Camber Bushing and Ball Joint - Ford Bronco Forum
post #1 of 7 (permalink) Old 08-09-2011, 01:47 PM Thread Starter
Bronco Info: 1995 Eddie Bauer, 302 FI, SixLitre Ignition Upgrade, Bassani Headers,Bassani Y pipe 3 " exhaust
I need some advice after installing new ball joints and the Moog adjustable cam bushing. My bushing does not seat all the way down on the knuckle like in this photo from another thread (first and third photos). camber jacked after balljoint swap
After thinking about it some more - Do I need to loosen the ball joints to drop down the BJ's and then get the bushing set properly. Then torque the upper BJ first?
Also, Does anyone have the proper torque specs for the BJ's?
I know I tightened up the lower BJ first, so maybe that's my problem?
NitroMan23 is offline
post #2 of 7 (permalink) Old 08-10-2011, 12:09 AM
omp
Bronco Info: 96 302, 5spd, 4" lift home made with custom deavers coils, hefty shackle flip
I have a similar situation but after I measured and compared stock bushings noticed that moog ones are a bit longer
omp is offline
post #3 of 7 (permalink) Old 08-12-2011, 09:32 PM
mouzer1's Avatar
Bronco Info: 1989 Bronco XLT. 4" ProComp lift
Help
I have a some what similar issue. I am going to replace my ball joints with the Dana bj's from Bronco Graveyard. They come with camber adjusters but do not indicate what degree. I had my Bronco aligned recently and they said I needed a 2 degree cam kit. Will the adjuster that came with the ball joints work or do I need another kit? Please help, I am going to do the ball joints tomorrow... Thanks
Cameron
89 Bronco
351
4" Pro Comp Lift
mouzer1 is offline
post #4 of 7 (permalink) Old 08-15-2011, 10:55 AM Thread Starter
I think you need the kit. Especially since you have the lift.
post #5 of 7 (permalink) Old 08-15-2011, 08:59 PM
95F1504x4EB's Avatar
Bronco Info: 1995, F150, MAF 5.0L, 4R70W, BW 1356, 3.31 gears, 31x10.50s, 130A 3G, Saginaw, Eddie Bauer Edition
You need to get a Haynes Repair Manual if you are doing these types of repairs on your rig.
1. Place the camber bushing in in the axle beam at the correct orientation.
2. Lift the knuckle into place and tighten the lower BJ nut to 35-40 ft. lbs with loctite.
3. Tighten the upper nut to 85-100 ft. lbs. and continue tightening until the hole in the BJ aligns with the castle nut, then install the cotter pin.
4. Tighten the lower ball joint nut to 95-110 ft. lbs
5. Install axleshafts, spindles, brakes....
95F1504x4EB is offline
post #6 of 7 (permalink) Old 08-16-2011, 11:57 AM Thread Starter
Thanks for the responses. My ABS light is on so one of my sensors is foobar.
I figured I would have to go back and do it again. This helps a lot.
post #7 of 7 (permalink) Old 08-16-2011, 06:17 PM
mouzer1's Avatar
You were right, the camber adjusters that come with the Dana Ball joints are only 1 degree. i ended up getting a kit from Napa that allows adjustment from 1.75 degree to 3.25 degrees. Expensive liitle guys ($35 each) but at least I don't have to worry about not having the correct size.
Thanks for the support
mouzer1 is offline
