink) Old 01-23-2010, 11:18 AM
Forward Some Money
j. r. Nice's Avatar
Not a close up - but the blue lines on the passenger side are the heater hoses.
PIC
j. r. Nice is offline
post #6 of 31 (permalink) Old 01-23-2010, 03:12 PM Thread Starter
timmayh2's Avatar
Yeah those are the hoses im talking about...and where did you get your hoses?
_=()||||||| ()=_
|x|* ....... *|x|
|X| ----O--|X|
|x|_______ |x|
timmayh2 is offline
post #7 of 31 (permalink) Old 01-23-2010, 03:21 PM
Seattle FSB's Avatar
Seattle FSB is offline
post #8 of 31 (permalink) Old 01-23-2010, 03:21 PM
Forward Some Money
j. r. Nice's Avatar
Summit Racing.
post #9 of 31 (permalink) Old 01-23-2010, 03:24 PM Thread Starter
timmayh2's Avatar
Man I was looking just to replace those hoses not everything in the engine bay Need more money in the pocket book
_=()||||||| ()=_
|x|* ....... *|x|
|X| ----O--|X|
|x|_______ |x|
timmayh2 is offline
post #10 of 31 (permalink) Old 01-23-2010, 03:29 PM
JKossarides's Avatar
You can buy those heater hoses in any auto parts store and not expensive along with replacing the heater core, I agree it's not a hard job by any means,.....
Don't forget to check the condition of the T-Stat and Radiator cap......AND while you're at it, why not backflush the cooling system with just plain water FIRST before you install the new HC and wash the radiator/heater hoses in Tide if they're reusable and you'll have really nice heat....
backflush procedure:
remove the radiator cap and disconnect the lower radiator hose and with a garden hoses in the neck to refill, run the engine for 10 minutes or so until clean water comes out.....in most cases you should run the heater on high but that may not work in this instance so NBD.....top off with a good quality anti-freeze for your region and you're good to go...
You should perform this once a year, don't forget to wash out the over-flow tank.....
Good Luck ~
JKossarides is offline
post #11 of 31 (permalink) Old 01-23-2010, 03:41 PM
Bronco Info: 87FSB, 302 020 over ,3g alt, GT40 heads, Exp intake , Bassani Exhaust and 24" Magnaflow muffler
Good Luck ~
if you run the engine with the lower hose off for 10min, you will probably over heat the motor. The water enters the block from the bottom and discharges form the top hose.
Take the top hose off, drain the radiator add new clean water and run the engine with the a garden hose in the top fill tube.
Once the engine get to temp, it will open the tstat and discharge the water from the block/head. Let this happen until fresh clean water from the radiator enters and all green or orange coolant has been eliminated.
Once your satisfied, cut motor off. drain the radiator, reattach top hose, and then add the proper mix of your choice of water and coolant.
broncoflorida is offline
post #12 of 31 (permalink) Old 01-23-2010, 05:14 PM Thread Starter
timmayh2's Avatar
I will make sure to do this flush also. I replaced my radiator fluid like 2 months ago and did the same thing. Thanks. Anyone have a link to this heater core install?
_=()||||||| ()=_
|x|* ....... *|x|
|X| ----O--|X|
|x|_______ |x|
timmayh2 is offline
post #13 of 31 (permalink) Old 01-23-2010, 07:31 PM
I hate todo this to you, but search in the tech forum. A few have just recently place heater core changes.
It's one of the easiest thing todo. Just remove the 2 heater hoses ( 3/4" iirc ) at the firewall. Go inside and open your glove box door and dis engage the arm.
Once the door is out of the way, you should 4-5 screws if my memory serves right, remove those screws, and pry the heater core out. Clean out the area , apply some sealant.
And finally reverse the install process. it should be no more than 30mins or so.
post #14 of 31 (permalink) Old 01-23-2010, 07:47 PM Thread Starter
timmayh2's Avatar
That works for me thanks. Sounds super simple
_=()||||||| ()=_
|x|* ....... *|x|
|X| ----O--|X|
|x|_______ |x|
timmayh2 is offline
post #15 of 31 (permalink) Old 01-23-2010, 10:53 PM
Owned 20 Years
I believe these are what you need:
http://www.summitracing.com/parts/GTR-65071/
they do make a 3/4" ID but I put a dial caliper on my fitting down by the alternator and it measured .65ID/ .95OD and the link I show is for a hose .625 ID and .91OD so that seems proper size for me, and what I am looking to buy as well.
note the price, $5 spot and change should do both hoses.
They do make the pretty blue hi miler as well, but the same 6' of hose will be $19 and change.
Edit: apparently you can skip the shipping and buy at autozone...another site mentions you can buy 6' of the 65071 for $6 at da zone.
anudder edit: da zone does have the above, but there number is H0508 for the standard black goodyear hose in stock., $5.99 here. Going to try and get this tomorrow. They can special order the blue stuff, it shows $22.99 for the same 6'. It is better, but seeing as my Motorocraft stuff has not failed me in 15 yrs. I don't need that.
post #16 of 31 (permalink) Old 01-23-2010, 11:19 PM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
if the fan also does not work your going to need to trouble shoot it and see if it's getting power or the blower motor is dead.
Let's Go Fishing.
jopes is offline
post #17 of 31 (permalink) Old 01-25-2010, 06:43 PM
Not if the oil level is up and engine is FULL of old coolant, basically at cold operating temp....
If you disconnect the top radiator hose the coolant will piss out all over everything making a real PITA mess.....the lower hose can be can be disconnected from the radiator and pointed downard and out of the way.....you just let the engine IDLE for a few minutes to circuate thru the radiator and heater core but REFILLING thru the radiator neck so the level doesn't get low enough to cause a problem......going thru the top radiator hose draining from the radiator petcock takes way too long.....drain -refill -drain -
I've never had a problem doing it this way but do whatever makes you happy as long as the engine gets BACKEDFLUSHED.........lol lol
Good Luck ~
post #18 of 31 (permalink) Old 01-25-2010, 07:04 PM
Owned 20 Years
Good Luck ~
I think what he is saying is....top hose hot, bottom hose cold.
So, by your method of taking off the lower hose, any water you put in the radiator will not circulate into the motor and heater core, but rather just piss out the bottom.
So you start motor, it warms, and once the Tstat opens all fluids go into radiator and drain out the bottom, and you have not be introducing any new fluid into the motor/heater core, you've just put water in the radiator which goes down and pisses out the bottom.
post #19 of 31 (permalink) Old 01-25-2010, 07:56 PM Thread Starter
timmayh2's Avatar
Yes im thinking that disconnecting the lower hose and trying to fill the radiator neck will not be very effective because it will just leak out of the bottom of the radiator.
_=()||||||| ()=_
|x|* ....... *|x|
|X| ----O--|X|
|x|_______ |x|
timmayh2 is offline
post #20 of 31 (permalink) Old 01-25-2010, 07:57 PM
Well shittttttt maybe I am doing it wrong now that you put it that way, so all I've been doing is just draining the block and flushing the radiator .........what a MAROOOOOON.....
Next time I'll do it your way.......
Live and learn, why we're all here for the little things.......lol lol
