89 bronco is not getting fuel! HELP!!! - Ford Bronco Forum
post #1 of 24 (permalink) Old 06-06-2010, 09:40 PM Thread Starter
Unhappy 89 bronco is not getting fuel! HELP!!!
I just bought a 89 bronco i thought it was the fuel pump i repalced it and the fuel pump relay but she is not priming! fuel pressure test resulted in no pressure! I checked the inertia switch to but still nothing! what could make it do this???
gates6297 is offline
post #2 of 24 (permalink) Old 06-06-2010, 09:43 PM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
you try searching? your fuel system has 2 fuel pumps and 2 filters.
Let's Go Fishing.
jopes is online now
post #3 of 24 (permalink) Old 06-06-2010, 09:49 PM Thread Starter
? it has two pumps one in tank thats the one i replaced and one on the frame rail. only one filter right after the pump on the frame
post #4 of 24 (permalink) Old 06-06-2010, 10:04 PM
BroncoRN's Avatar
Bronco Info: 1988 F150 4x4 302 M5OD 3.55
could be PCM relay as well. did u pull codes?
1991 F250 4x4 HD - sold
1988 F150 4x4 - sold
1989 Bronco - sold
2000 Ford Excursion V10 - current
BroncoRN is offline
post #5 of 24 (permalink) Old 06-06-2010, 10:16 PM Thread Starter
pcm relay??? and tried to with the check engine light and could not do it!
post #6 of 24 (permalink) Old 06-06-2010, 10:16 PM
jfritts's Avatar
Bronco Info: Broncos are for chumps
check and make sure you are getting power to the pumps before you toss more parts at it
[gijoe4500] 5:34 pm: I'm an IDIOT.
[RebelRider2010] 8:25 pm: Yes Josh's Brother. I am Nancy.
Bronco Rebuild
jfritts is offline
post #7 of 24 (permalink) Old 06-06-2010, 10:23 PM
gone fish'n
jopes's Avatar
there is another filter between the 2 pumps.
Let's Go Fishing.
jopes is online now
post #8 of 24 (permalink) Old 06-06-2010, 10:34 PM
sackman9975's Avatar
PCM relay = EEC relay
Chances are if you couldn't pull the codes, then your EEC relay is at fault. The EEC relay supplies the power to the fuel pump relay. Check the fuel pump relay for constant power and ignition power (supplied by the EEC relay).
sackman9975 is online now
post #9 of 24 (permalink) Old 06-06-2010, 11:47 PM Thread Starter
I am getting power to both pumps about 8 volts! and no just one filter! tried to test the pumps off the eec but nothing happened!
post #10 of 24 (permalink) Old 06-06-2010, 11:49 PM
gone fish'n
jopes's Avatar
hey, your right, wtf do I know about broncos. I mean being around them for over 15 years, I am still just learning where the ignition key goes.
Let's Go Fishing.
jopes is online now
post #11 of 24 (permalink) Old 06-07-2010, 01:00 AM
SandStallion's Avatar
Location: Santa Maria Ca., right close to pismo Dunes. :)
Bronco Info: 1990 Bronco XLT. 4in. New and Improved 5.8L sand lovin' machine.
if there is only 8v going to the pump or pumps, i think filter location or quantity is irrelevant. have your battery load tested, and make sure the connections are clean. then start checking voltage input and output at your EEC and Fuel Pump relays. Bad contacts inside of a relay can cause a voltage drop. If you have low input voltage to the relay your going to be looking at a resistance problem in the wiring.
Support your local Mobber.
SandStallion is offline
post #12 of 24 (permalink) Old 06-07-2010, 01:58 AM
Bronco Info: 1991 EB 5.8l, 1995 xlt 5.8, 1995 EB 5.8
I was only getting 7.xxx amount of volts back at the pump. I also had the same going into and out of the fuel inertia switch. So, I jumped it at the EEC test connetor and it still wasnt working. Then went further on and cut the + and - wires a foot or so before the pump and spliced directly to the battery. Pump still did'nt work, so replaced the in tank pump and what do ya know....works like a champ. I dont have any other electrical issues, so idk, maybe theres some sort of resistor in the relay. (I replaced it twice while I was dealing with my pump issue)
Edit: After thinking about that overnight, the lower voltage was probably the result of the bad pump. (fried pump, fried internal connections)
dougc767 is offline
post #13 of 24 (permalink) Old 06-08-2010, 07:16 PM Thread Starter
It had both constant power and igniton power!
post #14 of 24 (permalink) Old 06-08-2010, 07:49 PM
Spectre's Avatar
Bronco Info: 78 Bronco 400/C6
Pull off the line after the in tank pump and blip the key. See if the pump is pumping.. If it is do the same thing at each connection in the fuel line until no fuels comes out.
Vic - W6VIC
1978 Ranger Bronco XLT 400/C6 with only 33's =(
2001 F250 - 6" SL. 37" tires Goliath
2007 Yamaha R1 Ricochet
Spectre is offline
post #15 of 24 (permalink) Old 06-09-2010, 12:19 AM
gone fish'n
jopes's Avatar
if your not getting full 12 vdc to both pumps you will never get enough fuel pressure.
you can check your fuel pressure at the fuel rails on the engine.
if you have 40 psi and both pumps are getting 12vdc you have something other than a fuel problem
if you have 12vdc at both pumps and both are running, but still do not have 40 psi or any pressure, you either have a bad fuel regulator, no fuel in your tank, or a plugged filter.
Let's Go Fishing.
jopes is online now
post #16 of 24 (permalink) Old 06-09-2010, 01:25 AM Thread Starter
no fuel pressure at all!
post #17 of 24 (permalink) Old 06-09-2010, 02:21 AM
Spectre's Avatar
Did you do like I told you and disconnect the fuel line from the in tank pump to see if gas is squirting out?
Vic - W6VIC
Spectre is offline
post #18 of 24 (permalink) Old 06-09-2010, 07:43 AM
gone fish'n
jopes's Avatar
he is better off taking it to a mechanic who might know what he is doing.
Let's Go Fishing.
jopes is online now
post #19 of 24 (permalink) Old 06-09-2010, 11:21 AM
Spectre's Avatar
True.. My suggestion is one of the basic things to check and if he's ignoring it and not doing it, then
Vic - W6VIC
Spectre is offline
post #20 of 24 (permalink) Old 06-09-2010, 06:48 PM Thread Starter
nothing is squirting out bud! and it will if i hot wire it from battery to fuel pump on fram rail! both will squirt out !
