5.0 & 5.8 Fuel Rail spacing ? - Ford Bronco Forum
post #1 of 20 (permalink) Old 08-02-2012, 07:44 AM Thread Starter
Ford Hoarder
Anyone know the differance in width for the fuel rails between a 302 and 351? as in accros the intake, perpindicular to the heads. I am looking at getting a fuel rail kit and there are more 5.0 kits then 5.8 kits. Was going to get a 5.0 kit and make the lines longer to work on the 5.8 intake.
The SVO book I have says the intakes are 2.25 different. I was unsure if that applied to the fuel injector holes as well.
CrazyBRONCOguy is online now
post #2 of 20 (permalink) Old 08-02-2012, 11:20 AM
kyleson's Avatar
Bronco Info: 96 F150 4x4 Off-Road, 5.8, E4OD
That would probably be about right. The rails themselves would be the same, if you go with a kit that's AN lines and cut yourself it shouldn't be bad.
86 F350 XLT Lariat 4x4, power everything, AC, C6, 3.55, 265/75R16 STT on 16x8 Mojave's.
97 F350 XLT 4x4, 7.3, built E4OD, AFE Big Boost, GTP38R, IC, 17 HPOP, bellowed up pipes, efuel, 120v IDM, 160/100's, PHP Phoenix, 4" MBRP, 305/70R16 STT on 16x10 Eagles, over 400/800 to the wheels.
kyleson is offline
post #3 of 20 (permalink) Old 08-02-2012, 11:24 AM
Wrenching for a Livin'
magnumpi's Avatar
On my 5.8 i just bought edelbrock rails and stuck in some pipe thread adapters to AN/JIC fittings and made up a short crossover hose. Had pirtek do the new fuel supply, and return lines and a short line from the rail to the pressure regulator.
My SuperFord
'85 Bronco......
magnumpi is offline
post #4 of 20 (permalink) Old 08-02-2012, 12:54 PM Thread Starter
Ford Hoarder
I was thinking the same on the cut it to length kit. Russel makes one that looks like it would work well.
http://www.summitracing.com/parts/RUS-641550/
Accel also has one they say is for eithier, I dont know if the lines are extra long or what though and can't really find any good info on it.
http://www.summitracing.com/parts/ACC-77306/
post #5 of 20 (permalink) Old 08-02-2012, 01:00 PM
magnumpi's Avatar
the edelbrock one seems pricey. You can piece it together cheaper. Accel one might be a good option. you could always make up a line if its short. its simple
My SuperFord
'85 Bronco......
magnumpi is offline
post #6 of 20 (permalink) Old 08-02-2012, 01:09 PM Thread Starter
Ford Hoarder
Yeah the making the lines does not worry me too much. Was just looking for some input.
Thanks
post #7 of 20 (permalink) Old 08-02-2012, 06:14 PM
Seattle FSB's Avatar
I recommend that you consider Professional Products Fuel Rails. Good quality for a good price. I had a problem with ECT TEE clearance, but nothing a fitting couldn't fix. 5.0L/5.8L crossover line is different length, fuel injector spacing is the same.
Seattle FSB is offline
post #8 of 20 (permalink) Old 08-06-2012, 09:08 AM Thread Starter
Ford Hoarder
I have been looking they, have a kit with all the pieces too, however I have not found much info on their regulators and that, eithier good or bad.
post #9 of 20 (permalink) Old 08-06-2012, 11:06 AM
My Professional Products EFI Adjustable FPR (PN 10679) works great with no issues. Along with the Holley/Walbro 255 lph In-tank Fuel Pump, Canton Racing Products CM EFI High Flow Fuel Filter and Professional Products Powerflow Fuel Rail, it holds a steady 42 psi. But it is not the only adjustable FPR out there.
post #10 of 20 (permalink) Old 08-06-2012, 11:23 AM Thread Starter
Ford Hoarder
Did not know you were running one of their regulators as well. I have to look some more into their stuff.
