Seafoam how long? - Ford Bronco Forum
post #1 of 26 (permalink) Old 07-09-2005, 03:23 PM Thread Starter
Bronc40's Avatar
Bronco Info: 88 bronco 5.0 37 IROKS on 15x12 rims,2" body lift,2" pro comp coils,add-a-leafs, dual stabilizers.
Question Seafoam how long?
Okey just put a can of seafoam in the bronc. Need to know how long I should keep it in for before starting it? Motor has about 150,000 miles on it. Thx!
Bronc40 is offline
post #2 of 26 (permalink) Old 07-09-2005, 03:35 PM
derrick36's Avatar
Bronco Info: 1991 302, E4OD, 1356
I just did seafoam over 4th of july weekend. I left it in for about an hour b4 starting it back up.
Here's a good write up on that stuff http://www.fullsizebronco.com/forum/23-technical-write-ups/43682-how-sea-foam.html
derrick36 is offline
post #3 of 26 (permalink) Old 07-09-2005, 03:51 PM Thread Starter
Bronc40's Avatar
Here's a good write up on that stuff http://www.fullsizebronco.com/forum/showthread.php?t=43682
Guess I better fire it up then been about 30 minutes !
Bronc40 is offline
post #4 of 26 (permalink) Old 07-09-2005, 03:57 PM
Bronco Info: 4 sale
i usually dump it in 100 miles before an oil change
I wanna die in my sleep like my grandfather....not screaming like the passengers in his car....
94 Bronc, 351, warn premium hubs.
White/Silver
mostly stock.
31x10.5
Oh and i hate when people put future plans in their profiles, but she will get taller soon...
stock94 is offline
post #5 of 26 (permalink) Old 07-09-2005, 04:00 PM Thread Starter
Bronc40's Avatar
Do I rev the engine or let it idol?
Bronc40 is offline
post #6 of 26 (permalink) Old 07-09-2005, 04:06 PM
Bronco Info: 4 sale
i just drive it, i wouldnt kick it too hard, when you dump it in the crankcase, it thins the oil making it less protective
White/Silver
mostly stock.
31x10.5
stock94 is offline
post #7 of 26 (permalink) Old 07-09-2005, 04:09 PM
derrick36's Avatar
I'm guessing you put it thru a vacuum line. I reved the crap out of mine. If you haven't warned your neighbors, I'd do so now. It's going to smoke like an SOB.
post #8 of 26 (permalink) Old 07-09-2005, 04:10 PM Thread Starter
Bronc40's Avatar
Put it through booster vaccum line.
Bronc40 is offline
post #9 of 26 (permalink) Old 07-09-2005, 04:14 PM
derrick36's Avatar
It's gonna smoke like crazy.
The stuff works awesome tho
post #10 of 26 (permalink) Old 07-09-2005, 04:20 PM
Honeynut Cheerios Urine
JoeBob1901's Avatar
Bronco Info: 95 Bko/C150/C350
you can put it through the crankcase of brake booster line..
the longer you leave it in the intake, the longer it has to work...i've left mine overnight before
JoeBobOutfitters.com
SOLD:'95 2DR Bronco 60/10.25
SOLD:'95 4DR C350 PSD
SOLD:'95 4DR C150 351 '05 60/10.5[/URL]
JoeBob1901 is offline
post #11 of 26 (permalink) Old 07-09-2005, 04:22 PM
derrick36's Avatar
I was going to do the same thing, but I didnt want to walk my lazy ass to work.
Maybe next time.
post #12 of 26 (permalink) Old 07-09-2005, 04:24 PM Thread Starter
Bronc40's Avatar
Just let it set for half hour. Already noticed improvment. Not that much smoke as expected. Runs nice and smooth!!!!!!!!!!!!
Bronc40 is offline
post #13 of 26 (permalink) Old 07-09-2005, 05:03 PM
JoeBob1901's Avatar
Maybe next time.
I just did it after i got off from work..takes 2 seconds to throw it in there
post #14 of 26 (permalink) Old 07-09-2005, 05:45 PM
Bronco Info: 1990 Bronco 351 5.8L E.B. Edition (lift and tires soon baby!)
ok so I'm a little slow here but, if I have a 1990 (which the entire engine compartment looks very different from his 1986) which vacuum line do I pull off to let it suck all the of SeaFoam out?
- jboates
Visit my Supermotors page
jboates is offline
post #15 of 26 (permalink) Old 07-09-2005, 05:51 PM Thread Starter
Bronc40's Avatar
I pulled the vaccum line off of the brake booster on the upper drivers side engine compartment (firewall). Not sure if the 90 has the same setup
Bronc40 is offline
post #16 of 26 (permalink) Old 07-09-2005, 06:38 PM
Wanna see my
arkansawer's Avatar
Bronco Info: broncoless at the moment
Yes the 90 has the same set up. Mine is a 90, just pulled the vac. line off the booster and fed it sea foam. Waited about 20 or so minutes and started it back up. Smokes like a freight train. Ive let it idle, reved it, and drive it a few miles in a 20 minute time, and it still smokes. But one good thing though, is i found my exhaust leak, lol.
How long will it smoke?
The quickest way from point A to point B, is through the mud.
arkansawer is offline
post #17 of 26 (permalink) Old 07-09-2005, 06:50 PM
ok. I'll try to find where the hose is...and hope it's the right one :)
If it's anything like Bardol (sp?), for a while. Bardol smoke pretty bad for about 10 minutes but it might depend on how much crap it's burning out.
Is there such thing as too much SeaFoam? (I have to pass inspection and I have a lot of carbon build up)
- jboates
jboates is offline
post #18 of 26 (permalink) Old 07-09-2005, 07:01 PM
GHOSTRIDER's Avatar
Bronco Info: 90 XLT/351W, 6" LFT SAS, 9" 35" TIRES , 4.56, LOCKED, REALLY COOL SNORKEL, OTHER COSTLY CHIT
I got a 90 and did the seafoam thing...put a WHOLE can through the brake booster, and a WHOLE can in a tank of gas. Filled it at a rev, let it die, sit for about 30 minutes, when I cranked it back, the smoke was, shall we say, UNGODLY....drove it like I stole it, never ran better!
And to answer your question, I dont think there is any way to use too much seafoam, so long as you are sort of reasonable.
Riding on in the mist of morning, no one dares stand in my way...possessed by some distant calling, riding on through night and day.
PETE HALEY
GHOSTRIDER is offline
post #19 of 26 (permalink) Old 07-10-2005, 01:06 AM
Practicing Infidel
Sixlitre's Avatar
Ghostrider
Naive question. Everybody says they stall it and let the seafoam sit in the intake for a given period. Does it stall itself as it chokes down the can ? Or hwo do you stall it
Sixlitre (with can in his possession)
My Superford site
Sixlitre is offline
post #20 of 26 (permalink) Old 07-10-2005, 02:28 AM
JoeBob1901's Avatar
Originally Posted by Sixlitre
Ghostrider
Some people's engines stall, others dont..i would imagine it would depend on how strong your engine is running, how much you put in per second, etc...i normally have someone rev it up while im putting it in, then they kill it once it starts sucking air on the seafoam can..
When i've done it alone..it killed my engine, so, i just slowly poured it in until it mostly went in there, and then just let it guzzle it and kill it quick. I Just either let it partially in the can to slurp it up, or dunked it to kill it
