351W Timing Chain/Gear Drive - Ford Bronco Forum
post #1 of 31 (permalink) Old 02-15-2010, 01:41 PM Thread Starter
LS SWAP EVERYTHING!
Red91XLT's Avatar
Bronco Info: half a bronco
Okay, I have a 1994+ 351W in my 1991 with a bad timing chain. I am considering replacing it with a Gear Drive instead of a double roller. I have heard the arguments over the noise that it makes (Remember the last thread on this, Gacknar's "WRRRRRRRRRRRRRRRRRRR" ... lol) and I'm willing to live with it.
The only thing that's making me hesitant to just go ahead & buy one is this.
Originally Posted by SummitRacing
Our SummitŪ gear drives are great for you folks who want better timing and a choice of "noisy" or "quiet" operation. Their dual-idler design has CNC-machined components and they are easy to install. Each set comes with a pressed-in Torrington bearing or an SAE 660 bronze thrust washer (varies by application), as well as a cam gear that allows for timing adjustments in two-degree increments. These drives fit under your stock timing cover and come complete with instructions. Minor machining is required on models with the bronze thrust washer.
http://www.summitracing.com/parts/SUM-G6711-Q/
Does anyone know if my engine is (or probably does) have a bronze timing gear? Is there any way to tell without pulling the timing cover off? I'd rather not have to tear into it until I have replacement parts, but I may have to.
Also, what kind of Machining is necessary if I do have a bronze thrust washer? What kind of money am I looking at spending, and would I have to pull the engine to have it machined (I'm almost positive I would)?
'91 XLT-totaled
This is not a Democracy, it is a Broncocracy
You do realize that you just reported the new owner of FSB?
-James
Red91XLT is offline
post #2 of 31 (permalink) Old 02-15-2010, 01:59 PM
Bronco Info: 1989 4X4 351W C-6 3.54/3.55
If your engine is wore to the point that it needs a new timing chain set, you got's bigger fish to fry that what type of cam drive to use. Save your money for upcoming repairs, install a Clowes True Roller chain set and be done with it.
Just my 02 .
DGW
1989 Bronco 4X4 351W EFI C-6 3.54/3.55 Gears.
DGW1949 is offline
post #3 of 31 (permalink) Old 02-15-2010, 02:08 PM Thread Starter
LS SWAP EVERYTHING!
Red91XLT's Avatar
If I go with a double roller chain, it will be a Cloyes true roller. The 1994+ 351W are Hydraulic Roller Cam engines and require a steel dizzy drive gear as the the camshaft is made of a harder tool steel. My truck has destroyed two cast iron dizzy gears and it's been due to timing chain slack. Engine still runs damn strong for having a bad timing chain, but it needs to be replaced.
'91 XLT-totaled
-James
Red91XLT is offline
post #4 of 31 (permalink) Old 02-15-2010, 02:15 PM
sackman9975's Avatar
James, save your money and just get another chain and gear set.
sackman9975 is offline
post #5 of 31 (permalink) Old 02-15-2010, 02:20 PM Thread Starter
LS SWAP EVERYTHING!
Red91XLT's Avatar
Think so, Scott? I guess you know best
'91 XLT-totaled
-James
Red91XLT is offline
post #6 of 31 (permalink) Old 02-15-2010, 02:29 PM
Yes. A new chain will go another 150k plus. You honestly think the motor will hold up that long? It just might, but save that money to make it better. A gear drive isn't gonna give you any more power than the chain. It'll be more accurate later in life, but really, save the cash. The chain went tired, the motor will too someday.
post #7 of 31 (permalink) Old 02-15-2010, 02:36 PM Thread Starter
LS SWAP EVERYTHING!
Red91XLT's Avatar
I know I need a rebuild, but you know me... money's always an issue LOL... Hopefully, I'll find higher paying work in the spring and make enough to start the rebuild and lift process.
Any particular chain & gear set you recommend?
I was looking at this one: http://www.summitracing.com/parts/CLO-9-3535X9/
'91 XLT-totaled
-James
Red91XLT is offline
post #8 of 31 (permalink) Old 02-15-2010, 02:54 PM
Clowes true rollers are nice, but honestly I'd go to O'rielys or Napa and just pick up a double roller chain. I wouldn't even worried about it being a "true" roller. Last one I bought was like $40 (O'rielys). That will suite you just fine.
Now, make sure when your scraping your gaskets off the block to stuff some rags into the oil pan opening to catch debris from causing a major meltdown after its all back together. Use a shop vac to suck all the debris off the rags before removing the rags.
post #9 of 31 (permalink) Old 02-15-2010, 03:00 PM Thread Starter
LS SWAP EVERYTHING!
Red91XLT's Avatar
I'd like to go with a Billet Steel cam gear if it all possible, but I have nothing against Napa parts. Stranger things have happened to me and I may not be able to afford a rebuild when I like, so I'd really want to insure maximum life of the timing chain and gears. Wonder if napa carries one with a billet steel cam gear?