Im more making sure my fuel system will not be the limiting factor when my new engine goes in. Would the stock pieces be sufficent, maybe, if anything these will look better.
post #11 of 20 (permalink) Old 11-10-2012, 06:39 AM Thread Starter
Ford Hoarder
Ended up getting the accel kit. However I would probably get the trick flow kit if I was to get the stuff again. The Accel kit is made to put fuel injection on a car with the regulator and that at the front of the engine. I had to change some things to make it work but its fine now, and I don't think any kit would of been 100% bolt on. I did use professional products fuel line adapters to go to the stock lines.
post #12 of 20 (permalink) Old 11-10-2012, 09:08 AM
Pic!
post #13 of 20 (permalink) Old 11-11-2012, 06:29 AM Thread Starter
Ford Hoarder
I will have to get a good one of what I ended up doing.
The stock ECT TEE piece was kept but changed a little bit for clearance on the front of mine, Im also not running a front cross over line.
post #14 of 20 (permalink) Old 04-25-2016, 01:36 PM
Hey Seattle, were the fittings that came in the professional products the rite size to hook up to the stock lines? (I believe they were 9/16 inlet, and 7/16 return?) But everywhere I've read on here I am finding that the lines are 5/16? I am using their rails on my 410 build but I didn't buy the whole kit. And unfortunately the rails from the kit and the ones you buy separately are slightly different which forces me to use a different style regulator. I'm trying to get all the fittings that I need so when it comes time to swap ill have everything there.
Form392 is offline
post #15 of 20 (permalink) Old 04-28-2016, 09:22 PM
If I recall, I am using:
Professional Products (Part #54181)
3/8" NPT to 9/16" Ford Fuel Inlet, 90 degree
Professional Products (Part #54187)
1/4" NPT to 7/16" Ford Fuel Return, 30 degree
post #16 of 20 (permalink) Old 04-28-2016, 10:50 PM
I love the Trick Flow stuff, I installed a few Professional Products stuff and was not impressed at the fit or quality of the castings. I guess you get what you pay for, I usually try to stick with the same brand of rail as the intake as for can be slightly different. Rails can be kinda funky, if they do not align properly or the holes are not sized right it will leak.
445 FE Bronco is online now
post #17 of 20 (permalink) Old 02-24-2017, 02:30 AM
Bronco Info: 96 Eddie Bauer 5.8 5" lift 35's
Just found a bad fuel leak on a new to me 96 Eddie Bauer 351 coming from a busted fuel rail. I have been looking for a new one and as far as I can tell, all the aftermarket fuel rails do not seem to work with the stock intake manifold. I was looking at the professional products but not sure if they still make the one posted earlier. Any ideas?
BigTom is offline
post #18 of 20 (permalink) Old 02-24-2017, 05:29 AM Thread Starter
Ford Hoarder
If I had your issue I would go to junkyard and grab a set of stockers. I have very rarely seen the stock setup fail, so I would bet that you will be able to find some in good shape.
post #19 of 20 (permalink) Old 02-24-2017, 04:33 PM
Well I got the fuel rail off and it looks like something furry decided to snack on the flexible lines connecting the two rails together. It left some peanut shells on top of the motor for me. I was wondering if a rubber hose splice would work or would the pressure be to much?
As an added bonus I found a broken off bolt holding the upper manifold to the lower. I do not believe it was leaking, but I am already into it this far. I feel like I should go ahead and pull the lower intake, but the last time I tried to install a lower intake I had a hell of a time getting it sealed up correctly. Not looking forward to that again.
BigTom is offline
post #20 of 20 (permalink) Old 02-28-2017, 10:59 PM
So I have decided to replace the formed plastic fuel lines connecting the two fuel rails together with regular rubber fuel line. The metal rail has barbs on the ends so I do believe I will get a good seal.
I will post results later after I get the broken intake bolt replaced and get everything back together.
BigTom is offline
