Any differences in E4OD transmission? - Page 2 - Ford Bronco Forum
 6Likes
post #21 of 27 (permalink) Old 01-14-2016, 02:00 PM
@covijes - you really shouldn't start two threads on the same subject - maybe one of the mods will merge them.
Mikey350 is online now
post #22 of 27 (permalink) Old 01-14-2016, 02:20 PM
sackman9975's Avatar
But he's only started one... he posted here first, then I recommended for him to start his own thread as his problem didn't match this thread's title
sackman9975 is online now
post #23 of 27 (permalink) Old 01-14-2016, 03:47 PM
I saw his other thread first. I just wanted to have all the possible help in one place. Maybe put the Diagnosis Thread you posted in his other post?, sometimes folks actually do search, and maybe they'll find that write up. It looks pretty inclusive.
sackman9975 likes this.
post #24 of 27 (permalink) Old 01-21-2016, 01:09 AM
chakakan's Avatar
Bronco Info: 79 XLT 351M (sold) 1978 FSB 351M (sold) 1995 FSB OJ edition (sold) current 1996 XL 5.8
Transmission
Ok guys I am confused. Could someone dumb this down alittle for me. I have 2 Broncos.....a 1995 XLT 302 with a automatic (assume E4OD) 105K miles and a 1996 XL 351 with a automatic..210K miles. Can I pull the trans from the '95 and put it in the '96? The '95 body is toast so I bought this '96 with a clean body.
chakakan is offline
post #25 of 27 (permalink) Old 01-26-2017, 12:42 PM
Since this thread was brought back to life I have some questions that follow along the lines of the original title.
I understand the differences in the bell housing bolt pattern, that there were various updates along the way, and the gear ratios are the same.
When it comes to the internals, is there any difference between the big block, small block, or diesel variations? Could I physically build a small block version to the same specifications as a diesel version?
1990 Eddie Bauer Bronco
scparrish is offline
post #26 of 27 (permalink) Old 01-26-2017, 12:56 PM
It would seem your question has already been answered:
Originally Posted by thePUNISHER View Post
this is not true. the 4.9-5.0 e4od is identical. the 7.5 and 5.8 are also the same.
the difference between these is:
forward clutch:
5.0 3 plates
5.8 4 plates
direct clutch:
5.0 3 plates
5.8 4 plates
this actually is a big difference and significantly contributes to a difference in durability. if youre on the hunt for a small block e4od get one from a 5.8
all your builder has to do is get a 4 plate forward drum and 4 plate direct drum and you got yourself a 5.8 unit. did he do this??? youll have to ask him. i ilterally wont use the 3 plate drums in any rebuild regardless of what its going behind......but usually i use a diesel direct drum. this will hold 5 full thickness plates but they are hard to find and expensive...
This makes me wonder though, if its worth saving anything else out of the 5.8 variant, or if 100% of the rest is the same.
Reading this has made me decide not to sell my 2wd 5.8 E4OD but rather strip it for parts, so when my 5.0 E4OD craps out, i can rebuild it with the bigger clutches.
reptillikus is offline
post #27 of 27 (permalink) Old 03-20-2017, 05:52 PM
rgvbroncs's Avatar
Not sure if you can help , but i have a 94 bronco and transmission went out, ive got a 96 donor and was wondering what if any needs to be changed for it to be compatible and work on my 94
rgvbroncs is offline
