I have searched and searched threads/posts but some final opinions on my possible build. Long story short my SAS once again has to be put on hold. I am in the middle of my paint/body work and have the front clip off. So I might as well and pull the engine to fix the oil pan and rear main leak. But why do that when I can freshen up my engine. Runs good with 188,000, just leaks fluid and would like a little more oomph. I need to keep cost down to because I am also doing the paint etc, so I figured on this: BBK under drive pulleys; GT40P heads; Edlebrock truck Performer lower/upper intake; stock cam; new oil pan/pump etc, water pump, 2 row radiator; freeze plugs and obviously gaskets.
I already have FMS headers, aftermarket Y pipe with single high flow cat and Magnaflow muffler. I figure as long as the compression and cylinder walls looks good I can squeeze another 20K miles or more until I have to bore her.
Maybe I can also get close to 300hp and some wanted Tq. I don't think I would be to far off but just probing your minds!
Thanks in advance! :beer