'91 XLT-totaled
-James
Red91XLT is offline
post #10 of 31 (permalink) Old 02-15-2010, 08:32 PM
Bronco Info: 1995 5.8 E4OD. Rancho 4in.Ext. Radius Arms. 35x12.5 BFG Muds. Resi Shocks
http://www.summitracing.com/parts/CLO-C3057K/
Cloyes Brand - Check
Double Roller - Check
Billet Steel - Check
Affordable? - Damn Straight
Same on I'm putting in my rebuild and was recommended to me by two seprate engine builders with a combined 60 years experience.
BB33's is offline
post #11 of 31 (permalink) Old 02-15-2010, 10:43 PM Thread Starter
LS SWAP EVERYTHING!
Red91XLT's Avatar
I saw that one, it was first choice, but cam sprocket's cast iron.
'91 XLT-totaled
-James
Red91XLT is offline
post #12 of 31 (permalink) Old 02-15-2010, 10:52 PM
Satyr of the Midwest
SigEpBlue's Avatar
I like the Sealed Power stuff myself. OE quality, easy to find.
SigEpBlue
SigEpBlue is offline
post #13 of 31 (permalink) Old 04-13-2010, 07:35 PM
95F1504x4EB's Avatar
Bronco Info: 1995, F150, MAF 5.0L, 4R70W, BW 1356, 3.31 gears, 31x10.50s, 130A 3G, Saginaw, Eddie Bauer Edition
I was just on Cloyes website and they say "Sprockets Are Made From High Alloy Steel". Do we "have" to have a steel cam sprocket on the roller engines?
I am gonna be replacing my timing chain when I go in to replace the leaking timing cover gasket on my 95. I was also thinking about getting the OE replacement Cloyes C3057K double roller set.
I've been reading some old threads and some have said that the "true" roller chains stretch too fast. Does this apply to the OE replacement chain above?
Would there be any advantage in going with the Cloyes C3206 silent type chain, or is it garbage?
My engine is stock and will be for a while. Thanks.
95F1504x4EB is offline
post #14 of 31 (permalink) Old 04-13-2010, 09:01 PM
I perfer the edelbrock street legal setup. Cost form summit is around $45-50 dollars.
broncoflorida is offline
post #15 of 31 (permalink) Old 04-13-2010, 09:38 PM
SigEpBlue's Avatar
This is the old-style Morse chain link. They're preferred on a daily driver, for durability and noise reasons, IME.
SigEpBlue
post #16 of 31 (permalink) Old 04-15-2010, 03:25 AM
Ex Navy Nuke
RLKBOB's Avatar
Don't put gears on, stick with a chain. I put on a true roller setup when I built my 351 and had to modify my cam thrust plate. Easy and didn't cost a thing. Here's some pics to show you exactly what needs to be done just FYI.
here's what it looks like stock
This view shows the cam gear won't go on all the way b/c the torrington bearing is hitting the thrust plate bolt heads.
Here's the thrust plate after machining, just need to countersink the holes.
installed and everything went together fine.
Bob Kulhanek, My Superford
RLKBOB is offline
post #17 of 31 (permalink) Old 04-15-2010, 05:21 AM
SigEpBlue's Avatar
Groovy mod, Bob. So simple, it makes me wonder why Ford didn't do that in the first place.
SigEpBlue
post #18 of 31 (permalink) Old 04-15-2010, 10:46 AM
MARBLE GARGLER!
351w500's Avatar
Why is billet better than iron when it comes to the gears anyways, isn't it the actual timing chain that goes ta hell ?
351w500 is offline
post #19 of 31 (permalink) Old 04-15-2010, 12:41 PM
The thing here is that wear metals have to be compatable or you'll experience premature failure of one (or more) componants. Hence your need to keep replacing distributor gears.
You may also note that even when these metals ARE compatable, the action of one part riding, rubbing, sliding against and/or rolling across the other establishes a wear pattern on both. That wear pattern WILL effect the service life of one componant IF we replace it and not the others. In other words, it is prudent to replace your timing gears & chain as a set. And FWIW...no, it aint just the chain that wears. Gears wear too. In fact, if you install a new chain onto the old gears, the new chain will not have proper tooth contact which in turn will cause the little rollers to wear out faster than before.
Far as modern timing chains needing a steel gear goes...yes they do. Otherwise, as you have seen with your steel cam & iron distributor drive, the steel will eat-up the iron.
If I seem to be repeating myself here, it's 'cause I am. Reason is, this is important stuff to know when we set about selecting engine parts, replacing wheel bearings, power train parts, gears and stuff.
Hope this helps.
DGW
DGW1949 is offline
post #20 of 31 (permalink) Old 04-15-2010, 01:08 PM
The Anti Yam!
Gacknar's Avatar
Am I missing something here
Ohhhh....
And by the way.....
WHRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!!!
What??? I can't hear you over the sound of how cool my gear drive is!!
I just ran a standard double roller from Crane on mine.
The Greatest Thread on FSB
Gacknar is offline
